Strange Interpretation - More Than One Device In A Box - Electrician Talk - Professional Electrical Contractors Forum
Like Tree91Likes
Old 06-19-2019, 07:50 PM   #1
908Eng's Avatar
Rewards Points: 70
Default Strange Interpretation - More Than One Device In A Box
Here is the junction box in question :
It was custom-built on site using all CSA / UL listed contactors and relays.
This is in the RM of Wood Buffalo (Fort McMurray region). The inspector said that the box as a whole needs to get special CSA / Intertek approval. This is a little blue field inspection sticker. They then forwarded this PDF document:
Equipment Certification Notice Jan 2019.pdf
On a side note, this notice does not appear to be available on their website or anywhere on the internet. I'm not sure how we were expected to follow it.
Summarized: "Based on the consensus of the other authorities and the RMWB Electrical Safety Codes Officers, it was decided that if there is more than one component in a box it is therefore considered an assembly and would require approval."
Have any of you run into this before? I can't find a CEC reference that states that any more than one component in a JB needs approval. The contractor has decided to simply install 6 separate JBs and pipe them together. Any help would be appreciated.
CAVEAT: Information presented in this post does not constitute professional engineering advice.
908Eng is offline   Reply With Quote
Old 06-19-2019, 08:44 PM   #2
Rewards Points: 3,686
Same in Ontario I think. I have never actually had to do it, but I have had special inspections for equipment that was built for us or brought in from other countries.
Cheers
John
Old 06-19-2019, 09:21 PM   #3
cog
stuiec's Avatar
Rewards Points: 1,048
Probably wouldn't have looked twice if it were all IEC on DIN rails so everything was straight and "professional" looking
Navyguy, MTW and Max C. like this.
Old 06-19-2019, 09:47 PM   #4
Band Member
emtnut's Avatar
Rewards Points: 614
I've gone through the certification process with ESA here in Ontario.
The interpretation given, was that if the components were used together for a specific function (ie, and single function).
A good example was a custom interlock for powering traffic lights from mains and generator. It needed approval.
To quote the first paragraph of the letter you received ..
“typically all electrical products not certified to be used together and assembled into an enclosure to create a product, requires approval.”
My question is are these relays/contactors working independently or are they performing a function together ? (ie, to create a product)
If they are for individual functions/equipment, then that interpretation is just wrong.
Good luck on an appeal though, sounds like they called every number in their rolodex
You could try getting an interpretation direct from CSA.
The_Modifier and emt1 like this.
Old 06-19-2019, 10:25 PM   #5
Rewards Points: 132
A while ago I took a mini class on control panels. Control panels have to have all the detailed labels and stickers as far as voltage, amps, fault current, etc... They have to be engineered with all the required calculations. Also about two years ago the IAEI magazine had an article about building control boxes. So yes it should be inspected by a recognized testing lab. However I bet there are tens of thousands of similar panels never tested. At least that is my understanding from where I work.
Old 06-19-2019, 10:52 PM   #6
Rewards Points: 10,863
So, if you use a six pole contactor instead of three 2 poles, it’s okay?
Old 06-19-2019, 10:53 PM   #7
wcord's Avatar
Rewards Points: 1,478
More than 4 contactors or relays in the box, requires local csa inspection.
I cant remember the ruling on this, but it's been this way for as along as I can remember.
Kevin_Essiambre likes this.
The Following User Says Thank You to wcord For This Useful Post:
The_Modifier (06-20-2019)
Old 06-19-2019, 11:19 PM   #8
908Eng's Avatar
Rewards Points: 70
It's tough to say if they are for a single or multiple functions. It is an industrial shop with a MUA unit and exhaust fans. The contactors are for the exhaust fans and the relays are for the MUA and other logic. The MUA is controlled via the manual switch AND the gas detection system. It may also have low/high selection functions.
They are part of a shop ventilation "system", but the individual components control totally separate parts.
Yes... as long as the other smaller relays were elsewhere as well. And that is part of the point. It seems a little silly. What about a lighting contactor box / lighting control panel? BMS panel? Sump pump controls? What about a fire alarm panel? What if you just put junction boxes inside the bigger junction box? Where does it end?
You're ticketed electricians! Shouldn't you have some discretion to practice your trade??? Surely you are qualified to hook up a few relays in a box!
Wouldn't it be nice if there were an actual code or legislation reference? The only references that seem to exist are anecdotal opinions of people that sell equipment and training courses.
Old 06-19-2019, 11:31 PM   #9
RSE Master Electrician
Incognito's Avatar
Rewards Points: 410
When you build a control box it needs to be certified. Yes each component is CSA certified and tested but when you build something different with these components, what you built needs to be tested by CSA as a whole.
glen1971 likes this.
2018 Ontario Electrical Code
Old 06-20-2019, 12:29 AM   #10
Rewards Points: 15,309
I betcha when they build something similar to that in China , they don't have to do anything additional at all .............. just sayin...... cause they are winning the economic race against western economy's ......
Old 06-20-2019, 06:27 AM   #11
Can't Remember
Rewards Points: 788
The State has a thing for this too, and while I don't often build something that would trigger this, I sometimes need multiple relays for load shedding and just buy one already made and labeled to avoid this.
Old 06-20-2019, 07:38 AM   #12
I don’t understand this. We can put together a “system” of panels, lights, receptacles, motors, transformers, etc. but putting four contactors in an enclosure requires certification from someone else. Cash grab.
Old 06-20-2019, 07:41 AM   #13
Rewards Points: 1,283
I agree.
What if you put those contactors in separate enclosures?
There are 2 types of electrician... Those who knowingly break code, and those who lie about it.
Old 06-20-2019, 07:47 AM   #14
Incognito's Avatar
Rewards Points: 410
In the “system” you describe, we are using each piece of equipment the way they were designed and tested for.
Taking a bunch of items and building a new piece of equipment out of it is when you need to have it tested.
Old 06-20-2019, 07:49 AM   #15
Incognito's Avatar
Rewards Points: 410
I agree.
Then you would be using them in a way they were tested and certified to be used.
Old 06-20-2019, 07:54 AM   #16
What is the difference if they were in separate enclosures or 1 enclosure?
What if you put 4 separate enclosures next to each other with close nipples between them?
What if you put 4 separate enclosures next to each other with a window cut out between them?
No one is building a new piece of equipment. Putting devices into the same enclosure is no different than putting them into different enclosures next to each other.
Don't defend lunacy.
Old 06-20-2019, 08:00 AM   #17
I agree.
Apparently you’re okay.
I built on of these two weeks ago. A fancy control box with bells and whistles you don’t need is $1500. I built one that did the job for less than $200 in materials. The tinbasher paid me to build it and I saved him money. Win/win.
These aren’t complicated controls. A current sensing relay from the exhaust controls MUA and the contactors are used to make or break power to equipment as required. They teach us about contactors and basic control circuits in school but in the field we are deemed too stupid to do what they taught us.
908Eng likes this.
Old 06-20-2019, 08:04 AM   #18
But you’re not creating a new piece of equipment, you’re simply grouping a number of components in one location.
A contactor has ratings for coil voltage and contacts. It switches on and off. That’s what it’s designed for. That’s it’s...erm...definite purpose.
908Eng likes this.
Old 06-20-2019, 08:11 AM   #19
Incognito's Avatar
Rewards Points: 410
Most often there is no difference and everything is fine.
But other times there are many things that need to be looked at. Wire sizes often are not correct, fusing, multiple circuits contained in the one enclosure, the way the devices are mounted, bonding......
There has to be rules and things need to be certified and tested to be used in the manner they have been connected.
Old 06-20-2019, 08:21 AM   #20
Not a single thing that you mentioned here is different when they are installed in different enclosures vs. the same enclosure. If anything, installing them in different enclosures exposes them to higher risk of potential issues.
Why are you defending this nonsense?
I agree, but you are misapplying that statement.
