Flexible wire for hoist? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 1 Post By HackWork
  • 1 Post By Navyguy
  • 1 Post By telsa
  • 1 Post By CTshockhazard
  • 1 Post By LawnGuyLandSparky
  • 1 Post By Funkadelicfred
Old 08-28-2019, 06:58 PM   #1
Rewards Points: 228
Default Flexible wire for hoist?
Recently put in some wiring for a hoist. From the octagon on the ceiling halfway down the hoist track, boss put a Kellem grip on some cabtyre/SO wire and then a spring screwed under a PVC strap for flexibility. I personally thought it looked like **** and looked pretty hack but I don't know any other way to do it. What do you guys do when you need an extra long power drop cord for something like that and what connectors and such?
Funkadelicfred is offline   Reply With Quote
Old 08-28-2019, 07:08 PM   #2
Rewards Points: 353
I'm not really sure of what you described.
What's wrong with just using one of these?
Old 08-28-2019, 07:11 PM   #3
Rewards Points: 228
Attachment 136422
Yeah I know my description kind of sucks but it's hard to describe it. If we only used one of those, then we'd have 30 feet of cabtyre hanging down to the floor.
Old 08-28-2019, 07:48 PM   #4
Rewards Points: 4,968
Do the same thing except usually use an eye bolt for the spring. Not sure I have any pictures, but it is a pretty standard install.
Cheers
John
Old 08-28-2019, 07:53 PM   #5
Watt Pusher
B-Nabs's Avatar
Rewards Points: 470
The PVC strap sounds dubious, otherwise sounds pretty bog standard to me.
Old 08-28-2019, 08:21 PM   #6
Rewards Points: 228
Ok I guess that's the way it's done then.
Old 08-28-2019, 08:41 PM   #7
Rewards Points: 353
I am still trying to visualize what’s going on. Springs, eyebolts, straps?
Old 08-28-2019, 09:44 PM   #8
Something like this
Except there is a spring in between the eyebolt and the kellems grip.
Cheers
John
telsa likes this.
Old 08-28-2019, 10:30 PM   #9
joe-nwt's Avatar
Rewards Points: 1,016
What does the spring do in that application?
Old 08-28-2019, 10:58 PM   #10
To be honest, I think it is a throwback from the hazardous area section where the cables had to have a form of strain relief other than the connector itself.
Perhaps garages had this classification at one time. I know in industry it has been a specification too.
Cheers
John
Old 08-29-2019, 12:45 AM   #11
Rewards Points: 26,398
A spring provides 'forgiveness' -- so that you have a few inches of stretch when the crew is fiddling with the other end.
It's like the toe-warning lip sometimes seen on scaffolds. It tells the guy -- "Hey, you're right at the edge -- dummy!"
glen1971 likes this.
Old 08-29-2019, 08:40 AM   #12
Rewards Points: 228
For my situation it provides a lot of of extra flexibility. It was next to a 20 foot hoist track so it needed to be able to stretch a good amount without having a giant coil of wire touching the floor at the start position.
Old 08-29-2019, 09:14 AM   #13
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,564
I've used these sky-ties as well:
Navyguy likes this.
Were you born retaŕded or did you pick that up on your own?
Old 08-29-2019, 09:53 AM   #14
Rewards Points: 228
Those look onteresting
What specific application are these for compared to a Kellem grip and spring?
Old 08-29-2019, 10:07 AM   #15
joe-nwt's Avatar
Hah! The light finally came on!
I initially thought of a vehicle hoist but you are talking about an electric chain/cable hoist, correct? In that case, I can see the purpose of the spring.
Old 08-29-2019, 02:59 PM   #16
LawnGuyLandSparky's Avatar
Rewards Points: 172
Try a ratcheting cable reel mounted to the ceiling with the ratchet option disabled.
Kevin_Essiambre likes this.
Old 08-29-2019, 05:16 PM   #17
Rewards Points: 228
Yes it's a big suction cup hoist to lift up pieces of plywood and such and take them one way or another.
Old 08-29-2019, 05:18 PM   #18
Rewards Points: 228
Have you tried that before? Never had any issues with it getting tangled up or something?
Old 08-30-2019, 09:07 AM   #19
Sentimental Mental
These are nice mid run as they split in two so you wouldn't have to slide the kellems a long way.
I didn't know they made a kellems grip with a spring, I've only seen the open end and connector end types.
Old 08-30-2019, 03:01 PM   #20
Rewards Points: 228
No the spring was seperate. It was a normal open ended grip, then one of those springs with the two hooks poking out the end (sorry, don't know what they're called) and then that hook was attached to a loung, extra-springy spring which was attached to the ceiling via a strap.
CTshockhazard likes this.
