Stapling over joist for trusses ? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
Old 08-08-2019, 12:57 PM   #1
Rewards Points: 164
Default Stapling over joist for trusses ?
In a farmers shop and am running wire for some lights and I asked my boss if I could go over the joists if I wanted to. I didn't and went elsewhere anyway, but he said you can't staple to the top of joists. I didn't really see anything in the code that prohibits it because the spacing is less than 1.5 metres. Is he right? Other than its ugly as hell?
Funkadelicfred is online now   Reply With Quote
Old 08-08-2019, 01:01 PM   #2
Rewards Points: 17,215
Those don't look like Joist to me.......
electricguy and MechanicalDVR like this.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 08-08-2019, 01:17 PM   #3
jw0445's Avatar
Rewards Points: 1,770
How about rafters or trusses?
Old 08-08-2019, 03:11 PM   #4
Rewards Points: 3,860
They are when the roof is on the west wall.. lol
J F Go likes this.
Old 08-08-2019, 03:25 PM   #5
12-514 Protection on joists and rafters (see Appendix G) Cables shall not be run on or across
(a) the upper faces of ceiling joists or the lower faces of rafters in attic or roof spaces, where the vertical distance
between the joists and the rafters exceeds 1 m;
0day and Funkadelicfred like this.
AbSparky is offline   Reply With Quote
Old 08-08-2019, 03:57 PM   #6
Rewards Points: 12,449
Commonly called the three foot rule
Navyguy likes this.
Old 08-08-2019, 04:01 PM   #7
FishinElectrcian's Avatar
Rewards Points: 66
If that runner board that goes from end to end is 2x4 you could have stapled to the side of that.. Sides alright, on top where you can walk/ crawl is not.
FishinElectrcian is offline   Reply With Quote
Old 08-08-2019, 04:06 PM   #8
Mensa Player
Rewards Points: 219
Not sure if it's allowed up there, but down here we would just staple the cables to one of those diagonal web cords.
Perfection is the enemy of perfectly adequate.
Old 08-08-2019, 04:29 PM   #9
Rewards Points: 938
FYI......Every state is a little different but Farmers and agricultural companies have exceptions from following alot of building codes. I'm sure stapling above the joist is fine in a farm building.
oops i didn't realize you are in canada...dont know if there are any exceptions there
Tonedeaf is online now   Reply With Quote
Old 08-08-2019, 05:04 PM   #10
Rewards Points: 164
I know I need to have a clearance of 3 feet between the roof and the tie beam/joist/whatever and a support of 1.5 metres between them horizontally. If both these conditions are met, which can easily be done in the example in the picture, then it should be fine shouldn't it? And yes it's Canada so CEC rules but I didn't see anything that wouldn't allow it.
The Following User Says Thank You to Funkadelicfred For This Useful Post:
emt1 (08-10-2019)
Old 08-08-2019, 06:26 PM   #11
Wdl25's Avatar
You answered your own question. Yes it is allowed. Stay under the 3 foot rule
Wdl25 is offline   Reply With Quote
Old 08-09-2019, 11:26 PM   #12
Rewards Points: 4,798
The other thing is you actually have to staple them too. Because laying on the truss / rafter is not considered support and since it is not fished, you are required to staple it.
Cheers
John
Old 08-10-2019, 06:03 PM   #13
Rewards Points: 164
Cheers
John
It's not considered supported? Can you point me to the rule that says that? I guess it's because it can still sway sideways.
RRF likes this.
Old 08-10-2019, 06:15 PM   #14
Mensa Player
Rewards Points: 219
Down here it would be support, but not secured.
HertzHound likes this.
Old 08-10-2019, 08:42 PM   #15
It is the same rule as the regular stapling rule...
Cheers
John
Old 08-10-2019, 11:11 PM   #16
12-510 1 and 2, but for some reason my phone will not let me copy from the code book right now.
Old 08-11-2019, 08:39 AM   #17
Here you go...
12-510 Running of cable between boxes and fittings (see Appendices B and G)
Δ 1) Where the cable is run between boxes and fittings, it shall be supported by straps, Type 2S or 21S cable ties, or other devices located
a) within 300 mm of every box or fitting; and
b) at intervals of not more than 1.5 m throughout the run.
2) Cables run through holes in joists or studs shall be considered to be supported.
3) Notwithstanding Subrules 1) and 2), where the cable is run as concealed wiring such that it is impracticable to support it, and where metal sheeting or cladding, metal joists, metal top or bottom plates, or metal studs are not used, the cable shall be permitted to be fished and need not be supported between boxes and fittings.
Δ 4) Notwithstanding Subrule 1) a), where cable is run to a switch or a receptacle with an integral enclosure incorporating an integral cable clamp, the cable shall be supported by straps, Type 2S or 21S cable ties, or other devices located within 300 mm of the switch or receptacle wall opening, and there shall be at least a 300 mm loop of unbroken cable or 150 mm of a cable end available on the interior side of the finished wall to permit replacement.
Cheers
John
Funkadelicfred likes this.
The Following User Says Thank You to Navyguy For This Useful Post:
Funkadelicfred (08-11-2019)
Old 08-14-2019, 09:36 AM   #18
RSE Master Electrician
Incognito's Avatar
Rewards Points: 954
I know you said it’s a farmers shop, but will there be any livestock in there?
2018 Canadian Electrical Code
Old 08-14-2019, 09:41 AM   #19
Rewards Points: 2,168
In an install like that (technically attic space) have you ever been told it needs a running board along side it?
Old 08-14-2019, 02:00 PM   #20
Rewards Points: 164
I know you said it’️s a farmers shop, but will there be any livestock in there?
Nope it's the garage basically. If it's animals I believe pvc is required.
