Australian Plug wiring - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 2 Post By jw0445
  • 2 Post By daveEM
  • 1 Post By Incognito
Closed Thread
Old 04-17-2019, 11:48 AM   #1
Default Australian Plug wiring
Hi, I need to convert an Australian 240V 15A 50Hz plug to a north american plug. It's a 3 prong plug, two hot wiring on either side and the middle prong is wider and I am hung on weather it is Neutral or Ground. I think it is a ground just wanted some more opinions. This device has a control panel that controls 3 elements.
Any body experience this before?
Thanks,
gusterminator is offline
Old 04-17-2019, 12:20 PM   #2
canbug's Avatar
Rewards Points: 1,510
I'll refrain from being a smart ass, but you shouldn't be rewiring this even if you knew what you were doing.
Tim.
canbug is offline
Old 04-17-2019, 12:31 PM   #3
I have contacted the supplier and they are going to send me a diagram on the proper North american wiring. Next I will be Modifying the Unit so I can control it with Craft BeerPi. I will have solid state relays control the elements. I will have a switch that will allow the factory controller to control the temps or My controller to control the temps.
This is just the first modification of many
Old 04-17-2019, 12:36 PM   #4
jw0445's Avatar
Rewards Points: 1,644
good luck
The_Modifier and tmessner like this.
jw0445 is offline
The Following User Says Thank You to jw0445 For This Useful Post:
gusterminator (04-17-2019)
Old 04-17-2019, 01:04 PM   #5
daveEM's Avatar
Rewards Points: 2,382
Careful you don't burn up.
The_Modifier and 99cents like this.
I like perfect.
daveEM is offline
Old 04-17-2019, 01:37 PM   #6
RSE Master Electrician
Incognito's Avatar
Rewards Points: 618
What province are you in? I assume this equipment does not have a CSA logo on it?
In Ontario you would have to get "special inspection" to certify any modifications you make and give it CSA approval.
The_Modifier likes this.
Incognito is online now
Old 04-17-2019, 01:53 PM   #7
Rewards Points: 780
No ...I know how to power equipment....and if it is from overseas what certifications are needed.
Or is this something you are playing with ? If so this is not the site for you .
scotch is offline
Closed Thread
Non grounding type plug ratings reyamkram Other Codes and Standards 3 05-08-2018 02:21 PM
Residential Wiring Issue ParkModelElectrician Residential Electrical Forum 2 02-20-2017 08:12 PM
Continuity Between 2 Phases of 240V Plug Azachi Canadian Electrical Forum 13 02-16-2017 09:00 AM
NPLFA circuit wiring khfiei General Electrical Discussion 5 02-05-2016 11:03 PM
