Procedure to determine if NMD 90 exposed to flood damage needs to be replaced. - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
Old 01-31-2020, 07:51 AM   #1
Default Procedure to determine if NMD 90 exposed to flood damage needs to be replaced.
Hi I've been a quiet observer in the forum. I am a Red Seal Journeyman in Alberta, pretty green still as I've had my ticket for just over 2 years and 6 years in the trade. I am currently working for a renovation crew, and we are doing disaster recovery for a hotel that suffered severe water damage. A 4 inch pipe burst in the attic, and damaged all 6 floors. This happened just over a week ago. My question is how do I determine if the loomex needs to be replaced. I have done some Megger tests and so far got very good readings for everything I've tested, even circuits where the wire feels damp to the touch ( jacket) and the ends are starting to show corrosion. Side note this is a very new installation, hotel opened a couple of months ago. Any help and advise is greatly appreciated!
sparky84 is offline   Reply With Quote
Old 01-31-2020, 09:52 AM   #2
Rewards Points: 2,824
There are some materials on this subject from the US FEMA, the federales that respond to flood disasters and all that.
The big problem is if the cable is submerged where the jacket is open. The paper insulation wicks the water up. If there are boxes below the waterline, those cables probably have to be replaced.
(I am not sure why this matters from an electrical perspective because the conductors in the NM these days are rated THHN / THWN - they're OK for wet locations and would be OK in conduit that has water laying in it for years.)
There's no problem with the usual exposure to the elements you have when under construction, even leaving NM unterminated for months in a half finished house, passes. I don't know how much worse this flood was than rainfall type exposure.
FishinElectrcian likes this.
sparky84 (01-31-2020)
Old 01-31-2020, 10:12 AM   #3
joe-nwt's Avatar
Rewards Points: 2,348
By chance was it part of the Nova chain?
joe-nwt is online now   Reply With Quote
Old 01-31-2020, 10:22 AM   #4
Rewards Points: 18
Canada doesn't use paper in nmd.
Gnome and Kevin_Essiambre like this.
mofos be cray is online now   Reply With Quote
Old 01-31-2020, 10:46 AM   #5
Rewards Points: 21,657
So they let you guys up there wire non metallic sheathed cables in 6 floor construction? This would not have been the case down south.
five.five-six likes this.
I stand with Tucker Carlson
Old 01-31-2020, 12:18 PM   #6
joe-nwt's Avatar
I find it hard to believe water could damage NMD90. It's plastic. Devices, on the other hand, could get corroded. Strip some clean wire for new devices where needed and call it a day.
Old 01-31-2020, 12:38 PM   #7
FishinElectrcian's Avatar
Rewards Points: 122
Well nmd is rated for damp locations.. There could be an issue if it was fully submerged for a period of time but it sounds like short duration. I worked on a condo when the Bow river overflowed and the Electric room was fully or at least 5' deep in water for a week. That was bad.
I'd say visual inspection and if you want to take it further megger a few wires. Replace any devices that were submerged and check any splices. The stuff in wall is pretty safe just where the jacket is cut open that I might worry but I'm not worried.
FishinElectrcian is offline   Reply With Quote
Old 01-31-2020, 01:00 PM   #8
canbug's Avatar
Rewards Points: 2,136
When Calgary had the flooding back awhile ago, insurance company's made it very clear that devices(of course) and panels needed to be changed out but as far as I know, all the wire stayed and a lot of that was under for a week.
Tim.
canbug is online now   Reply With Quote
Old 01-31-2020, 01:53 PM   #9
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 470
Yup. My brother just finished a 6 story hotel that is ICF and wood framing with NMD cable.
Vote Kevin for Moderator!
Old 01-31-2020, 02:06 PM   #10
Thanks guys, kind of along the lines of what I was thinking. Interesting to hear that even when submerged in water the NMD 90 may still be good. What about device boxes? I'm concerned about rust...
Old 01-31-2020, 02:10 PM   #11
Rewards Points: 26,874
The actual issue is not electrical -- it's MOLD.
Mold destroys the economic value of a building.
The trade even has an alphabet for it: WDB -- a Water Damaged Building.
Folks can't live around a WDB.
Without paper in the composition, you're probably in good shape.
Inspect, first, where you'd expect the worst conditions to have occurred.
Meg everything every which way. -- Remove loads, of course.
Get the EEs and Inspectors to sign off -- INCLUDE the health inspector.
Take swabs and have them tested by expert labs -- yes these exist -- and they issue test kits.
I'd expect that the sheet rock is ruined all over the place. So you can do your 'thing' with naked walls.
Sheet rock will wick up ruinous amounts of water in no-time flat.
Old 01-31-2020, 02:11 PM   #12
Not Nova lol
Old 01-31-2020, 05:53 PM   #13
Yeah that's exactly like this one, hate cutting raceways in the ICF
Old 01-31-2020, 06:03 PM   #14
Beam Me Up Scotty
Rewards Points: 470
I hear a hot knife is the perfect tool for this...
Old 01-31-2020, 07:35 PM   #15
Bleddyn's Avatar
Rewards Points: 52
Found this when I was researching flood damage a while back. May be worth the read.
https://www.nema.org/Standards/Pages...Equipment.aspx
Bleddyn is offline   Reply With Quote
The Following User Says Thank You to Bleddyn For This Useful Post:
splatz (02-01-2020)
Old 01-31-2020, 08:49 PM   #16
Rewards Points: 5,734
This is from Ontario, but I suspect everybody pretty much has the same.
Cheers
John
Old 02-01-2020, 03:38 AM   #17
That's an excellent resource, thanks for posting.
https://www.nema.org/Standards/Secur...ment-Guide.pdf
Old 02-01-2020, 06:34 AM   #18
wcord's Avatar
Rewards Points: 2,188
Get a cheap electric chain saw👍
The cut is the right size to hold NMD.
Just be prepared to use a broom afterwards
( Dont let anyone see you sweep up, That would give electricians a bad name)
Old 02-01-2020, 09:30 AM   #19
Knotted Ropes Skeery
CoolWill's Avatar
Rewards Points: 1,876
Depends on the construction type classification. The "3 stories rule" was removed from the NEC several cycles ago.
Old 02-03-2020, 09:30 AM   #20
canbug's Avatar
Last week Calgary AB is allowing wood structures as high as 12 stories.
Tim.
Kevin_Essiambre likes this.
