Exit signs - Electrician Talk - Professional Electrical Contractors Forum
Like Tree29Likes
Old 11-21-2019, 06:29 AM   #1
Rewards Points: 18
Default Exit signs
I've got 3 exit signs that need a replacement battery in a fast food joint. I was just going to slap some new batteries, hit the test button to make sure they work and leave it at that. But then one of the guys I work with said you had be certified as an exit sign guy. Is that true? I'm in bc if it makes a difference. Also, would you guys do anything different from what I propose?
mofos be cray is offline   Reply With Quote
Old 11-21-2019, 07:19 AM   #2
Watt Pusher
B-Nabs's Avatar
Rewards Points: 480
Plastic self powered exits are $40 - 50 and exits are a pain in the d!ck, so for that money I would just replace the whole sign.
pudge565, dronai, tmessner and 1 others like this.
Old 11-21-2019, 07:30 AM   #3
Rewards Points: 1,537
I tell people this all the time. I can bring a new sign with me and give them everything brand new.
If I go there and I have the wrong battery or the bulb/LED is the issue then it is going to cost 2-3 times as much for me to go out and find what I need and return to install it.
Old 11-21-2019, 09:54 AM   #4
Rewards Points: 908
Just install new ones. I have had the circuit board/ charging circuit be the problem to many times. I have also ordered the exact replacement battery and had them be an unmeasurable difference in size and not fit in the case. Let the mfg install the battery. Same thing for small under the desk ups units
Old 11-21-2019, 10:00 AM   #5
Rewards Points: 1,879
What the **** is a certified exit sign guy?
Old 11-21-2019, 10:33 AM   #6
CoolWill's Avatar
Rewards Points: 604
Around my way they are the fire protection companies that also supply fire extinguishers and alarms.
Old 11-21-2019, 10:38 AM   #7
Around my way, we wire ‘em up and kill the breaker as a test. Done. You think I’m going to hire some exit sign dude?
Kevin_Essiambre likes this.
Old 11-21-2019, 10:40 AM   #8
Who certified them?
Did they use the same method that I used to certify my own company (by writing certified on the side of their van)?
Old 11-21-2019, 10:44 AM   #9
Rewards Points: 18
Thanks ya'll. Ya I told them to change the signs or rather, I told the boss to tell them but here I am changing batteries so idk. As a follow up the coworker said you needed to be certified so you could sign off on the signs functioning correctly. Welcome to Canada we there is a rule for everything.
Old 11-21-2019, 10:45 AM   #10
CoolWill's Avatar
Rewards Points: 604
These guys go around to existing installs and test the lights and put a sticker on them with a date.
Who certified them?
The National Academic Academy of Fire-ology.
MikeFL likes this.
Old 11-21-2019, 10:52 AM   #11
This isn’t a Canadian thing. You must live somewhere special.
Old 11-21-2019, 11:16 AM   #12
Rewards Points: 18
This isn’️t a Canadian thing. You must live somewhere special.[/QUOTE]
It's special alright. Short bus special.
99cents likes this.
Old 11-21-2019, 11:31 AM   #13
canbug's Avatar
Rewards Points: 2,032
Have your boss certify you, put a sticker on the exit light and charge an extra $50.
People will pay for what they don't know or what they think is expected. I wouldn't do it but I sure would be temped to.
Tim.
Old 11-21-2019, 12:33 PM   #14
Tim.
I dunno, like Will says, maybe someone has to go around every year or so testing fire extinguishers and emergency lighting to satisfy the fire marshall or insurance company. That has nothing to do with us as installers.
Old 11-21-2019, 02:21 PM   #15
Rewards Points: 792
Vancouver and a couple of other BC locations have certification for people doing fire extinguisher ,fire alarm systems , exit lighting systems in their areas thru the BC Techs group.
Old 11-21-2019, 02:45 PM   #16
That can’t mean an electrician needs to be certified to hang a few emergency/exits in a new taco joint, does it? Duh.
Old 11-21-2019, 03:03 PM   #17
canbug's Avatar
Emergency lighting checks are on our monthly PMs, therefore documented and repaired if they don't work. Fire extinguishers are contracted out for annuals but we have in-house do the monthly's there too.
Tim.
Old 11-21-2019, 04:06 PM   #18
Rewards Points: 792
ASTTBC has listing of life safety equipment testing certification requirements that have been adopted by various cities/municipalities in BC.
Doesn't effect installation of electrical equipment.
99cents likes this.
Old 11-21-2019, 05:47 PM   #19
Code Man's Avatar
That can’️t mean an electrician needs to be certified to hang a few emergency/exits in a new taco joint, does it? Duh.
In Ontario, I think the building code specifies when emergency lighting and exits are to be installed. A licensed electrical contractor installs them, and an annual inspection by a fire prevention officer, or an ESA inspector can check if they are operating correctly and require repairs as necessary.
Code Man is offline   Reply With Quote
Old 11-21-2019, 09:09 PM   #20
Watt Pusher
B-Nabs's Avatar
Rewards Points: 480
I think the distinction is between installation, and modification or repair. Around here anyway, exit signs and emergency lighting battery packs are tested annually by an ASTTBC certified technician who applies a tag with the date of test, result, and due date for re-inspection. I don't know if replacing a battery in a sign is supposed to be done or at least inspected by those guys, but installing a new sign sure isn't, and like I said before is just as much work and not much difference in cost. You wouldn't catch me fudging around replacing a self powered exit battery, not worth the effort. New sign.
