Steel studs and insulated walls - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
Old 03-25-2020, 08:35 PM   #21
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 534
Originally Posted by Kevin_Essiambre View Post
Big enough courtesy loops there?
Courtesy loop?
Oh, you mean the dumbwaller fnck up loop? Never knew there was a non construction term for it.
Navyguy and Kevin_Essiambre like this.
The_Modifier is online now   Reply With Quote
Old 03-25-2020, 09:57 PM   #22
Rewards Points: 26,780
Originally Posted by Navyguy View Post
I have only ever used plastic vapour barrier. Cut in 2 x 2 sections and wrap the box in it.
Cheers
John
That wall looks ancient ( pre-WWII framing ) -- has no tar paper layer -- nothing.
It's begging for poly urethane foam so as to totally fill the cavity.
Does your code allow for that option?
Old 03-25-2020, 10:59 PM   #23
Rewards Points: 15,013
Tar paper? Are you stuck in the 50’s?
Old 03-25-2020, 11:01 PM   #24
Switched's Avatar
Rewards Points: 9,900
Tar paper is still used here on stucco homes. We don't have the same climate. Like your homes would fall down in one of our earthquakes.
This site is kinda cool for that though, seeing all the different ways our trade does things.
99cents and Kevin_Essiambre like this.
Old 03-26-2020, 09:10 AM   #25
Rewards Points: 5,324
Many people use spray foam here. I have my guy (or myself) wrap boxes in either case as I don't want the boxes filled with sprayfoam either.
Cheers
Kevin_Essiambre likes this.
Old 03-26-2020, 01:20 PM   #26
Rewards Points: 4,066
It does. I just posted a photo of it. It’s kind of useless, though, because there is no support on the side opposite the stud and you can only fasten it on the flat side of the stud.
Cut a piece of the top/bottom track and wafer screw it to the open side of the stud?
Old 03-26-2020, 02:25 PM   #27
Rewards Points: 1,658
Tar paper (asphalt felt) is making a comeback here, if water does wind up where it does not belong, the tar paper soaks it up and dries it away preventing mold and rot. Tyvek does not do that.
Old 03-27-2020, 12:14 AM   #28
Rewards Points: 66
Confirmed. Flanged and gasketed in AB now.
Really no more poly hats? When did this change?
Jmcstevenson is online now   Reply With Quote
Old 03-27-2020, 12:19 AM   #29
Rewards Points: 106
Several years ago now that I've been aware of it.
Sent from my SM-G960W using Tapatalk
Mobius87 is online now   Reply With Quote
Old 03-27-2020, 12:55 AM   #30
This month, in AB anyway. Building code.
Old 03-27-2020, 01:12 AM   #31
Rewards Points: 19,087
All those boxes look like they're trying to not get aids...........
The lab was just 260 meters away from the Wuhan seafood market....... 853ft 0.2204880in. Chinese Wuhan Virus.
