Steel studs and insulated walls - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
Unread 03-25-2020, 04:26 PM   #1
Rewards Points: 14,819
Default Steel studs and insulated walls
What are you guys using for device boxes in insulated steel stud walls with a vapour barrier? I have tried a few things but nothing is all that great.
I put this in the Canadian forum because vapour barriers in Canada are sacred.
Unread 03-25-2020, 04:35 PM   #2
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 326
I would probably use welded nail on boxes with a vapor boot.
Are you using romex or AC90?
Unread 03-25-2020, 04:42 PM   #3
I’m thinking mostly NMD. The box needs to be supported on the side opposite to the stud. If you screw a piece of 2 X 4 to the box the vapour boot gets all scrunched up.
Unread 03-25-2020, 04:50 PM   #4
Beam Me Up Scotty
Rewards Points: 326
Scrunched up is pretty normal... maybe plastic boxes would work better though, especially if you're using NM.
Unread 03-25-2020, 04:51 PM   #5
Rewards Points: 102
I haven't yet come across this issue, but I would use Nutek boxes with a 2x4 on one side.
Are you in AB? Because I thought we couldn't use poly hats anymore? Has to be plastic gasketed boxes (Building Code)?
Sent from my SM-G960W using Tapatalk
Mobius87 is offline   Reply With Quote
Unread 03-25-2020, 04:54 PM   #6
Rewards Points: 102
If you go AC90 then you pretty much have to use a steel box with poly hats. Maybe a 2304 to fill out the hat more.
Or 4x4s with poly hats and plaster rings supported from behind.
99cents likes this.
Unread 03-25-2020, 04:58 PM   #7
I haven’t heard that but I haven’t done much resi lately. I better check it out because I’m doing a resi job right now.
What about AC90 jobs? You can’t get NuTek boxes for armoured cable can you?
Edit: Actually you can (single gang only).
Unread 03-25-2020, 04:59 PM   #8
Can't Remember
Rewards Points: 744
It's interesting because these plastic boxes with the flange for that purpose are here, but I don't think too many places require them. I'd like to see what one of these looks like, plastic with the tabs to screw to steel studs with the foam on flange. Such a thing exists?
Unread 03-25-2020, 05:08 PM   #9
It does. I just posted a photo of it. It’s kind of useless, though, because there is no support on the side opposite the stud and you can only fasten it on the flat side of the stud.
Unread 03-25-2020, 05:30 PM   #10
Rewards Points: 779
What you are talking about is what we generally refer to as “far-side support”.
To achieve this we would generally use the Caddy H23 bracket to hold the box. It also allows you to attach the box to either side of the stud.
Unread 03-25-2020, 05:37 PM   #11
Rewards Points: 102
I wonder if those are CUL rated? I've never seen them before. Typically I use KSS boxes.
Those caddy supports still don't help with the vapour barrier issue though.
The_Modifier likes this.
Unread 03-25-2020, 05:37 PM   #12
Isn’t that just for a 4 X 4 box?
Unread 03-25-2020, 05:41 PM   #13
Rewards Points: 779
Yes, with a mud ring. Can’t you cut the vapor barrier tightly around the mud ring?
Unread 03-25-2020, 05:42 PM   #14
Rewards Points: 102
Vapour barrier has to enclose the box.
Unread 03-25-2020, 05:42 PM   #15
Can't Remember
Rewards Points: 744
or 4 11/16 boxes. So yes there would be a problem for your barrier.
Unread 03-25-2020, 05:56 PM   #16
Confirmed. Flanged and gasketed in AB now.
Kevin_Essiambre likes this.
Unread 03-25-2020, 07:03 PM   #17
MHElectric's Avatar
Rewards Points: 4,914
I'm not Canadian, but I did stay in a Holiday Inn once
Can't you use 4x4 with mud rings and wrap it in duct tape? Just like you would if you were chasing masons?
99cents and Kevin_Essiambre like this.
Unread 03-25-2020, 07:59 PM   #18
Rewards Points: 5,296
I have only ever used plastic vapour barrier. Cut in 2 x 2 sections and wrap the box in it.
Cheers
John
Unread 03-25-2020, 08:26 PM   #19
Beam Me Up Scotty
Rewards Points: 326
Cheers
John
Big enough courtesy loops there? Lol
Navyguy likes this.
Unread 03-25-2020, 08:27 PM   #20
Rewards Points: 102
Cheers
John
I've done that on occasion when I didn't have the right poly hat, but overall poly hats are way easier.
I'm not a fan of the plastic boxes on the exterior walls that we have here.
They're more of a pain to work with, and are not as adaptable. No spacing them out or in to accommodate finished wall thickness.
