Is NEMA Twist Lock 60A IP56 Receptacles available? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 4 Post By quick_2
  • 2 Post By ppsh
Old 09-11-2019, 06:19 PM   #1
Rewards Points: 6
Default Is NEMA Twist Lock 60A IP56 Receptacles available?
Hi,
I am working in a project for ship building and the customer required receptacles with the following specs:
• 440V/60A, 3PH + Ground
• Flange Mounted
• NEMA Twist Lock Type Blade Configuration
• Threaded end caps to keep receptacle clean and dry when not in use. Caps shall be tethered to the receptacle flange mount
• IP56 Rated
According to the NEMA chart for receptacles, there are no receptacles available could meet the requirement for NEMA Twist Lock Blade Configuration at 60A and also IP56 rated.
Anyone know if this spec is feasible? If possible, please specify the Model Number (s) of the Receptacles.
Thanks.
HenryPham is offline   Reply With Quote
Old 09-11-2019, 08:21 PM   #2
Journeyman
Rewards Points: 200
Pin and Sleeve.
http://www.cooperindustries.com/cont...e_devices.html
Navyguy, glen1971, J F Go and 1 others like this.
quick_2 is offline   Reply With Quote
The Following User Says Thank You to quick_2 For This Useful Post:
HenryPham (09-12-2019)
Old 09-11-2019, 10:29 PM   #3
ppsh's Avatar
Rewards Points: 118
Meltric DSN-60
ppsh is offline   Reply With Quote
The Following User Says Thank You to ppsh For This Useful Post:
Old 09-12-2019, 12:10 PM   #4
Rewards Points: 6
[quote=quick_2;5239388]Pin and Sleeve.
Thanks
Old 09-12-2019, 05:12 PM   #5
Rewards Points: 6
[quote=HenryPham;5239678]
Originally Posted by quick_2 View Post
Pin and Sleeve.
Thanks
But there is a requirement for the twist-lock and all the above recommendation is for Pin and Sleeve only.
Old 09-12-2019, 11:15 PM   #6
ppsh's Avatar
Rewards Points: 118
Engineer is smoking crack. Pin and sleeve is your only option.
Specs exist for NEMA 60a twist locks, however AFAIK they are not produced, for good reason too. They will self destruct in short order when opened under load, especially with the arcs at 480v.
Navyguy and Kevin_Essiambre like this.
Old 09-13-2019, 01:31 AM   #7
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 242
Originally Posted by HenryPham View Post
•NEMA Twist Lock Type Blade Configuration
•Threaded end caps to keep receptacle clean and dry when not in use. Caps shall be tethered to the receptacle flange mount
I've never heard of nor seen a twist lock with threaded caps...
You'll be using pin and sleeve.
Old 09-25-2019, 01:06 PM   #8
Rewards Points: 84
The Meltric one is commonly used ship/shore at my workplace.
u2slow is offline   Reply With Quote
Old 09-25-2019, 02:10 PM   #9
Rewards Points: 4,944
I have never seen one before either... these are "non-nema" type...
http://www.cooperindustries.com/cont...ower_lock.html
http://www.cooperindustries.com/cont.../AHBG-C-72.pdf
Cheers
John
Old 09-26-2019, 11:09 PM   #10
billyhunter's Avatar
Rewards Points: 218
Either Pin & Sleeve, or Cooper Crouse Hinds Arktite
https://www.bulbspro.com/electrical/arktite.html
billyhunter is offline   Reply With Quote
