Cathedral Ceiling LED Options n - Electrician Talk - Professional Electrical Contractors Forum
Old 07-15-2019, 07:35 PM   #1
Rewards Points: 79
Question Cathedral Ceiling LED Options n
I am curious as to what is the go to LED light when it comes to cathedral ceilings with insulation contact?
Do you guys find any issues with using the non pivoting style or should the pivoting style be used so the light is actually projected down towards the floor?
I am also curious as to what guys are doing to address the code change that required a neutral in every box that has a switch, particularly where 3 ways are installed? Are you running 14/4 AC90?
Anyone who has never made a mistake, has never tried anything new.
mr_electrician is offline   Reply With Quote
Old 07-15-2019, 07:46 PM   #2
Rewards Points: 11,459
You’re likely going to put in cans. That means either sloped ceiling cans or a normal can with a gimbal trim if it gives you enough angle. You can try the Lotus gimbals. Maybe.
Good luck with the 4 wire discussion. It kind of got beat to death here already.
Old 07-15-2019, 07:51 PM   #3
Can't Remember
Rewards Points: 864
The most recent one I needed something off the shelf and went with Juno new work cans and their gimbal trims. If I had more lead time available, I likely would have gone the Lotus route.
Old 07-15-2019, 08:27 PM   #4
Rewards Points: 79
I kinda figured that regarding the neutral at every switch.
I actually was looking at the spec sheets for the angled potlight cans, I am just not sure yet as to how much depth I have in the ceiling. So far the roof has not been framed up and the drawings don't show much detail.
Old 07-15-2019, 08:31 PM   #5
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 146
I've used light liteline products (Juno) for the cathedral ceilings. They work great.
Old 07-15-2019, 10:09 PM   #6
RSE Master Electrician
Incognito's Avatar
Rewards Points: 626
Feed the first switch with 2 wire, use a 3 wire between switches and then a 2 wire to the light. No 4 wire needed.
2018 Ontario Electrical Code
Incognito is online now   Reply With Quote
Old 07-15-2019, 11:07 PM   #7
Rewards Points: 79
Ever have one of those days where your mind shuts off???
You are absolutely correct. Not sure why I was thinking a 4 wire when there would already be a neutral in the box. (If the circuit was ran this way)
Old 07-17-2019, 12:41 PM   #8
Going_Commando's Avatar
Rewards Points: 1,476
I've used 4-wire for dead end 3 ways in the past. Most of the time it just easier to feed one end of the switches, and load the other.
Old 07-17-2019, 01:09 PM   #9
Rewards Points: 15,887
Halo's even cheaper cousin "Commercial Electric" brand makes and sells gimbaled wafer style lights at Home Depot. Beware- they are thicker than the usual 1/2" depth wafer lights so if there is a truss up there above the rock you are in trouble. They are about an inch or an inch quarter or so deep. Or more. I just pulled one out of the box one day and glanced at it to see how they looked. Not bad incidentally .
Old 07-17-2019, 08:57 PM   #10
Rewards Points: 1,173
I don't like the look of gimbal rings in a sloped ceiling. If you tilt them too much, the top side sticks out of the ceiling and looks ugly. For new construction, I usually go with a sloped ceiling can, white baffle trim and a screw in LED R lamp. If the ceilings are 2x6, I'll go with a regular 4" can and an LED eyeball trim. This is still not my favorite look, but eyeballs have a finished look on all sides at steeper angles then gimbals.
If money is no object, Juno slope LED cans and trims. They are stupid expensive though. 3-4x the cost of an incandescent can and LED lamp.
