Odd mast size - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
Old 06-26-2019, 10:33 AM   #1
Rewards Points: 6
Default Odd mast size
I haven't done much residential stuff recently but am working on a service upgrade from 100 to 200amps for someone. The thing I've run into is they have a 3" EMT mast that I can't seem to find any parts to fit aside from a weatherhead. Has anyone run into a mast this size? I think the weatherhead is good for 200amps, but there's a reducer on the bottom to 1-1/4" into the old meter box. Does anyone know if I can re-use that reducer, or do I have to replace it with 2" (which I can't find for 3" EMT)? I'd rather not replace the mast if I can re-use it.
skruffy is offline   Reply With Quote
Old 06-26-2019, 11:03 AM   #2
sbrn33's Avatar
Rewards Points: 3,238
This should be fun.
I have been looking for a 200 amp weatherhead for a long time. Where did you find it.
Bird dog likes this.
Old 06-26-2019, 12:43 PM   #3
CoolWill's Avatar
Rewards Points: 1,998
3" parts can be found at any electrical supply.
glen1971 likes this.
I'm With Her! Hillary 2016
Old 06-26-2019, 01:14 PM   #4
Rewards Points: 201
This should be fun.
Right next to the 200A pipe.
Old 06-26-2019, 01:35 PM   #5
CoolWill's Avatar
Is that near the "220 wire"?
Old 06-26-2019, 02:02 PM   #6
Rewards Points: 201
It's 240V
There is no such thing as 220V wire
JoeSparky and glen1971 like this.
Old 06-26-2019, 02:29 PM   #7
Rewards Points: 3,676
I hear that RE86's are also on the endangered species list..
Old 06-26-2019, 05:46 PM   #8
Rewards Points: 6
Sorry guys, I get it, I haven't explained it very well.
The conduit isn't threaded. I'm used to seeing a MM200M. Is there anything in the code book that says I can't reduce to 1-1/4" prior to the meter box? For that matter, I can't find anything in the code book that specifies the required mast size. Or is that a Manitoba Hydro specific thing.
Old 06-26-2019, 06:40 PM   #9
Rewards Points: 16,778
I have one question reguarding the EMT conduit .,, where is the POA ? is on the conduit or it on the building ?
And it is poked thru the roof ?
Old 06-26-2019, 07:36 PM   #10
Small Potatoes
flyboy's Avatar
Rewards Points: 3,442
It's 240V
220 / 221 whatever it takes.
“Money doesn’t always bring happiness. People with ten million dollars are no happier than people with nine million dollars.”
~HOBART BROWN
Old 06-26-2019, 07:40 PM   #11
wcord's Avatar
Rewards Points: 1,518
Are you measuring the OD @3" ? If thats the case, then the ID is 2.5 which is a standard mast. If thats the case, a MM202 head is what you want
You'll have to go up to a 2" bottom reducer to allow for the wire size
Old 06-26-2019, 07:46 PM   #12
RSE Master Electrician
Incognito's Avatar
Rewards Points: 602
Yes you must follow conduit fill rules 12-910.
200 amp conductors are too big for 1-1/4” conduit.
Also masts must be a minimum 63mm.
6-112
5) Where service masts are used, they shall be of metal and assembled from components suitable for service mast use.
6) Rigid steel conduit of a minimum nominal size of 63 trade size shall be permitted to be used for the purpose of Subrule 5), provided that all other requirements for a service mast are complied with.
2018 Ontario Electrical Code
Old 06-26-2019, 08:46 PM   #13
Band Member
emtnut's Avatar
Rewards Points: 790
An EMT mast ??
Whud I missin' here
Old 06-26-2019, 09:09 PM   #14
Rewards Points: 1,153
Originally Posted by emtnut View Post
An EMT mast ??
Whud I missin' here
It's probably just a scrap of EMT on the bottom. 2.5" EMT and GRC are both the same OD. Even with the cost of the compression fittings, It's still usually cheaper to extend a mast over 10' in EMT
Old 06-26-2019, 10:19 PM   #15
Small Potatoes
flyboy's Avatar
An EMT mast ??
Whud I missin' here
Yeah, I was thinking the same thing. I'm betting it's not a mast, just a riser. Here in the states it's either GRC or IMC for a mast.
~HOBART BROWN
Old 06-26-2019, 11:22 PM   #16
Rewards Points: 6
My bad guys. You had me wondering and eyeballing with a tape measure wasn't quite accurate. I popped the cap off an measured with calipers. ID is 2.75", OD is 3" so I'm really not sure what it is. Cap and reducer fit just right though. This stuff is older than I am.
I can get away with 3/0 copper in 1-1/4" pipe as per local inspectors. It'll be snug.
I tried posting a pic but it's not going. Link available: imgur.com/a/CcA202K
Old 06-27-2019, 01:26 AM   #17
Rewards Points: 15,817
Scruffy, YOU GO HIRE AN ELECTRICIAN. He will tell you what he is going to buy when he puts up your new mast.
Old 06-27-2019, 01:32 AM   #18
I've done some where I left the meter can with 2" emt, and ran the last ten up thru the rooftop with GRC conduit. But of course, you can't screw an EMT box connector into a GRC coupling cause it makes Incognito get Diarrhea. So forget I said I did it, I didn't really did it, I was joking and making it up. Everybody know's you can't screw an emt box connector into a grc coupling . Everybody knows. ..............
Best part: instead of those pricey "rain tight" emt couplings I went to Hardware Hawaii and found the right size o rings to slip up next to the compression couplings and siliconed em in place real nice. Inspector saw the o rings and complemented me for using proper raintite fittings.....lol.
Old 06-27-2019, 08:04 AM   #19
Incognito's Avatar
Rewards Points: 602
You can screw a male metal into a female metal or plastic. It’s the male plastic into female metal that causes dysentery
Old 06-27-2019, 08:24 AM   #20
Rewards Points: 11,369
An EMT mast ??
Whud I missin' here
I dunno. It’s one of those things that’s so obviously wrong I thought maybe it was right.
