Smallest 200A panel with main breaker - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 1 Post By eddy current
  • 1 Post By splatz
  • 1 Post By wcord
  • 1 Post By 99cents
  • 1 Post By 99cents
  • 1 Post By five.five-six
Old 04-07-2019, 09:17 AM   #1
NDC
NDC's Avatar
Rewards Points: 2,144
Default Smallest 200A panel with main breaker
I'm looking for the smallest possible 200 amp panel with a main breaker AND a cover with a door.
This homeline https://www.nedco.ca/cnd/Category/Di...evPageNumber=1 seems to be the smallest I could find but I cant find the dimensions for the life of me.
anyone know the size of this?
Old 04-07-2019, 02:09 PM   #2
Rewards Points: 7,520
Iím not sure of its size but it looks very small.
Curious why you want a 200 amp panel with such little amount of space for circuits? If itís for a residence that actually needs 200 amps that thing will be jammed full.
I would just make room for a full size panel.
NDC likes this.
Old 04-07-2019, 03:29 PM   #3
Rewards Points: 3,668
True but sometimes a small main panel and a big subpanel with most of the circuits makes sense.
NDC likes this.
Old 04-07-2019, 05:15 PM   #4
wcord's Avatar
Rewards Points: 1,520
According to their catalog, enclosure type 9
14.25 X 29.86 X3.75
NDC likes this.
The Following User Says Thank You to wcord For This Useful Post:
NDC (04-08-2019)
Old 04-07-2019, 05:41 PM   #5
Rewards Points: 11,437
Smallest might be Siemens listed at 27”. The door might be an issue, though (special order?).
I put one in a couple of months ago and it was small but the main breaker compartment still had lots of room.
NDC likes this.
Old 04-07-2019, 08:05 PM   #6
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 416
Homeline is towards the bottom if I recall correctly
Manual
BRINGING RESPECT TO THE TRADES IS IMPERATIVE. DO YOUR PART!
Old 04-08-2019, 08:07 AM   #7
NDC
NDC's Avatar
I plan to install the 200 amp panel in the garage and make their existing main a sub. The 200 amp panel is to feed two car chargers only at full charging rates.
This home is only 3 years old.
The existing ground is a plate buried directly on the outside of the panel under a concrete walkway where the service conduit enters the home. I'll have to pull a ground wire into the existing service conduit which shouldnt be a problem but I would really like to use the existing ground plate to ground the new 200 amp panel which will be about 25 feet away.
I'm assuming I have to use compression type crimp to tie into the ground correct?
I know 2018 OESC says we can use split bolts now but that code takes effect in May. You guys think an inspector would allow the new code rule to fly?
Old 04-08-2019, 08:31 AM   #8
Where is the existing panel? Is it also in the garage? Is there digging involved in upgrading the new service or is it just new wire and conduit from the meter base?
Iím thinking it would be easier to just abandon the old ground and install a new one along with the new service unless the new panel is going in the same location as the old one or close to it.
NDC likes this.
Old 04-08-2019, 08:36 AM   #9
NDC
NDC's Avatar
The existing panel is in the basement no digging required for the new one. The new panel will be in the garage on the opposite side of the meter base.
I was going to re-route the 1-1/4" conduit to the new panel. Installing a new plate means i have to break the concrete walkway.
Old 04-08-2019, 08:37 AM   #10
Rewards Points: 416
That would be up to the inspector, not an internet forum.
Old 04-08-2019, 10:01 AM   #11
I know a guy who knows a guy who would do the work now and pull the permit May 1.
tmessner likes this.
Old 04-08-2019, 01:00 PM   #12
five.five-six's Avatar
Rewards Points: 8,580
Zinsco used to make a really small 200A but that went up in flames.
99cents likes this.
Main Breaker - Miswired or Cross Connection Question priya1 General Electrical Discussion 4 01-18-2019 08:17 AM
Need Second Opinion on Circuit Breaker Panel Brian99 Residential Electrical Forum 6 01-13-2019 08:00 PM
Powering a main lug panel through a breaker? hovelmarkj Other Codes and Standards 7 10-30-2018 11:50 PM
Size feeder for Resi 200A panel. 4/0? - tricky bullheimer NEC Code Forum 15 02-15-2018 02:18 PM
Main Circuit Breaker in Sub-Panel (Again) swimmer NEC Code Forum 166 12-17-2017 04:26 PM
