Non mast overhead house service - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree30Likes
Old 04-15-2019, 01:53 PM   #21
Rewards Points: 2,884
I have never had an issue getting a coupling on a cut 90. PVC cement is slippery (if only for a few seconds ).
I went to my supplier once and asked for a PVC 45 and he looked at me like I was from outer space. He said everybody just cuts a 90 in half. I have done it that way ever since.
I wouldn't think that would work, you'll be slipping the coupling on a curved piece not a straight piece.
Old 04-15-2019, 02:02 PM   #22
Rewards Points: 462
You could hammer a square peg into a round hole with a big enough hammer.
And up there they only have snow, not rain. So they don't have to worry about the riser being sealed.
Old 04-15-2019, 03:04 PM   #23
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 472
Hydro one doesn't even install a weatherhead on PVC conduit runs... after many years the conduit will fill with water... That's what the drain holes are for in the meterbases.
Vote Kevin for Moderator!
Old 04-15-2019, 03:14 PM   #24
Rewards Points: 3,029
I guess rain falls up in NJ.
Old 07-07-2019, 11:33 AM   #25
billyhunter's Avatar
Rewards Points: 218
I use ACWU cable for service without mast and hot PVCBOOTS to shrink all wires, I passed inspection.
billyhunter is offline   Reply With Quote
Old 07-07-2019, 11:50 AM   #26
Knotted Ropes Skeery
CoolWill's Avatar
Rewards Points: 2,100
I have never seen a Poco-installed transition to underground that had a weatherhead. All their PVC is open. I guess they rely on the fact that their installers probably just dry fit it.
The only weatherheads I see on pole risers are the risers installed by an EC.
Kevin_Essiambre likes this.
Old 07-07-2019, 12:04 PM   #27
Rewards Points: 21,898
I put weather head on the pole only if the UG riser or conduit is higher than the meter or pad transformer. but otherwise I dont bother with it . the reason why sometime you will see a water coming out like a guyser especially after heavy rainstorm or moonson season in my area .
Old 07-07-2019, 01:19 PM   #28
Rewards Points: 60
That must depend on the POCO. Whenever we have to provide the wire and cable for up the pole we need the weatherhead as well.
Sent from my XT1650 using Tapatalk
Old 07-07-2019, 01:28 PM   #29
CoolWill's Avatar
You still installed it. I'm speaking of conduit installed by the utility.
Old 07-07-2019, 01:37 PM   #30
Rewards Points: 60
Actually not. This is for on the pole. The most we do is one stick up the pole and leave the rest there for them to do.
Old 07-07-2019, 04:00 PM   #31
Rewards Points: 3,096
About poles in BC if you only use 1 stick of pipe and there is still 5 ft of pole left it will fail . AHJ wants the full height of the pole used or use a shorter pole. He doesnt like to hear well i only have a ladder the will only reach that height.
Old 07-07-2019, 06:39 PM   #32
Here tha thing .,, if that is on Hydro pole I would tell the AHJ pound sand after they read the specs what Hydro want
I know what I always in my area and my POCO approved my methold is just slap a full stick and let POCO make their own termation on the uility side.,,
and I am not too keen to stand under 14.4 KV lines that why only one stick and be done with it.
Old 07-07-2019, 06:43 PM   #33
RSE Master Electrician
Incognito's Avatar
Rewards Points: 954
Around here (Ontario) the electrician only installs one length of conduit, but they have to supply all the materials (conduit, straps, screws, weatherhead ) for the whole service. the utility installs the rest
2018 Canadian Electrical Code
Old 07-07-2019, 07:11 PM   #34
spinninwheels's Avatar
Rewards Points: 1,197
The utility installs the conductors then and terminates in the meter base?
life is a wild adventure or nothing - helen keller
spinninwheels is offline   Reply With Quote
Old 07-07-2019, 07:26 PM   #35
Incognito's Avatar
Rewards Points: 954
No the electrician does all the lower work but only runs the conduit and conductors 10’ up the pole if the pole has live wires on it. The utility does all the higher work.
Old 07-07-2019, 07:45 PM   #36
Sounds like I should clarify this would be a customer owned pole I have never seen where we could put metering equipment on a POCO owned pole for a residence
Old 07-07-2019, 10:16 PM   #37
What electricguy said. I didn't realize you could put customer gear on POCO's poles.
Old 07-07-2019, 10:25 PM   #38
Customer owned pole yuh we can install the metering devices but POCO owned post .,, no .,, see below.
Most case the POCO kinda frown on that and they kinda discourge it for good reason due if they have to replace the pole for some reason they have to tear all the stuff off to get the pole replaced.
Only super limited situation then POCO can allowed metering on the pole ditto in my area it super rare our POCO not too keen with it due most of our poles are concrete so that one reason why.,,
the only time I will typically see it is primary metering that about it. anything else it kinda a shot in dark.,,
Old 07-07-2019, 10:29 PM   #39
Rewards Points: 60
It's not installing gear on poles. It running pipe in a ditch over to the pole and then up.
Old 07-07-2019, 10:39 PM   #40
I've seen POCO's secondary poles on the customer's property. Even with Teck or ACWU, still a no go.
Service mast back bracket 99cents Canadian Electrical Forum 63 09-19-2018 11:35 PM
Service mast change out jordandunlop General Electrical Discussion 23 04-23-2016 10:40 PM
overhead service raceway drain dirk103 Canadian Electrical Forum 29 03-18-2016 12:32 PM
Supporting service mast flush mout new construction so cal Dodge47 Residential Electrical Forum 6 02-24-2016 10:33 PM
