CEC Insulated Ground in wood studs - Electrician Talk - Professional Electrical Contractors Forum
Old 02-03-2014, 06:04 PM   #1
Aegis's Avatar
Rewards Points: 1,740
Anyone ever had a problem with an inspector running an insulated ground to the water main in a house through wood studs?
Drywalled ceiling.
Aegis is offline   Reply With Quote
Old 02-03-2014, 06:07 PM   #2
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Never done it in a house but I have run the ground through the wood studs and behind the drywall on commercial construction. Never been an issue.
Old 02-03-2014, 06:16 PM   #3
wcord's Avatar
Rewards Points: 388
Never run an insulated ground, just bare, but regardless, never had a problem.
What's the suspector questioning?
Old 02-03-2014, 06:22 PM   #4
Aegis's Avatar
Heat, almost like a Romex above at bar ceiling - like its not plenum rated. But the ceiling isn't an air duct or anything.
Old 02-03-2014, 06:44 PM   #5
wcord's Avatar
Rewards Points: 388
Is he looking for FT6 rating or what?
if its a house and you are not running inside the cold air joist lined plenum, whats the problem?
Old 02-03-2014, 06:50 PM   #6
jza
Mad as Hell Member
jza's Avatar
Rewards Points: 2,318
Jesus Christ. Some inspectors.
jza is offline   Reply With Quote
Old 02-03-2014, 06:56 PM   #7
Aegis's Avatar
Originally Posted by wcord
Is he looking for FT6 rating or what? if its a house and you are not running inside the cold air joist lined plenum, whats the problem?
Exactly.
Old 02-03-2014, 07:01 PM   #8
wcord's Avatar
Rewards Points: 388
Originally Posted by Aegis View Post
Exactly.
Here in MB, rule 12-010 has been relaxed to allow residential wiring to cross thru a plenum if it is constructed of combustible material, ie a joist lined plenum. Your guy is an idiot
The Following User Says Thank You to wcord For This Useful Post:
Hmacanada (02-03-2014)
Old 02-03-2014, 07:06 PM   #9
Hmacanada's Avatar
Is it coming in contact with the heat runs for duct work?
Hmacanada is offline   Reply With Quote
Old 02-03-2014, 07:06 PM   #10
Aegis's Avatar
Ok I'll call him an idiot tomorrow and hopefully everything goes smoothly.
The Following User Says Thank You to Aegis For This Useful Post:
electricguy (02-05-2014)
Old 02-03-2014, 07:07 PM   #11
Aegis's Avatar
No. And if it was I would have separation/insulation in between as if it were a Romex.
Old 02-03-2014, 07:09 PM   #12
wcord's Avatar
Rewards Points: 388
Let us know how well that turns out. rotf
Old 02-04-2014, 04:59 PM   #13
Navyguy's Avatar
Rewards Points: 86
Drywalled ceiling.
No I have not, but I know exactly where this is going. Use bare and you won't have any issues where it is run. Might be less expensive also.
Cheers
John
John Kuehnl-Cadwell
Old 02-04-2014, 05:17 PM   #14
Rewards Points: 1,810
Most insulated wires do not have a flame spread rating and must be installed in a raceway if in a plenum or bare.
For buildings of combustible construction wires must be at least FT-1 with telephone and data wiring at least FT-4 if in a plenum.
non combustible buildings the asme is FT-4 and FT-6 for the data and tel.
any insulated wire must have at least FT-1 for combustible construction, in a raceway of at least ft-4 or metal, or bare. Note that I do not think that PVC or ENT raceways are FT-1 but FT-4
That Most EI probably do not catch the insulated ground wire I would say this inspector is looking pretty close.
Old 02-04-2014, 05:38 PM   #15
Rewards Points: 174
Most insulated ground that I have used has been FT1 rated. Even on jobs that speced FT4
BlackHowling is offline   Reply With Quote
Old 02-04-2014, 11:48 PM   #16
Rewards Points: 340
Drywalled ceiling.
Time to get your knife out and make all visible insulation disappear.
FrunkSlammer is offline   Reply With Quote
CEC insulated ground/bond Mcsparkin Residential Electrical Forum 1 03-04-2013 09:04 AM
Running SER through studs Zparme General Electrical Discussion 78 07-02-2011 12:44 PM
Horizontal EMT runs through wood studs Lone Crapshooter General Electrical Discussion 82 04-01-2011 07:50 PM
SEU through Studs? HectorRogerio General Electrical Discussion 13 04-12-2010 01:10 AM
ceiling studs olectric Workplace Safety 13 08-31-2008 04:32 AM
