Notching stud for two gang box, homeowner is mad. - Page 22 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree401Likes
Old 05-31-2020, 10:46 PM   #421
Rewards Points: 2,827
Originally Posted by mofos be cray View Post
In the interest of bumping the count I'll supplement the OPs question: those of you who said no notch would you change your mind if the framing was different wood? I.e Douglas fir
Steel stud?
I know it’s not wood but what the hell.
Old 05-31-2020, 11:17 PM   #422
Rewards Points: 910
What was the original post about?
Old 05-31-2020, 11:21 PM   #423
Rewards Points: 18
OP notched out a 2x6 in an exterior wall and the carpenter said he'd fail the framing inspection because of it.
mofos be cray is offline   Reply With Quote
Old 05-31-2020, 11:22 PM   #424
Rewards Points: 18
Steel stud?
I know it’️s not wood but what the hell.
I definitely wouldn't notch steel stud.
99cents likes this.
Old 05-31-2020, 11:30 PM   #425
wcord's Avatar
Rewards Points: 2,186
Originally Posted by 460 Delta View Post
We need to steer this back to how only “properly” apprenticed electricians are real electricians, and how ANYONE else is merely a laborer, perhaps with some electrical skills.
to help the post count
Wikipedia
United States[edit]
In the United States, employment in some building trades, such as an electrician, carpenter, plumber, machinist, and HVAC contractor, usually requires holding state or local (city or county) license as a journeyman or master. The license certifies that the craftsman has met the requirements of time in the field (usually a minimum of 8,000 hours) and time in an approved classroom setting (usually 700 hours). A journeyman has the responsibility of supervising workers of lesser experience and training them and has the qualifications (knowledge and skills) to work unsupervised himself. A journeyman is commonly expected to have a wide range of experience, covering most fields of their trade. For example, a non-journeyman worker of some 20 or 30 years' experience may have most or all of their experience in only residential, commercial, or industrial applications. A journeyman, however, has a broad field of experience in residential, commercial, and industrial applications.
Old 05-31-2020, 11:47 PM   #426
JoeSparky's Avatar
Rewards Points: 1,953
If it was mahogany, I would have mortised it and put 3 coats of tung oil and hand rubbed it with bee's wax.
Old 05-31-2020, 11:59 PM   #427
MTW
Rewards Points: 12,010
Hi Joey
Old 06-01-2020, 01:05 AM   #428
Rewards Points: 18
Yeah but what about the framing?
Old 06-01-2020, 01:13 AM   #429
...woke...
cuba_pete's Avatar
Rewards Points: 3,565
In the days of Isaac Newton, conjurers and street magicians who had an interest in electricity called themselves "electricians".
To build a cenotaph, you must first choose a million victims
Old 06-01-2020, 02:04 AM   #430
Conductor Protector
Funksparky's Avatar
Rewards Points: 70
When I work in Massachusetts, most towns have adopted a the "stretch" energy code. I don't have the full details, but it has to do with limiting the amount of air movement between inside and outside.
I, for the most part do not work for GCs. When I am bidding a job for the owner, I ask them if they are using fiberglass or spray foam for insulation in the walls/ ceilings. If they are spray foaming, I price for and use cheap Carlon or P&S nail on boxes. If they are using fiberglass, I price and use T&B vapor tight boxes on all the walls/ceilings facing in walls opposing unheated spaces. Even when the stretch code is not involved, I explain the benefits to them to the homeowner and tell them they are a bit more expensive, but worth it.
How many of us with cold winters have replaced outside wall outlets and found the homeowner installed those useless foam gaskets behind the plates to try and stop the drafts through them. A Vapor tight box and a little squirt of closed cell behind them in a 2x4 wall before they fiberglass makes a big difference on a cold/windy day
Heyyyy! What the heck? those boxes don't have any bonding strap in them!!!!
Funksparky is offline   Reply With Quote
Old 06-01-2020, 02:07 AM   #431
Conductor Protector
Funksparky's Avatar
Rewards Points: 70
Wow what a long thread
Old 06-01-2020, 02:10 AM   #432
pjones is offline   Reply With Quote
Old 06-01-2020, 05:46 AM   #433
Rewards Points: 2,782
You do realize you don't have to serve any kind of apprenticeship to post on wikipedia, don't you?
Wikipedia
United States[edit]
The more you know, the less you need.
Old 06-01-2020, 05:51 AM   #434
Every single one of you Canadians should thank your lucky stars that I never served an apprenticeship. I am just short of Dr. Evil capabilities without it, with an apprenticeship would have put me over the top. I'd certainly be running this country by now and if I was running this country, you'd be the 51st state, Canaducky, or maybe Canasee. You'd be getting robbed of your resources and bled for cheap labor and tax base by our major metropolitan areas, marginalized and frustrated. Almost all of you would be holding your nose and voting for Trump.
HackWork, 460 Delta and CoolWill like this.
Old 06-01-2020, 07:02 AM   #435
Huh? Don’t touch your face!
Old 06-01-2020, 07:09 AM   #436
Knotted Ropes Skeery
CoolWill's Avatar
Rewards Points: 1,652
I'd like to see them become a state. The fourth state... of matter.
Old 06-01-2020, 08:23 AM   #437
JoeSparky's Avatar
Us electricians in the US don't need to "bond" a plastic box There are silly bare and green wires run in the cables that you hook to the little green screw on the device. Sounds dangerous and complicated, Huh
Old 06-01-2020, 08:28 AM   #438
You’re dangerous and complicated.
JoeSparky likes this.
Old 06-01-2020, 08:30 AM   #439
Rewards Points: 5,712
Topping tonight's news, fire in Buffalo, fire in Lackawana, fire in Amherst, etc, etc, etc
Cheers
John
Old 06-01-2020, 08:32 AM   #440
The winner of post #500 wins a pair of very nice wire twisters (which may or may not be Milwaukee linesman’s pliers with fried cutting edges). Shipping and handling not included.
