Number of conductors in a cable - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
Old 06-27-2016, 08:23 AM   #1
Rewards Points: 11,459
Default Number of conductors in a cable
I was at the local wire bandits buying some underground cable last week and the dude there said even Master Electricians have problems with this. The number of conductors in a cable always refers to insulated conductors. If you have a red, black, white and bare ground, for instance, it's three conductor. If you have a red, black, white and green, it's a four conductor.
I always specify exactly what I want. Cable is too expensive to screw it up.
Anyway, that's what happened last week. It wasn't a particularly eventful week .
Old 06-27-2016, 08:29 AM   #2
zac
Rewards Points: 816
The ground is insulated in this bundle.
zac is online now   Reply With Quote
Old 06-27-2016, 08:30 AM   #3
Rewards Points: 421
The only time you count the ground is in SJ cord, for some strange reason.
glen1971 (06-27-2016)
Old 06-27-2016, 08:31 AM   #4
zac
Rewards Points: 816
Maybe the thought is that if it's insulated it could be used as a hot wire?
Old 06-27-2016, 08:36 AM   #5
See, it IS confusing .
Old 06-27-2016, 08:40 AM   #6
zac
Rewards Points: 816
I think that dude was confused. I've never heard the ground counted in Mc cable.
MechanicalDVR and HackWork like this.
Old 06-27-2016, 08:46 AM   #7
Maybe it's Canadian. We don't have MC up here. What's the difference between MC and AC90?
zac likes this.
Old 06-27-2016, 08:50 AM   #8
Bird dog's Avatar
Rewards Points: 1,332
It is confusing if you don't deal with it every day. Make yourself a cheat sheet. You can't return cut wire and you don't want to get to the job and realize you should have asked for 12-4 MC instead of 12-3 MC. I know it's a pain but the time you don't check the order it will bite you in the rear.
99cents (06-27-2016)
Old 06-27-2016, 09:40 AM   #9
canbug's Avatar
Rewards Points: 1,510
MC and AC-90 are the same thing, BX. Yes in Canada, the only time you include, count the ground is in cab tire.
Tim.
Old 06-27-2016, 09:44 AM   #10
canbug's Avatar
Kind of funny, I deal almost exclusively with ASLC at work and it is a single conductor #8 unshielded and ungrounded.
ASLC- Airfield Series Lighting Cable.
Tim.
The Following User Says Thank You to canbug For This Useful Post:
Vintage Sounds (07-02-2016)
Old 06-27-2016, 09:59 AM   #11
Tim.
Which makes sense since cab tire has an insulated ground.
Old 06-27-2016, 11:19 AM   #12
Rewards Points: 1,162
Tim.
AC in this country is the same as BX. AC stands for armored cable and has a steel jacket while MC has an aluminum jacket that is much lighter than AC cable. I have not seen ac used around my area any more...
Old 06-27-2016, 11:20 AM   #13
AC never had an equipment grounding conductor either.. Maybe now it does but the jacket was used as the equipment grounding conductor along with a tiny steel wire strip that was run inside the armor
Old 06-27-2016, 11:22 AM   #14
Rewards Points: 421
Are you sure about that? I thought they made AC lite with aluminum sheath?
Old 06-27-2016, 11:25 AM   #15
canbug's Avatar
That's the difference, AC-90 up here is an aluminum sheathed single or multi conductor cable. In Canada, you can not buy it without the ground. The old cable used a flat aluminum ribbon as ground.
I'm sure you can get steel flex but honestly everything I order comes aluminum, even a 4 inch.
Tim.
Old 06-27-2016, 12:00 PM   #16
Bird dog's Avatar
I used some stuff (2000-03?) thought it was AC that had an bare aluminum wire. It was supposed to be wrapped back on the corrugated aluminum sheathing. The insulated conductors were copper with an insulated ground. I prefer MC with the proper connectors.
Old 06-27-2016, 05:39 PM   #17
Rewards Points: 7,520
AC-90 has a bare ground.
MC has an insulated green.
Old 06-27-2016, 05:46 PM   #18
Yes , I've made that mistake.
Refering to insulated conductors only works great in Canada cause our 2 wire BX (AC-90) has a bare copper ground conductor.
2 wire MC on the other hand has an insulated ground. Used in the US.
Old 06-27-2016, 06:39 PM   #19
I am not sure but that was the way ac or bx used to be. I have not seen AC cable in 20+ years
Old 06-27-2016, 06:41 PM   #20
Rewards Points: 2,973
Other multiconductor cables also count the green. Lapp cable, control cable, that sort of thing.
AK_sparky is offline   Reply With Quote
No MC Cable Bushings swimmer Commercial Electrical Forum 32 07-04-2016 05:47 AM
Conductor Electek inc General Electrical Discussion 25 05-04-2016 11:02 PM
Cable strain relief - extreme conditions chrisfnl General Electrical Discussion 16 04-23-2016 07:02 AM
Part number for Zelio cable althecontrolguy PLCs, VFDs, Motors and Controls 3 04-11-2016 10:13 PM
stove cable max length oscar sparo General Electrical Discussion 0 03-21-2016 02:53 PM
