2009 Canada Electrical Code - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By Kevin_Essiambre
  • 2 Post By Navyguy
Old 10-05-2019, 01:53 PM   #1
Rewards Points: 12
Default 2009 Canada Electrical Code
Can anyone confirm that this regulation for Solar PV - Overcurrent Protection is in the 2009 Canadian Electrical Code book:
"Where overcurrent protection is required by Subrule (1) for a photovoltaic source circuit, each photovoltaic source circuit shall be protected by an individual overcurrent device rated or set at not more than the allowable ampacity of the conductors of the photovoltaic source circuit or the maximum overcurrent protection indicated on the panel nameplates, whichever is less."
Thanks for your input.
CBerry is offline   Reply With Quote
Old 10-05-2019, 01:55 PM   #2
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 288
Why 2009 CEC?
Welcome to the forum.
Please fill out your profile.
Bird dog likes this.
Old 10-05-2019, 02:12 PM   #3
Rewards Points: 12
Thanks for the quick reply.
I'm concerned with 2009 because the array in question was installed in 2010 so this would be the applicable code at time of construction.
The specific issue I'm having is that the way the system is set up has 3 panels strung together with 4 strings coming together in a combiner box with a breaker for each combiner. The Electrician I'm working with is saying that each string needs a separate breaker which would a pretty costly change.
I'm just looking for confirmation on what the standard was when it was built to see if there's an opportunity to have the current design grandfathered in.
Appreciate any input you might have.
Old 10-05-2019, 02:37 PM   #4
HertzHound's Avatar
Rewards Points: 1,192
I don’t know anything about the CEC, so don’t be mad at me for replying. The way I remember ours is that two strings combined don’t need separate fuses. It has to do with a short and the stings being able to handle the total current. Once you add the third string, you need to add protection for the separate strings because they can’t handle the back feed? Something with one string shorted, it only sees the current of a single string? Series/parallel kinda stuff.
That was always the case for the NEC. Whether they now require protection for two strings IDK. But your set up always had four strings tied together. In your set up, to me, it always required protection for each string.
Why say lot words when few words do trick
Old 10-05-2019, 02:47 PM   #5
Beam Me Up Scotty
Rewards Points: 288
I don't have a 2009 CEC so I cannot help with this.
But, if it passed inspection, why bother?
Old 10-05-2019, 02:50 PM   #6
Rewards Points: 12
Thanks for the reply Hertz, I got similar feedback from another Electrician that I used to work for.
Old 10-05-2019, 04:54 PM   #7
RSE Master Electrician
Incognito's Avatar
Rewards Points: 954
Depending on which province your in, new code doesn’️t usually get adopted until at least a year after it comes out, sometimes longer.
Also, 2009 CEC does not have a section 64 for renewable energy systems, there was only a small section on solar photovoltaic systems, section 50. This is the only code on overcurrent in it.
2009 Canada Electrical Code-a3021711-b768-4fbb-bc7b-123a712dca31_1570305626027.jpg
2018 Canadian Electrical Code
Old 10-06-2019, 01:43 PM   #8
Rewards Points: 12
Thank you so much for the support!
Old 10-06-2019, 01:48 PM   #9
Rewards Points: 12
Sorry, just a bit of confusion. Is the image you posted from the 2009 or 2018 Ontario Code?
Old 10-06-2019, 04:54 PM   #10
Incognito's Avatar
Rewards Points: 954
Originally Posted by cberry View Post
sorry, just a bit of confusion. Is the image you posted from the 2009 or 2018 ontario code?
2009 CEC section 50
Old 10-08-2019, 02:25 PM   #11
Rewards Points: 12
Hi Incogito,
Is there any chance you could send another photo of that page from CEC section 50? A full page version perhaps it shows the year on the top of the page?
Old 10-08-2019, 08:13 PM   #12
HertzHound's Avatar
To me 50-010 (1) says you need overcurrent protection after two strings. That’s what I get when I read between the lines anyway.
Old 10-09-2019, 01:18 AM   #13
Rewards Points: 5,142
Hi Incogito,
There is no date on the page... at least on the Ontario code that I have.
Cheers
John
bob_says_hello and Incognito like this.
Old 10-09-2019, 11:45 AM   #14
Rewards Points: 150
Can confirm Navyguy, but here's the full page regardless.
bob_says_hello is offline   Reply With Quote
Tags
canada, code, safety, solar
