CEC transitioning conduit types - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By 99cents
  • 2 Post By Kevin_Essiambre
Unread 10-16-2019, 04:53 PM   #1
Rewards Points: 238
Default CEC transitioning conduit types
I am going to install EMT with ground in a garage for a receptacle. When I exit the garage to the exterior I want to transition to PVC for about 5 feet where I will then go into the home near the panel and transition to non metallic liquid tight.
In the garage I want to install an LB right before I transition to PVC conduit.
Where I enter the home with a PVC LB, what is the appropriate method to transition to flexible conduit without having to install a box?
newbie44 is offline   Reply With Quote
Unread 10-16-2019, 04:57 PM   #2
Fist of lightning's Avatar
Can I thread a PVC TA into the metal LB?
Yes they make female adapters that I have used a lot to transfer pvc to emt for stub ups from the slab .
CEC transitioning conduit types-bc8e51fa-6202-4a0c-a291-3485f27fab59_1571255872198.png
Fist of lightning is offline   Reply With Quote
Unread 10-16-2019, 04:58 PM   #3
Rewards Points: 13,401
This sounds DIY. No electrician would use liquid tight.
The_Modifier likes this.
Unread 10-16-2019, 06:46 PM   #4
Rewards Points: 238
I use it all the time.
Unread 10-16-2019, 07:39 PM   #5
Rewards Points: 52
Do you want the cheap, easy way or the compliant way?
Sent from my SM-G970U1 using Tapatalk
Unread 10-16-2019, 11:00 PM   #6
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 250
Why not use teck all the way?
The_Modifier and 99cents like this.
Unread 10-16-2019, 11:23 PM   #7
Rewards Points: 238
The customer wants conduit in the garage for esthetics.
Unread 10-16-2019, 11:25 PM   #8
Beam Me Up Scotty
Rewards Points: 250
EMT to boxes?
Why not do conduit to a connector then thread a rigid coupling on and spin a teck connector and go teck outside?
I guess at that point you could use polytuff
Unread 10-16-2019, 11:33 PM   #9
Rewards Points: 18
Just emt it the whole way.
mofos be cray is offline   Reply With Quote
Unread 10-16-2019, 11:37 PM   #10
Rewards Points: 238
EMT to boxes?
How does one go from emt to polytuff without using a jbox?
Unread 10-16-2019, 11:48 PM   #11
Beam Me Up Scotty
Rewards Points: 250
Bridgeport makes a fitting for that.
Bptfittings.com
