PVC pipe close to chimney . - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 1 Post By Navyguy
  • 1 Post By oliquir
  • 1 Post By 99cents
  • 1 Post By Navyguy
Old 02-06-2018, 09:34 PM   #1
Rewards Points: 50
Default PVC pipe close to chimney .
Hi everyone. I need to move a panel but the problem is chimney. There is no way to pass this chimney and i wondering is any rules about how close service pipe can run along chimney. Panel has to go 7-8 meters left . Thanks
yarik is offline   Reply With Quote
Old 02-06-2018, 09:54 PM   #2
Rewards Points: 5,334
I see two options (while not knowing how close the pipe is to the wall)...
1. Use rigid conduit;
2. Install a disco at the current location and run #3/3 inside to the new panel location.
To be realistic, I think that if that pipe got over 90*C there would be bigger problems then the service conduit being too close.
Cheers
John
Old 02-07-2018, 09:22 AM   #3
Rewards Points: 317
Can you not go underground from the meterbase and come back up when you get past the chimney?
silver50032000 is offline   Reply With Quote
Old 02-07-2018, 09:25 AM   #4
Rewards Points: 2,094
this is an insulated chminey, you just need 2" clearance from combustible materials
51360 likes this.
oliquir is online now   Reply With Quote
Old 02-07-2018, 09:27 AM   #5
Rewards Points: 26,782
Pardon me, but how is it that the co-ax cables survive the transit ?
Yeah, it doesn't look like you have any other issue than getting on by.
Old 02-07-2018, 09:37 AM   #6
Rewards Points: 15,269
Cheers
John
EMT maybe. Thinner OD, bigger air gap.
Navyguy likes this.
Old 02-07-2018, 09:57 AM   #7
Light Bender
eddy current's Avatar
Rewards Points: 7,938
Curious, is Hydro requesting you move the new meter base as well?
You only need 1 meter as per 2-324, but it is hard to tell how far the meter is from the gas in the pic.
Old 02-07-2018, 10:49 AM   #8
I am finding that the utility is less concerned with the meter location now that smart meters are pretty much everywhere.
It might be easier to get the utility to approve the relocation of the meter socket past the pipe (not knowing how high it goes) assuming this is a mast that goes through the roof.
Cheers
John
Old 02-07-2018, 12:18 PM   #9
Rewards Points: 7,787
Move the chimney.
Old 02-07-2018, 05:07 PM   #10
Rewards Points: 50
Problem solved, owner wants to get gas fireplace and get rid of the chimney ....anyway it would be a good challenge . thanks everyone for your replies
Old 02-07-2018, 10:05 PM   #11
Rewards Points: 330
Cheers
John
What is the reasoning for this? Is it because the always live feeders will be in the house for a longer than normal distance?
Canaduh is offline   Reply With Quote
Old 02-07-2018, 10:25 PM   #12
Rule 6-206(1)(c) and 6-208 and Bulletin 6-1-15.
Cheers
John
Canaduh likes this.
The Following User Says Thank You to Navyguy For This Useful Post:
Canaduh (02-07-2018)
Old 02-07-2018, 10:50 PM   #13
Rewards Points: 330
Cheers
John
Thank you John. I still dont see the need for a disconnect on the outside if the code states 7.5m of unfused conductors can be in the home if in rigid or emt.
Also in regards to the bulletins, would you know how to set up some sort of notification for any new ones being released? Or do we have to just keep checking for updates? I didn't know there was an updated list since I last checked in March 2017.
Old 02-08-2018, 12:41 AM   #14
The disconnect would go inside where the existing panel is now.
I just keep checking the ESA website, I don't think there is a notice announcement... but don't remember.
Cheers
John
NM-B Thru Studs Enclosing Chimney Assembly swimmer NEC Code Forum 0 11-30-2017 11:09 AM
Shot in the dark regarding pipe routing quarky2001 General Electrical Discussion 9 08-11-2017 10:29 PM
Receptacle for TV mounted in chimney brick Sparkykaboom Canadian Electrical Forum 12 04-20-2017 08:12 AM
6-3 Non-Metallic Wire; close to gas pipe and HAVC ductwork...SAFE? orange315 NEC Code Forum 12 03-25-2017 05:55 PM
Pipe fill ElectricalArtist General Electrical Discussion 10 08-22-2016 06:33 PM
