Box fill 3x2x2.5 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 2 Post By 99cents
  • 2 Post By LawnGuyLandSparky
  • 3 Post By qwertyjjj
Old 12-01-2019, 06:53 AM   #1
Rewards Points: 6
Default Box fill 3x2x2.5
Reading through electrical code simplified (ps Knight) there is an example for a 3x2x2.5 box that seems weird.
"If we are using #14 cable and intend to run a 2 wire supply and 2x2 load cables into a 2in deep switch box and plan to make 2 joints in this box, we cannot.
The table shows a 2.5in deep box may contain the 5-#14 wires and the two splices (caps) we need."
3 cables is 6 wires so is something wrong on the table in their book? Page 108-110
qwertyjjj is offline   Reply With Quote
Old 12-01-2019, 07:44 AM   #2
Light Bender
eddy current's Avatar
Rewards Points: 7,892
Don’t have the book in front of me, but are you including the device? It counts for two wires as well.
Old 12-01-2019, 07:53 AM   #3
Rewards Points: 6
Yeah that's what it's saying. 2 for the device, 2 for the wire nuts, then only allowed 5 conductors. However there are 6 so the book is saying a standard 12.5cu in cannot be used.
Old 12-01-2019, 08:43 AM   #4
Light Bender
That is correct, it can not be used. I assume the picture is showing you what you can not do as that size of box can only have 8 x 14 awg wires as per table 23.
5 conductors
2 conductors for the device
1 conductor for up to 3 wire nuts
=8
Can you post a pic of the drawing you are talking about?
Old 12-01-2019, 09:15 AM   #5
Rewards Points: 6
Will do in a second. So in a 2x3 wall, I can never bring power to a switch, then wire onward to a light and another switch because it's too many conductors. My only option would be to bring power to the bigger octagonal box first? Even then I have to bring 3 wires down to the switch and have it as a switch box only?
Old 12-01-2019, 09:25 AM   #6
Light Bender
Are you an electrician or apprentice?
Old 12-01-2019, 09:27 AM   #7
Rewards Points: 14,851
Use a 4 X 4 and a plaster ring.
The_Modifier and Max C. like this.
Old 12-01-2019, 09:33 AM   #8
Rewards Points: 6
To be apprentice. More studying really at the moment...
Old 12-01-2019, 06:48 PM   #9
LawnGuyLandSparky's Avatar
Rewards Points: 172
WTF is a to be apprentice? A to be apprentice who just happens to be building a home, asking about exterior service disconnects, box fill and electric baseboard heater loads?
splatz and Kevin_Essiambre like this.
Old 12-01-2019, 07:05 PM   #10
Band Member
emtnut's Avatar
Rewards Points: 2,136
If you can stuff the receptacle in the box, yer good to go. If not, a couple of spacers work wonders
You should 3D print a toe attachment for your shotgun
Old 12-01-2019, 08:00 PM   #11
Rewards Points: 6
You never asked about that when first starting out? 😉
99cents, Max C. and RRF like this.
