Staples - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
  • 1 Post By silver50032000
  • 4 Post By wcord
  • 4 Post By PlugsAndLights
  • 3 Post By 51360
Old 06-13-2016, 05:45 PM   #1
Default Staples
What are you guys using for 14/3 NMD cable? I think the manufacturer requires S2 staple, is this being required by your local AHJ?
CEC09 is offline   Reply With Quote
Old 06-13-2016, 06:41 PM   #2
Rewards Points: 317
S-2 or else,they watch for that like a hawk.
PlugsAndLights likes this.
silver50032000 is offline   Reply With Quote
Old 06-13-2016, 07:38 PM   #3
Rewards Points: 3,104
I just looked at the package insert on these
http://www.idealindustries.ca/produc...=cable_staples
14/2 14/3 12/ 2 12/3
I think the 2 nail metal ones are the same
I havent used a s1 s2 s3 for 30 plus years
Old 06-13-2016, 07:49 PM   #4
wcord's Avatar
Rewards Points: 2,288
Those 2 nail ones are a PITA. Take too long to use
However in an older house with old growth Fir, they are the only staple that you can drive in
S1 etc will bend
Old 06-14-2016, 04:50 PM   #5
Journeyman
Rewards Points: 210
2 nail nylon staples, cheaper than s1/s2 here, and they do way more range of cables. Also dont damage the sheath if you give a tug to gain an inch here or there. Also only need to carry one size of staple for just about everything. Metal staples are for old dogs, cant stand them.
quick_2 is offline   Reply With Quote
Old 06-14-2016, 05:08 PM   #6
wcord's Avatar
Bow Wow
The Following User Says Thank You to wcord For This Useful Post:
MechanicalDVR (06-29-2016)
Old 06-29-2016, 05:16 PM   #7
Rewards Points: 973
Here too. If the package or the manufacturer's sheet doesn't specifically say you can use them with that size and conductor count of NM then you can't use them.
Old 06-29-2016, 07:35 PM   #8
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
My thought on staples is: No need to pound them in till the cable is
compressed. Couple of taps with hammer will do it. Nice and loose,
just like when the cable runs through a drilled stud. That staple might
need to be removed in 5 minutes or in 50 years, either way, it can do
it's job and still be easy to remove.
Tight is over rated.
P&L
Old 06-29-2016, 07:56 PM   #9
Rewards Points: 3,090
P&L
Actually, the Rule regarding staples was revised years ago. Wording was changed from "secure" to "support". Allowing a more common sense approach to stapling cables.
Borgi
Old 07-04-2016, 10:34 PM   #10
billyhunter's Avatar
Rewards Points: 218
Do not use too many, as above said, sometime you need remove it in 5 minutes, most time in 50 years
http://www.bulbspro.com/electrical/e...s/staples.html
billyhunter is offline   Reply With Quote
Old 07-05-2016, 01:19 AM   #11
Rewards Points: 297
Agreed. Like these much better. Can tension them up to hold cables up from sagging and looking like ****.
Judoka is offline   Reply With Quote
Old 07-05-2016, 01:34 AM   #12
Rewards Points: 24,438
I use whatever staples are made for what I'm running.
staples bh16836 NEC Code Forum 7 03-01-2016 06:52 PM
UF cable w plastic GB staples Power21 Residential Electrical Forum 5 01-16-2016 07:12 PM
