Is PVC underground considered a wet location? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 2 Post By frenchelectrican
  • 3 Post By wcord
  • 1 Post By emtnut
  • 1 Post By PlugsAndLights
Old 10-06-2016, 09:50 AM   #1
Rewards Points: 330
Default Is PVC underground considered a wet location?
Is PVC underground considered a wet location and where can I find the definition of a wet location in the code book?
I am asking because I have always thought RWU had to be installed underground but some guy at work says TWN can be installed underground because the W stands for wet location and underground is considered a wet location.
Table 19 is pretty clear in that direct earth burial has to be TWU, RWU, NMWU, Teck90
Canaduh is offline   Reply With Quote
Old 10-06-2016, 10:00 AM   #2
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,820
Yes! Water gets into underground pvc.
Old 10-06-2016, 10:07 AM   #3
Rewards Points: 330
So TWN can be installed underground?
Old 10-06-2016, 10:46 AM   #4
Rewards Points: 21,898
It is because the PVC conduit in the ground is wet location because of condation inside the conduit and you will never able to keep the water out of the conduit it will find a way to get in.
Your Table 19 is clear on that but I do not have CEC book with me but I know the other type of conductors it listed is THWN is listed for wet location in conduit. which it will mention very clear in NEC code .
It is simauir wording in my Philippines codes too.
Majewski and PlugsAndLights like this.
Old 10-06-2016, 11:36 AM   #5
wcord's Avatar
Rewards Points: 2,042
Underground is a wet location.
You are correct in the W stands for wet in conduit and U designates direct burial.
Check the jacket and you will see that U cables are much thicker to prevent damage.
51360, Majewski and PlugsAndLights like this.
If you didn’t serve an apprenticeship, you're not a tradesman. You are labor.
Old 10-06-2016, 10:49 PM   #6
Band Member
emtnut's Avatar
Rewards Points: 2,510
You seem to be interchanging U/G PVC and U/G ... 2 different animals
PlugsAndLights likes this.
Old 10-07-2016, 02:16 PM   #7
Rewards Points: 416
In conduit.
mitch65 is offline   Reply With Quote
Old 10-07-2016, 03:21 PM   #8
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
See 12-930(1) and 22-002(a).
P&L
Canaduh likes this.
Old 10-07-2016, 03:40 PM   #9
Rewards Points: 330
Originally Posted by mitch65 View Post
In conduit.
So RWU can be installed underground without conduit? Isn't RWU single conductor wire?
Old 10-07-2016, 04:03 PM   #10
Safety Pin Member
Yes and yes. Single conductors, not just cables, can be installed
underground. It's normal for homes fed underground to have the
3 separate single conductors running in the trench until they
reach directly under the meter base where they enter the PVC
conduit that protects from there up to the meter. Said conduit is
about 80" long if I recall correctly. Screened fill is required in the
trench.
P&L
emtnut likes this.
Old 10-08-2016, 03:58 PM   #11
Byte's Avatar
Rewards Points: 936
12-930(1)?
Byte is offline   Reply With Quote
To get feedback on my prices? Angel Advanced Tech Business, Marketing, and Sales 50 09-02-2016 09:38 PM
Underground cable splicing 51360 Canadian Electrical Forum 10 06-16-2016 10:34 AM
PVC underground kd129 Commercial Electrical Forum 25 06-03-2016 12:14 AM
Canadian Electrical Code 8-104 (8) - underground conductor sizing jjdoerksen Canadian Electrical Forum 7 04-19-2016 03:50 PM
Underground Locating Again. SS&E1852 General Electrical Discussion 16 04-13-2016 09:22 PM
