Efficacy of Solar in 2019 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
  • 3 Post By JoeSparky
  • 3 Post By MHElectric
  • 1 Post By Southeast Power
  • 1 Post By Lightsmith
  • 1 Post By davey
  • 2 Post By splatz
Old 09-23-2019, 09:26 AM   #1
MikeFL's Avatar
Rewards Points: 980
Default Efficacy of Solar in 2019
Well here we are in the year 2019.
When it comes to turning on your car headlights as the day gets darker, I was taught to turn them on when half the other cars have theirs on. If I relate that to solar, it's not time. But I'm curious about it.
I'd expect having solar on my roof would lessen my heat gain in the building? I have a 90 lb modified bit roof. Covering that, at least partially, would reduce heat gain.
I pay for about 4k kWh of electricity per month (4MWh).
I have 2 services, both 200A 120/208 Y.
How much would it cost me today to install solar using an EC?
What's my power bill going to be?
How long will the system last?
You'd think my highest energy consumption would be the reflow oven, but it's not. It's the A/C.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 09-27-2019, 08:21 PM   #2
See you at CBE
JoeSparky's Avatar
Rewards Points: 553
I would have figured your headlights would have been controlled by a GPS light lock
99cents, splatz and Bird dog like this.
Old 09-27-2019, 09:26 PM   #3
MikeFL's Avatar
Rewards Points: 980
Now that we've been making some 12V units that just might happen. At least an indicator light.
GPS Timers
(833) GPS-TIME
Old 10-19-2019, 07:47 PM   #4
MHElectric's Avatar
Rewards Points: 2,504
I was in a continued ed class a while back and it was covering solar. Very interesting and informative!. Several key notes I took away from it:
1) The solar market/trade is changing so much, that its absolutely impossible to keep up with all the installation standards. If you are a solar contractor right now and you decided to get out for a year or two, when you get back in the industry will have changed so much that it you wouldn't be able to pick it back up without dealing with a huge learning curve.
2) lots of turn over in the solar business
3) the BIGGEST hurdle that the contractors face is the 100's of roof penetrations that get made on every project. That's a lot of worry if you ask me.
99cents, Bird dog and MikeFL like this.
Old 10-19-2019, 08:11 PM   #5
Rewards Points: 3,014
Get a free quote and listen to the sales pitch. You should be able to gather enough information with a few questions to backwards engineer what they are selling.
Old 10-19-2019, 08:25 PM   #6
Band Member
emtnut's Avatar
Rewards Points: 194
Not sure if that would sell. Both my car and truck turn on the lights automatically with the light sensor on the dash.
Back in the day, rule was half hour before sunset to have your lights on.
Electrical losses can be minimized by doing proper electrical estimating through jack-off internet electrical estimators
Old 10-19-2019, 08:28 PM   #7
MHElectric's Avatar
I think finding a good manufacturers is the big problem. Knowing that you could buy some high end equipment today, but they might not be around for you to get parts and service next year doesn't sit right with me. The installation process probably isn't to hard to peice together.
The Following User Says Thank You to MHElectric For This Useful Post:
Electrician in WR (01-25-2020)
Old 10-19-2019, 08:50 PM   #8
Southeast Power's Avatar
Rewards Points: 9,368
Mike,
You have to jump on the merry go round at some point.
Once you have the racks installed and the inverter installed, the system should should be both scale able and upgradable.
MikeFL likes this.
Old 11-22-2019, 01:51 PM   #9
Rewards Points: 84
Before installing solar add a layer of solid insulation to the roof and a new membrane. If it is subbed out by the solar installation company then it can be rolled together for the tax credits.
Solar panels have a useful life of more than 50 years and add on average $17,000 to the resale price of a house and a house on the market will sell in half the time of a comparable house without solar.
At the very least contract with a company that will install the panels and provide you with a fixed payment for electricity for you that will not go up in future years, unlike the electrical bill from the utility.
Nothing could be simpler than a solar panel installation. Most have the output as DC which is run in series in EMT to an inverter box and then a transfer switch (so no power goes to the grid when the grid is down). If two different sets of panels are used then the line voltages willl be different but that is easily resolved with a dual string type inverter that houses two inverters in a single box. More and more houses will have panels on different parts of the roof and so even the same number of panels will vary in terms of output voltage and the dual-string inverters handle the situation.
If living in the sunshine state this would be a good time to also wire in a whole-house surge supressor which is very cheap insurance.
joebanana likes this.
“If you can convince the lowest white man he's better off than the best colored man, he won't notice you're picking his pocket. Hell, give him somebody to look down on, and he'll empty his pockets for you." Lyndon Johnson
Lightsmith is offline   Reply With Quote
Old 11-22-2019, 10:26 PM   #10
Rewards Points: 1,058
I am assuming the this is a commercial location. Is it a flat roof? 90 pound modified bit? Is that a torch down type? Anyway check how installing the panels will affect the roof warranty. I have several commercial accounts who had a new roof and the warranty would be affected unless certain guidelines were followed.
The Following User Says Thank You to kb1jb1 For This Useful Post:
Old 01-18-2020, 08:17 PM   #11
Rewards Points: 109
A colleague went that route and then moved. The problem he ran into is that he had to sell the house with the PV company's contract: another thing for a purchaser to take into account.
Bird dog likes this.
davey is offline   Reply With Quote
Old 01-18-2020, 09:30 PM   #12
Bird dog's Avatar
Rewards Points: 852
Or the seller pay off the contract.
Old 01-18-2020, 10:27 PM   #13
Rewards Points: 1,920
Micro inverters and power optimizers eliminate the issue of voltage differences.
Old 05-25-2020, 12:23 AM   #14
Rewards Points: 54
Solar panels will not just power your AC on scorching hot summer days, they work as air conditioners themselves. Installing solar panels will block this sunlight from hitting your roof, thereby preventing heat from entering your house. Solar panels can lower a roof’s temperature by around 3 degrees Celsius.
pawanranta is offline   Reply With Quote
Old 05-25-2020, 07:04 AM   #15
Rewards Points: 3,140
This is a valid point but it works year round, right? In the winter the solar panels prevent the sun from warming the house.
drsparky and MikeFL like this.
#HACKLIVESMATTER
Old 05-25-2020, 08:04 AM   #16
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,880
There is no advantage to warming a roof in the winter.
A well insulated home with a well vented attic will stay cold, almost outside ambient, for as long as possible.
You can spot a poorly insulated and vented home by the lack of snow after a storm. Heat is what kills a roof quickly.
Old 05-25-2020, 09:37 AM   #17
Senior Moment
drsparky's Avatar
Rewards Points: 410
Come spring once you get a small part of the roof exposed the snow starts melting, and that is a wonderful thing.
Old 05-25-2020, 03:59 PM   #18
Rewards Points: 8,269
Does water swirl down the drain in the opposite direction up there too? It's half an hour after sunset down here. But anyway, what's a "head light switch"?
Old 05-25-2020, 04:03 PM   #19
See if this helps
https://www.homeadvisor.com/cost/hea...-solar-panels/
Depending on the quality, is how you figure "useful life" of panels, and it's all over the place.
ie. Chinese made= 3 to 10 years, US made 30 years +
