Largest 100 amp panel? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree31Likes
Old 05-21-2020, 10:07 PM   #1
NDC
NDC's Avatar
Rewards Points: 2,460
Default Largest 100 amp panel?
Im looking for a 40/80 100 amp residenetial load center panel. Does Siemens make one? I cant find their panel list anywhere on their website.
I'd rather use Siemens because I have tons of breakers I can use.
Old 05-21-2020, 10:22 PM   #2
NDC
NDC's Avatar
Nevermind found it SEQ40100
Still looking for a pdf panel list though.
Old 05-21-2020, 10:35 PM   #3
MHElectric's Avatar
Rewards Points: 5,596
Wow, I know Canada is different than the US, but I didn't think they made 100amp main breaker panels bigger than 20 spaces. At least I never paid enough attention to remember otherwise.
Old 05-21-2020, 10:58 PM   #4
Rewards Points: 2,897
I just left a 32/32 100a MCB GE panel at Home Depot the other day. Not my panel of choice, but $24.03 might sway me if I already had a job sold with one. Siemens has a 30/40 100a MCB. If you need bigger (not in Canada) you can always get a 40/80 ML and stab in a 100a main with a hold down kit.
Kevin for Moderator
Swampy doesn't want the job
* Make Electriciantalk Great Again! *
Old 05-22-2020, 06:24 AM   #5
Rewards Points: 2,390
I had a pretty good PDF for Siemens panels but I can't find it now. Their web site is comically awful.
Kevin_Essiambre and 908Eng like this.
This too shall pass.
Old 05-22-2020, 08:22 AM   #6
Going_Commando's Avatar
Rewards Points: 1,620
We used to put in a bunch of square d 100a 30 circuit panels back in the day. Then the 200a service became the norm.
Old 05-22-2020, 08:23 AM   #7
Rewards Points: 1,287
I use 30 space 100A Homeline panels all the time when upgrading just the panel. Many houses have a lot of circuits but very little load.
electricguy, Gnome and RRF like this.
Old 05-22-2020, 08:51 AM   #8
Rewards Points: 5,556
In the first post you ask for a load centre, then in the second the model number is a Service Entrance panel; which one do you want?
If it is a load centre, you can put in anything based on the protection ahead of it.
Cheers
John
iamsparky and NDC like this.
Old 05-22-2020, 08:54 AM   #9
wcord's Avatar
Rewards Points: 2,030
How about a 200amp 60/120 cct Homeline?
That should cover everything
Kevin_Essiambre likes this.
Old 05-22-2020, 10:49 AM   #10
NDC
NDC's Avatar
Cheers
John
You're right, I always thought a load center was a panel with a main breaker!
Actually EQL is main lug only. SEQ is service entrance rated but Siemens lists them all as load centers.
Navyguy likes this.
Old 05-23-2020, 01:40 AM   #11
Wardenclyffe's Avatar
Rewards Points: 620
https://digitalcontentcenter.compas....11-ALL-web.pdf
Wardenclyffe is offline   Reply With Quote
Old 05-23-2020, 08:35 AM   #12
HertzHound's Avatar
Rewards Points: 1,340
The way I always understood it, is that a loadcenter is a panelboard and back box (cabinet or Cutout box) all in one. It can be main breaker or main lug.
So by the NEC the panelboard is the "Guts". And all codes about Panelboards is only referring to what is inside the cabinet or cutout box, which is the code language for back box or tub.
Cabinets and cutout boxes have a whole different code section.
<<<< CHIP ME >>>>Not
Old 05-23-2020, 09:05 AM   #13
Rewards Points: 1,609
The term “load center” confuses me so I never use it.
Old 05-23-2020, 09:27 AM   #14
From the Eaton website...
What is the difference between a loadcenter and panelboard?
There is no difference as far as UL and the NEC are concerned. Eaton offers "loadcenters" as we call them which are panelboards that are targeted to the residential markets and are consider a lower cost version of a panelboard for that market. Typically the loadcenter has plug in type breakers that are required compared to panelboards that allow for bolt on breakers... A panelboard is typically used in a commercial or industrial application. Panelboards have a can, interior and trim. The can is installed at rough in and the interior later. Loadcenters are limited to 240V or less and max at 400A. all these consideration come into play and unless the specs have specific requirements that define the panelboard further, A loadcenter or panelboard as we define it can be offer if it meets the application and spec.
http://trcsupport.eaton.com/Resident...panelboard.htm
So in the original post my question was more about an MLO vs a Main Breaker (Service Entrance) not load centre vs panelboard; in the CEC the only definition is Panelboard and Service Box, no definition for load centre or just panel (MLO, SE, etc)
Cheers
John
iamsparky, 99cents, splatz and 1 others like this.
Old 05-23-2020, 09:48 AM   #15
Light Bender
eddy current's Avatar
Rewards Points: 8,034
Anytime I needed a panel without a main breaker, I got one with a main breaker anyway. The ones without a main seem to be more expensive than the ones with.
electricguy, Navyguy and RRF like this.
Old 05-23-2020, 02:44 PM   #16
Cheers
John
If you need a main lug panel, why not buy a 200a? They will be a stock item vs a special order item.
Navyguy and Kevin_Essiambre like this.
Old 05-24-2020, 09:54 PM   #17
The only time I buy an MLO panel is when I need to access the tub from both ends or from the same end the feed is in. This is mostly apartment / condo panel changes where you don't need the separate disconnect (service disconnect) in the panel.
Cheers
John
Old 05-25-2020, 04:54 AM   #18
Rewards Points: 857
I've installed a CQO160M100PC 100A 60 space, main breaker panel.
Old 05-26-2020, 10:56 PM   #19
Rewards Points: 36
Cheers
John
Hi John. In Residentail dweling unit in Ontario, can we use Eaton (CMP130RETAF OR CMPRETVA)100 amps service entrance load centre as sub panel (Bonding screw to neutral removed) and apply label Main Disconnect at sub panel main breaker which comes with package as per Eaton instruction - see attached pic , when we have 200amp Eaton (CMP240RETAF) as Service Entrance Panel. As all 3 panels mentioned above are labeled as Service Entrance load centre.
iamsparky is offline   Reply With Quote
Old 05-26-2020, 11:09 PM   #20
Light Bender
Most of the pony panels I have installed were service rated and came with a main breaker. Like I said earlier, they are usually less expensive than a panel without a main.
Navyguy and iamsparky like this.
