Thread Tools | Display Modes |
#1 |
Rewards Points: 8
Hello,
I did electrical work in my basement according to the newest code in Ontario. I wired everything up already (switches, light, outlet, panel etc...). The breakers are turned off, but I tested everything already. I will be doing my own drywall as well so the extra work doesn't matter for me. I want to call ESA now to come do inspection before I start the drywall. Will ESA have any problem that I wired everything up already? Thanks |
Join the #1 Electrician Forum Today - It's Totally Free! ElectricianTalk.com - Are you a Professional Electrical Contractor? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's the leading place for electricians to meet online. No homeowners asking DIY questions. Just fellow tradesmen who enjoy talking about their business, their trade, and anything else that comes up. No matter what your specialty is you'll find that ElectricianTalk.com is a great community to join. Best of all it's totally free! |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ElectricianTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 8
Another question (looks like I can't edit my original question).
If I wired switches and outlets, does that mean all switches and outlets have to be screwed into the box or can they just hang (while taped around with electrical tape) for the ESA inspection? |
#3 |
Rewards Points: 12,577
Where I come from, we stuff the wire in the wall after drywall. Otherwise, the wire falls all over the floor and makes a big mess.
Advertisement |
#4 | |
RSE Master Electrician
Rewards Points: 954
![]() Quote:
They will want to see the rough wiring first, as in no devices installed, no power connected, just the rough wiring and bonding connections done. No drywall
2018 Canadian Electrical Code |
#5 | |
Rewards Points: 8
![]() Quote:
I get that, but I already made the connections. |
#6 |
Rewards Points: 954
Take out the permit and call the inspector. They will tell you what they want.
My guess is they will want no power on any of the wiring and the devices not connected to the boxes so they can see all the connections and bonding, but it is up to the inspector.
#7 | |
Rewards Points: 8
![]() Quote:
Thanks |
#8 | |
Electron Pathway Engineer
Rewards Points: 86
![]() Quote:
![]() Simply refer them to contact the local AHJ- that is THEIR job- not yours. ![]()
Opportunities multiply as they are seized. |
#9 | |
Rewards Points: 954
![]() Quote:
Relax bud, I did not tell him how to wire or install anything. I told him he needs to call the inspector and what to expect from that inspector. There are others on other threads that give false and dangerous advice as a joke to DIY’rs. Is that what is preferred to be done here? And if not, why are you not complaining to them and telling them what they should do? onthegravytrain likes this.
#10 |
Rewards Points: 26
Also, to note, it's not illegal for a homeowner to do their own electrical in Ontario, so long as they take out a permit and have it inspected. (i'm not sure about other provinces)
#11 |
This isn’t a DIY site. Period.
The_Modifier and onthegravytrain like this.
The Following User Says Thank You to 99cents For This Useful Post: | The_Modifier (07-17-2019) |
#12 | |
![]() ![]() Join Date: May 2009
Rewards Points: 1,542
![]() Quote:
That is true in many areas of the US also however, we still cannot help with DIY work. The_Modifier and onthegravytrain like this.
They say I shot a man named Gray and took his wife to Italy She inherited a million bucks and when she died it came to me I can't help it if I'm lucky |
The Following User Says Thank You to Dennis Alwon For This Useful Post: | The_Modifier (07-17-2019) |
Thread Tools | |
Display Modes | |
