Thread Tools | Display Modes |
#1 |
Rewards Points: 2,306
So rule 6-212 pretty much states panel boards can't be used as a junction or act as a raceway.
I have an existing outdoor circuit that I want to add to. Does this rule prevent me from adding a wire to the panel and creating a splice that will let me land both wires on one breaker using one wire? I think it should be compliant. Square D breakers accept two wires but this is a Siemens panel. I also have to splice the neutral because I'm installing a dual function breaker. Rule 12-3032(2)(a)(i)&(ii) seems to allow what I plan to do. Any advice would be great. Thanks 6-212 (1) Enclosures for circuit breakers and externally operated switches shall not be used as junction boxes, troughs, or raceways for conductors feeding through or tapping off to other apparatus. From the hand book: Rule 6-212 Wiring space in enclosures Heat can affect the proper sensing of the current passing through the overcurrent device. An externally operated fused switch or a circuit breaker enclosure is normally designed for one conductor per phase terminal and must not be used for conductors feeding through or tapping off to other enclosures/apparatus. Subrule (1) restricts the use of space in a fused switch or circuit breaker enclosure so that only the conductors for that switch or circuit breaker are allowed to enter the enclosure. 12-3032 (1) Enclosures for overcurrent devices, controllers, and externally operated switches shall not be used as junction boxes, troughs, or raceways for conductors feeding through to other apparatus. (2) Notwithstanding Subrule (1), (a) the enclosures identified shall be permitted to be used as junction boxes (i) for all installations where a single feeder supplying another enclosure is tapped from it and the connectors used each provide an independent clamping means for each conductor and each clamping means is independently accessible for tightening or inspection; or (ii) where wiring is being added to an enclosure forming part of an existing installation and the conductors, splices, and taps do not fill the wiring space at any cross-section to more than 75% of the cross-sectional area of the space; and (b) the enclosure identified shall be permitted to be used as a raceway where the conductors are being added to enclosures forming part of an existing installation and all conductors present do not fill the wiring space at any cross-section to more than 40% of the cross-sectional area of the space. From the handbook: Rule 12-3032 Wiring space in enclosures Subrule (1) requires that enclosures for overcurrent devices, controllers, or externally operated switches not be used as junction boxes, wiring troughs, or raceways for conductors feeding through to other apparatus. Wiring space within these devices is usually only large enough to contain the supply and load conductors. Situations that can necessitate a feed-through to other apparatus can usually be avoided by the use of wireways or auxiliary gutters. When an enclosure is supplied with terminal connections that provide individual clamping means for each conductor, Subrule (2) allows a single feeder supplying another enclosure to be tapped from it. For maintenance and inspection purposes, each clamping means must be accessible. Subrule (2) also requires that adequate space be provided in the enclosure to route the conductors so as to prevent undue strain on the terminations and maintain the necessary clearances. When wiring is required to be added to an existing installation, Subrule (2) allows the existing enclosures to be used as junction boxes or as raceways, provided that the conductors, splices, and taps do not fill the cross-sectional area of the space to more than 75% and that conductors run through the enclosure do not fill the wiring space at any cross-section to more than 40% of the cross-sectional area of the space. This exception recognizes the need for the installation of management systems and other similar upgrades that tap into the existing wiring system for monitoring purposes, etc. Apart from the single feeder tap in Subrule 2(a)(i), this exception applies to existing installations only and is not an acceptable practice for new installations in which the design can incorporate the required enclosures for the wiring systems. Last edited by NDC; 08-13-2018 at 11:39 PM. |
Join the #1 Electrician Forum Today - It's Totally Free! ElectricianTalk.com - Are you a Professional Electrical Contractor? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's the leading place for electricians to meet online. No homeowners asking DIY questions. Just fellow tradesmen who enjoy talking about their business, their trade, and anything else that comes up. No matter what your specialty is you'll find that ElectricianTalk.com is a great community to join. Best of all it's totally free! |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ElectricianTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 7,620
This comes up all the time. The key words are “feeding through or tapping off”.
The intent of Those codes are to keep people from using a panel as a j box for wires not associated with it. Also to make sure you don’t exceed the space with joints that are allowed. |
#3 |
![]() Join Date: Jan 2007
Rewards Points: 6,421
Not being able to put a splice in a panel would make a panel change downright difficult. I've done probably hundreds of panel swaps where every circuit was spliced.
One reason not to give DIY advice: Catch a man a fish and you can sell it to him. Teach a man to fish and you’ve ruined a good business opportunity. |
Advertisement |
#4 |
Rewards Points: 342
I was under the impression the CEC and NEC were similar , but it's been a long time since i've had a CEC
Look for the equivelent of 312.8 A&B, or 409.104 (which mentions splices) NDC likes this.
#5 |
Yes I've used wire nuts in panels many times to extend circuits that are short. I have just never had to feed 2 different nmd cables from one breaker within a panel.
#6 |
Rewards Points: 12,445
The loose rule of thumb here is that you can do it as long as you don't go crazy. At one time I think it was prohibited (could have been a provincial thing).
I have pigtailed two cables in a panel before with no problem but, to be honest, my inspectors rarely dig that deep. Aren't you allowed to terminate two conductors on some breakers like QO's (not sure)? My personal rule of thumb is to use a Wago and hide it. If I have a few splices I use an external JB. Last edited by 99cents; 08-14-2018 at 08:43 AM. |
#7 | |
Rewards Points: 2,156
![]() Quote:
99cents likes this.
I'm as Christian as possible in the times we live in. Always just a stallion in a china shop |
#8 | |
Rewards Points: 3,090
![]() Quote:
In the old days, my old days (the 80s), if an inspector seen a junction, he mentioned it, not called it, as he didn't really give a chit unless you had a real mess of them, then he got pissy. Now with all the new technology, like energy management systems and such, this Rule needs a re-look. But, I have also mentioned this often as well. These days, inspectors rarely take off the cover. Legality issues again. ![]() ![]() Borgi canbug likes this.
#9 |
Rewards Points: 26,360
If you've ever seen really old residential panels, the first using circuit breakers, they were so short of wire space it was a crime. They were dimensioned so that they barely took more space than the traditional fuse box... which was a mistake.
Modern panels always have enough space so that the occasional splice off of a breaker is no insult. That's why the rule hangs on. It's for the inspector's discretion, to give him a reason to shoot down a travesty. I've never seen an inspector raise a peep over the matter. |
#10 | ||
![]() Quote:
#11 | |
Rewards Points: 52
![]() Quote:
Not acceptable to have 2 circuit runs (2wires)on one breaker and/or use the cct panel as a junction box! I've replaced panels because of many reasons. If there's no room for that extra circuit run I suggest you either install a sub panel or swap panel to a bigger one.... don't go the homeowners route to save money do it right. |
#12 | |
![]() Quote:
#13 |
Rewards Points: 1,364
Most small generator panels are designed to be spliced in the main panel.
The rules do get a little fluffy as the generator panel is feed from the main panel so the splices are related to the panel until you switch to the generator then technically the splices are no long related to the panel. In a new install this would probably be against code but on a existing install it seems to be covered unless you already have maxed the fill rate for the panel. Makes sense on a new install to run the cables to the transfer rather than splicing them in the main panel. Same as it makes sense to splice them in the main on a existing panel when adding a transfer panel. |
#14 | |
![]() Quote:
A pissy inspector can always use Rule 2-112, and make life miserable for you. In Alberta they don't have the time, probably shake their head and move on. ![]() In life, you are often tempted to do things you don't feel is acceptable, and you are always offered many excuses; "technically allowed by the code", or "the letter of the law allows it", or "it's a shady area but acceptable". I think a junction in a panel looks like chit and is difficult to troubleshoot. If you want your work to be "quality" and your trade treated with respect, I think you have to start somewhere. I start with this Rule! ![]() But, as I type this I realize it's kinda silly for me to be giving life lessons, and extremely difficult to teach your children good moral values and ethics when the Donald Trumps of our world are successful doing exactly the opposite. ![]() Home inspectors are allowed to rape our trade, and every other building trade out there. So, have at it, put an ugly junction in the panel. ![]() ![]() No apologies for the rant! ![]() Borgi |
#15 | |
Rewards Points: 17,211
![]() Quote:
You cannot read forum rules properly , yet you try to lecture others about rules? What a jackass.
Just days before China unveiled a nuclear weapon that can "strike the US within 30 minutes with ten warheads" as part of a giant military parade, US Major General Lori Reynolds announced she's declaring "diversity" is a "warfighting necessity" which will help America defeat the more homogeneous nations of China and Russia. |
#16 |
Rewards Points: 3,424
@Borgi. How are home inspectors "raping" our trade? I do a buttload of work for realtors who rely on home inspectors.
If you are talking about the inspection process maybe but I hate doing home inspections and it just seems better for me to have it come from an independent source. But since I see you are a Donald hater there really is no changing your mind because you like it the way it has always been done. |
#17 |
@Borgi, I know your trolling just like the last time this question came around but the code in question is very clear and I would happily fight an inspector on it.
#18 | ||||||
Band Member
Rewards Points: 1,626
![]() Quote:
I guess you get called on that rule a lot ?? ... on the few times you've actually done a job ? Quote:
![]() Quote:
![]() Quote:
![]() No apologies for calling you out as a complete fawking moron. ![]() Jeezzus, I logged in just to reply to this ![]()
_____________________________________ Your Mother was a hamster, and your father smells of Elderberries. ... Now go away, or I shall taunt you a second time To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#19 |
Sentimental Mental
Rewards Points: 1,484
...if you can't splice in a panel how do you make the connection of a conductor to the breaker?
. __________________________________________________ Just to be absolutely clear... I didn't say anything about nothing to nobody. |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Need advice for mouting a pony panel | NDC | Canadian Electrical Forum | 10 | 04-05-2018 03:52 PM |
Double panel design question. | JohnJ65 | Services and Service Equipment | 23 | 07-07-2017 09:19 PM |
Main panel, subpanel, detatched structure, objectionable current and 3-phase | cdw904 | Residential Electrical Forum | 4 | 05-10-2017 03:47 PM |
Old Breaker/Fuse Panel | A Little Short | General Electrical Discussion | 18 | 10-11-2016 06:34 AM |
Can I use old breaker panel as a sub panel | marshall361 | General Electrical Discussion | 4 | 07-09-2016 05:45 PM |
