does all of you follow rule 12-510 for armored cable - Electrician Talk - Professional Electrical Contractors Forum
Old 05-16-2011, 01:29 PM   #1
Rewards Points: 2,124
Default does all of you follow rule 12-510 for armored cable
This rules tell us to support cable (even armored cable) at maximum 12" of box, i try to follow it most of the time but ive seen in big industries that it is not followed at all, ive seen a lot of 2-3 feet distance for the first anchor of cable (teck cable).
Old 05-16-2011, 02:27 PM   #2
Sideways Sparky
farlsincharge's Avatar
Rewards Points: 1,170
Our inspectors are generally strap nazis. They enforce supports and any recent codes (AFCI, Tamper resistant etc...) I strap the piss out of everything.
farlsincharge is offline   Reply With Quote
Old 05-16-2011, 04:27 PM   #3
JohnR's Avatar
I always do, unless it is in a fixture that has the doghouse too far from the tywire. Then I leave it at the 14 inches or so, that the distance is.
Signed out.
Old 05-16-2011, 05:11 PM   #4
Beware Of The Apprentice
Always. As the low man on totem pole I also get to go back and strap all the ones that are as you've mentioned, too far or non existing.
I know you guys have diff rules up there but this one is the same (at least here in Phx).
wsntme is offline   Reply With Quote
Old 05-16-2011, 08:47 PM   #5
Mike in Canada's Avatar
Rewards Points: 506
I don't worry about it,much. Motors I give a lot of leeway to (for vibration, and so you have enough slack for a mechanical guy to move the motor out of his way without disconnecting it. If this means there is 2 feet of teck hanging in the breeze then so be it. I've never had an inspector fail me on it.
Mike in Canada
Makin' it up as I go along...
Mike in Canada is offline   Reply With Quote
Old 05-17-2011, 05:02 PM   #6
Rewards Points: 1,810
Mike, you offer an interesting observation. If the cable is not stressed and as you have offered there is reason to extend the first strap rule I would consider it. Strapping or the lack of it is the #1 most frequent reason for writing a violation followed closely with second box supports in Steel studs. The most common place for strapping deficiencies is in T-Bar cielings.
Old 05-17-2011, 05:08 PM   #7
Rewards Points: 2,002
So you are more or less following the changes in the US and adapting AFCI's and TR's into the CEC?
Old 05-17-2011, 10:51 PM   #8
Rewards Points: 504
The NEC has Canadians and the CEC have Americans acting in purely advisory roles in helping shape the codes. Many UL standards are either bi-national (usually Can-US) or tri-national standards that include Mexico. Then we've got harmonized standards that are largely the same with some minor twists i.e. CSA Z462 and NFPA 70E.
In short, with a lot of standards and codes, Canada and the US are more or less working in sync with one another.
I don't follow the CEC but the (Ontario Electrical Safety Code) OESC. That said we've had AFCIs on the books for about a decade, TRs since 08 in Ontario.
Mike_586 is offline   Reply With Quote
Armored cable use marty General Electrical Discussion 38 06-19-2012 03:47 AM
Which rule to follow jwjrw NEC Code Forum 29 10-16-2010 08:00 PM
NJ. Gets it Right. Other States to Follow? John Valdes Off Topic (Non Trade) 165 01-23-2010 09:59 AM
Steel Wired Armored cable useage in USA marty General Electrical Discussion 18 08-27-2009 04:06 AM
PVC Jacketed Armored Cable stripper Mountain Electrician General Electrical Discussion 19 01-27-2008 04:46 PM
