Ferril type connectors - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By telsa
  • 1 Post By telsa
Old 06-16-2017, 08:19 AM   #1
Rewards Points: 237
Default Ferril type connectors
I'm using the Midnight combiner box. The lug that is used to connect the battery cable to the combiner plate for the positive leed is too small for a 2/0 wire. I'm looking for a crimp connector with a solid ferril(1/4 in.) on the end to tighten the set screw down on. Looked but can't find. Mike.
besc is offline   Reply With Quote
Old 06-16-2017, 08:33 AM   #2
Rewards Points: 8,119
I tried a different spelling and found this:
http://www.ferrulesdirect.com/
joebanana is online now   Reply With Quote
Old 06-16-2017, 09:18 AM   #3
Rewards Points: 237
Sorry. I meant solid ferriles. Which would probably mean stud. I need to solder the 2/0 in the open end and secure the other with a set screw. I'm trying to avoid cutting off a few strands to make the cable fit but if I have to then so be it.
Old 06-16-2017, 03:29 PM   #4
Rewards Points: 24,222
Ferrules it is!
Old 06-16-2017, 03:36 PM   #5
Rewards Points: 26,912
There are such things as terminal reducers. ( my term )
These have female openings for a larger conductor... and a male tip a bump or two smaller in size.
These are intended to be CRIMPED on... though I'd guess you could solder them on.
( Not recommended... go with compression connections every time. )
Last time I touched one was ~ twenty-years ago.
Buchanan ? Heck if I can remember.
These are often needed when the field conductor was up-sized for distance and voltage drop -- not amps. They make an elegant way to get your conductors underneath circuit breaker lugs, etc.
splatz (06-16-2017)
Old 06-16-2017, 04:09 PM   #6
Rewards Points: 2,888
Glad you mention this, I need something like this right now!
I bumbled around a little just now, if you search for "reducing pin" you'll find them for big wires, for small wires, look for "pin terminal" - Sta-kon makes them.
With a ferrule, the wire goes into the pin, so the diameter is a little larger. With the pin terminal, well, it is what it sounds like.
telsa (06-16-2017)
Old 06-16-2017, 10:27 PM   #7
Those 10 awg type are the only ones of that design I recall using.
Old 06-16-2017, 11:34 PM   #8
Correction:
Hax taps loving cons.
splatz (06-17-2017)
Romex Connectors for Oil Resistant Cable sparkiez NEC Code Forum 6 09-27-2017 04:44 PM
Wrapping tape around cord connectors? Jayc316 Commercial Electrical Forum 18 08-08-2016 09:13 PM
Upgrading and outdoor screw-in fuse box to a circuit breaker type box Jimmi328 Residential Electrical Forum 2 03-26-2016 08:09 PM
Ever-Lok Connectors gregvinci NEC Code Forum 1 02-08-2016 03:22 PM
Ever-Lok Connectors gregvinci NEC Code Forum 0 02-08-2016 02:28 PM
