single conductor between panels - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 1 Post By spinninwheels
  • 1 Post By eddy current
  • 2 Post By 99cents
  • 1 Post By Navyguy
Old 10-01-2018, 10:54 PM   #1
spinninwheels's Avatar
Rewards Points: 1,197
Default single conductor between panels
I was reading another thread, which is now closed, and @99cents made a good point. I had a follow up question, but obviously can't, so hence this thread.
All this talk of portable generators, neutrals, bonds and such got me thinking...
If you're wiring a small gen panel, and you've nippled between that and the main. And you need to extend some ccts, to bring into gen panel. Skinning the sheathing on nmd and extending it to reach new breakers, is a violation - as you should be using single conductor?
Whether it's a chase or close nipple, it's still a raceway, no?
Kevin_Essiambre likes this.
life is a wild adventure or nothing - helen keller
spinninwheels is offline   Reply With Quote
Old 10-01-2018, 11:14 PM   #2
Light Bender
eddy current's Avatar
Rewards Points: 8,138
Yes, still a raceway and technically a violation.
I’ve heard many guys argue that short sections of raceway are not considered a raceway but I have never seen a code that says that.
There is a code that exempts conduit fill rules for short, incomplete sections of raceway that are being used for mechanical protection. 12-910(2)
spinninwheels likes this.
Old 10-01-2018, 11:22 PM   #3
Light Bender
And your also breaking the most misunderstood code in the book, 12-3032(1), using a panel as a junction box for conductors feeding through to other apparatus.
(This is the code that many use for the “no joints allowed in a panel” argument)
Old 10-02-2018, 12:15 AM   #4
Rewards Points: 3,029
I know a guy who knows a guy who stripped out some BX today and stuffed it down a pipe. It may or may not have been about twenty feet. What a hack.
electricguy and spinninwheels like this.
Old 10-02-2018, 12:20 AM   #5
Good point.
Couldn't see the forest for the trees on that one.
Old 10-02-2018, 12:24 AM   #6
I have never been called for using these.
single conductor between panels-screenshot_20181001-222201_samsung-internet.jpg
Old 10-02-2018, 12:27 AM   #7
Just trying to get home
cuba_pete's Avatar
Rewards Points: 3,597
Agree...sounds like a plumber i.e., “Canadian Electrician”
(…lectricien Canadien)
To build a cenotaph, you must first choose a million victims
Old 10-02-2018, 12:27 AM   #8
In the thread that was closed, the guy used #3 NMD between the meter and the panel. That's not bending a rule, it's breaking it.
Old 10-02-2018, 08:28 AM   #9
Navyguy's Avatar
Rewards Points: 5,770
I use them fairly regularly and just did on Friday. Job got inspected and passed no problem. Mine were not 20', but are usually stubs from the drop ceiling. My last one was only a couple of feet, but regardless the same situation.
I have also done the same thing using an Octo box or 4 11/16 box, never been called on that either. Maybe it is like the flush / surface plates; some things are less important then others.
Cheers
John
99cents likes this.
240v 3 phase corner grounded delta and 240v single phase loads snadeau Commercial Electrical Forum 2 08-30-2018 07:28 PM
Geographically Distributed Solar Panels? RePhase277 Alternative Energy Forum 17 11-01-2017 02:50 PM
Swichboard vs distribuition panel vs power panel just the cowboy General Electrical Discussion 4 10-12-2017 09:18 PM
2 meters with 3 panels - 400 amp service ZPelectric General Electrical Discussion 9 09-26-2017 11:46 AM
Requirements for wiring inside electrical panels Anthony666 NEC Code Forum 3 08-22-2016 06:09 PM
