3 way switches-Building Code - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
  • 3 Post By Navyguy
  • 2 Post By Navyguy
  • 1 Post By trentonmakes
  • 1 Post By macmikeman
  • 1 Post By Navyguy
  • 2 Post By macmikeman
Old 04-20-2019, 11:16 PM   #1
Rewards Points: 626
Default 3 way switches-Building Code
Does the Canadian building code require a switch at every entrance of a room.
Installing lights in a room that has two entrances and trying to figure out if a switch is needed at each entrance.
Common sense and what I probably will do is a switch at each entrance but am wondering if it is a code requirement.
darren79 is offline   Reply With Quote
Old 04-20-2019, 11:24 PM   #2
Rewards Points: 3,858
30-502 requires a luminaire to be controled by a switch in pretty much every room.
Three-ways not a code requirement except at stairways... 30-504
Cheers
John
NDC, RRF and iori like this.
Old 04-20-2019, 11:31 PM   #3
Rewards Points: 626
This is a commercial space, that rule is for residential occupancy.
Old 04-20-2019, 11:57 PM   #4
RSE Master Electrician
Incognito's Avatar
Rewards Points: 630
Neither the building code nor electrical code require switches at every entrance to a room for residential or commercial.
2018 Ontario Electrical Code
Old 04-21-2019, 12:39 PM   #5
I am pretty good at a lot of things... but mind reading is not one of them I guess :-)
Commercial / industrial is open season. I have heard however some AHJ have related the installation of switches as a requirement for the safe ingress and egress to a space if there is not any permanent illuminated fixtures (night lights).
Cheers
John
The_Modifier and NDC like this.
Old 04-21-2019, 01:08 PM   #6
trentonmakes's Avatar
Rewards Points: 138
Screw the code
Install those motion sensors
No worries
Kevin_Essiambre likes this.
Old 04-21-2019, 02:30 PM   #7
Rewards Points: 15,923
In the NEC land , there is no requirement that the switch for lighting a room be even located in that room. Strictly speaking the switch for the lighting could be on another floor on the opposite side of the building and it would still meet code.
Not a very good idea obviously, but still meets code.
electricguy likes this.
Old 04-22-2019, 07:28 AM   #8
In my apprentice days I did a fair amount of lighting for grocery stores and other larger retail stores...
Typically we would have a separate lighting panel on a 3-pole contactor controlled by a single pole switch. Of course that switch would control all the lights in the entire space, retail area, stock room, loading bays, offices, mechanical, etc.
While electricity was a lot less expensive back then, it was either all on or all off and the switch was in some "hidden" location so it did not get turned off accidently.
I think today with the cost of electricity it makes more sense to spend a bit extra and control individual spaces with occupancy sensors.
Cheers
John
Old 05-02-2019, 11:43 PM   #9
Rewards Points: 283
Thumbs up
Here is quote from the 2015 hand book: The design of the switch locations for luminaires should not require the occupant to travel to the other end of the hallway or room to operate the switch. Similarly, where an area has multiple entrances, the use of 3- and 4-way switches enables the luminaires to operate independently at each entrance without the occupant having to move around in the dark looking for the switch. Like you said, better safe than sorry!!
Judoka is offline   Reply With Quote
Old 05-03-2019, 02:09 AM   #10
People have become so lazy that they cannot get off their ass and walk to a switch. They wanna be able to turn it on and off with their stupid smart phone.
There is an epidemic of obesity now. The NEC should have a code that says you have to go 25 feet minimum to turn on a light.
51360 and Funksparky like this.
Bonding sub-panel residential out building Easy General Electrical Discussion 16 10-02-2018 06:23 PM
Metered Sub-Panel Residential out building Easy General Electrical Discussion 8 10-02-2018 12:55 PM
For Sale: International Existing Building Code MDShunk Electrician Swap 0 09-24-2018 08:34 PM
Common Code Mistakes (Canadian) PlugsAndLights Canadian Electrical Forum 41 02-15-2017 11:28 PM
P.S. Knight 2015 Code book emtnut Canadian Electrical Forum 6 06-04-2016 09:31 PM
