Emergency and exit lighting, Canada - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
  • 1 Post By CoolWill
  • 1 Post By splatz
  • 1 Post By daveEM
  • 2 Post By emtnut
  • 3 Post By 908Eng
  • 1 Post By stuiec
Old 01-18-2019, 08:23 AM   #1
Rewards Points: 1,995
Default Emergency and exit lighting, Canada
I have two restaurants starting, small places with a few tables, mostly take out. The last one I did had exits and emergencies on the drawings. This time they have been left out.
I am not sure of building code requirements. I read somewhere that they are required for an occupancy load over 60.
Help.
Old 01-18-2019, 09:02 AM   #2
CoolWill's Avatar
Rewards Points: 644
Help.
Isn't this something you could eyeball? I mean, you know where the exits are, you know where the bathrooms are, you know where the hallways are, etc.
Kevin_Essiambre likes this.
Old 01-18-2019, 09:29 AM   #3
daveEM's Avatar
Rewards Points: 2,382
Have a look...
chrome-extension://oemmndcbldboiebfnladdacbdfmadadm/http://www.tnb.ca/en/brands/lumacell/files/3LU_Building_Code_EN.pdf
^^ weird link but seems to work for me.
I use the Brave Browser which is built on Chrome but has all the filthy Google stuff snuffed out.
Also use DuckDuckGo for the search engine which has all the Google filthy stuff snuffed out.
Liking it.
I like perfect.
Old 01-18-2019, 09:43 AM   #4
CoolWill's Avatar
Rewards Points: 644
Originally Posted by daveEM View Post
Have a look...
Liking it.
So, skimming through that, I didn't see mention of emergency lighting for restrooms. Is that not something you do in Canada? We don't require it everywhere here either. It varies from jurisdiction to jurisdiction. Usually a fire code.
Old 01-18-2019, 09:58 AM   #5
Rewards Points: 2,470
So in Canada, if you don't know enough to get out of the bathroom if the building's on fire, it's f. you, burn motherf'er?
I am all right with that, but they say Canadians are so nice, I think once you scratch the surface, they're pretty ****ing hostile.
CoolWill likes this.
This too shall pass.
Old 01-18-2019, 10:00 AM   #6
That is the opposite of a brave browser. They should call it Scaredy Browser.
Old 01-18-2019, 10:19 AM   #7
Wardenclyffe's Avatar
Rewards Points: 626
Or like the Exchange rate,
.75 x The Exits in the States,...
Wardenclyffe is online now   Reply With Quote
Old 01-18-2019, 10:28 AM   #8
daveEM's Avatar
Yeah it doesn't seem to list them. We light em up tho. At least the larger ones I've been in.
I like perfect.
Old 01-18-2019, 11:52 AM   #9
Who made the drawings? Was it an engineer or are they on the back of a napkin?
If engineered drawings confirm with them. May end up being a nice little extra for you...
Kawicrash is offline   Reply With Quote
Old 01-18-2019, 12:11 PM   #10
Band Member
emtnut's Avatar
Rewards Points: 2,514
I can't speak for all the Canucks, but it doesn't really take much scratching for me
splatz and CoolWill like this.
Old 01-18-2019, 07:57 PM   #11
908Eng's Avatar
Rewards Points: 172
From the NBC (most provincial codes have nearly verbatim clauses, I have the BCBC and ABC if you want a specific reference):
3.2.7.3 Emergency Lighting
1) Emergency lighting shall be provided to an average level of illumination not
less than 10 lx at floor or tread level in
a) exits,
b) principal routes providing access to exit in open floor areas and in service rooms,
c) corridors used by the public,
d) corridors serving sleeping rooms in a treatment occupancy,
e) corridors serving sleeping rooms in a care occupancy, except corridors
serving sleeping rooms within individual suites of care occupancy,
f) corridors serving classrooms,
g) underground walkways,
h) public corridors,
i) floor areas or parts thereof where the public may congregate
i) in Group A, Division 1 occupancies, or
ii) in Group A, Division 2 and 3 occupancies having an occupant
load of 60 or more,
j) floor areas or parts thereof of daycare centres where persons are cared for, and
k) food preparation areas in commercial kitchens.
3.4.5.1 Exit Signs
1) Every exit door shall have an exit sign placed over or adjacent to it if the
exit serves
a) a building more than 2 storeys in building height,
b) a building having an occupant load of more than 150, or
c) a room or floor area that has a fire escape as part of a required means of egress.
In general... Emergency lighting is needed everywhere regardless of occupancy / size / etc. Exit lighting is only needed when you have more than 150 people or a 3 storey building or higher.
Hope that helps.
CAVEAT: Information presented in this post does not constitute professional engineering advice.
908Eng is online now   Reply With Quote
Old 01-19-2019, 07:57 AM   #12
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,688
Default We are not alone down here.....
a) exits,
load of 60 or more,
3.4.5.1 Exit Signs
exit serves
Hope that helps.
I like funny codes
Who decides which paths are the principle routes?
What's the difference between c(corridors used by the public) and h(public corridors)?
How do you determine where the public may congregate, wouldn't that be everywhere?
Also, looks like you can save a li'l cash as they only require exit signs.
I hate to see her go, but I sure love watching her walk away.
Old 01-19-2019, 08:42 AM   #13
cabletie's Avatar
Rewards Points: 1,274
Originally Posted by CTshockhazard View Post
I like funny codes [IMG class=inlineimg]https://www.electriciantalk.com/images/smilies/wink.png[/IMG]
[IMG class=inlineimg]https://www.electriciantalk.com/images/smilies/vs_smirk.gif[/IMG]
Here the route, the length of the route, and how many people are going to take that route is usually on the life safety plan.
Emergency and exit lighting, Canada-a21dc12a-9587-44d3-9b7b-28648b981b31_1547905317626.jpg
Old 01-19-2019, 08:59 AM   #14
Still confused. This is a flat rate job. Extras are like pulling teeth. The default answer is “make it to code”. To have emergency lighting and no exits in a small restaurant makes no sense.
Do I need emergency lighting in bathrooms?
Old 01-19-2019, 09:17 AM   #15
CoolWill's Avatar
Rewards Points: 644
I read through that document that Dave posted twice. I saw no mention of bathrooms. Here it is usually a fire code and under the authority of the fire marshal.
99cents likes this.
Old 01-19-2019, 10:23 AM   #16
What I'll sometimes do is talk to the inspector for that district, or even the chief and ask him. I know them all so that's an advantage, because it's not up to them to tell you how to do things, but if you are nice and friendly they will usually point you in the right direction. If you're off home turf things might be different however.
My brother was a city mechanical inspector for 30+ years, and I know he would often help guys out as long as you weren't an a**hole about it.
Old 01-19-2019, 01:09 PM   #17
908Eng's Avatar
Rewards Points: 172
All great questions. I still battle with these frequently.
I have stopped trying to understand the reasoning for code rules a long time ago. Trying to figure out the rationale is usually fruitless (ie. public corridors vs corridors used by the public). "Don't try to find logic in stupidity" - unknown!!!
I show emergency remote heads in bathrooms but if there is any push back from the contractor on a fixed budget, I usually cave! I won't update the drawings but I also won't hold up the final occupancy. I can't find any reference that requires emergency light in a bathroom but some building inspectors require them regardless.
In my office, we frequently have projects with emergency lights and no exit signage. If the building already has exit signs, I will usually extend them. If there are exit signs anywhere, they should be everywhere. If half the building has the old red EXIT signage, we usually consult with the building inspector to determine if the new area needs RUNNING MAN or old red EXIT signage to match. Sometimes the building inspector wants the whole building upgraded to green RUNNING MAN.
If I were 99cents, I would recommend installing the economy battery packs in minimal locations until the building inspector is satisfied. Forget the exit lights unless you are in a 3 storey building (or up) or have more than 150 people total.
Old 01-19-2019, 02:34 PM   #18
Watt Pusher
B-Nabs's Avatar
Rewards Points: 480
As far as I know em lights are not required in bathrooms here, but are often shown on engineered drawings.
Old 01-20-2019, 06:28 PM   #19
billyhunter's Avatar
Rewards Points: 218
check with engineer who prepared the permit, it is a simple job, otherwise pretend you know nothing because no drawings from engineer or building permit.
billyhunter is offline   Reply With Quote
Old 01-23-2019, 09:59 PM   #20
cog
stuiec's Avatar
Rewards Points: 1,302
Well, its a lot easier to be nice when a few of the poindexters that can't find their way out of a one exit bathroom have been burnt off.
Phones and Safety splatz Workplace Safety 17 12-09-2018 11:31 PM
Emergency lighting and exits, Canada 99cents Canadian Electrical Forum 14 09-04-2018 06:06 PM
Emergency and Exits fed from Night Lights? Arcflasher Commercial Electrical Forum 10 11-15-2017 08:23 PM
EM lighting Chicagospark General Electrical Discussion 23 06-27-2016 12:01 AM
