How much damaged could have been caused? - Electrician Talk - Professional Electrical Contractors Forum
Old 08-13-2018, 07:55 PM   #1
Rewards Points: 42
Default How much damaged could have been caused?
I work for a commercial electrical contractor and we don't do much with solar. We were brought into a building to disconnect some panels so roofers could get in and the guy who reconnected them ****ed up. He didn't disconnect the DC link and said he saw an arc at the MC4 connector when he did. He also briefly hooked up two stings incorrectly so that one had 6 panels and the other had 8 (each was supposed to have 7). It was like this for several hours..
My question is: how much damage could have ben caused?
flashmasterspark is offline   Reply With Quote
Old 08-13-2018, 08:40 PM   #2
Rewards Points: 8,259
Damage to what? The inverter, the panels, wiring? Did you remove the panels so the roofers could do their thing, and "the guy" put everything back? Who does "the guy" work for? Was he qualified to reconnect them? does he still have a job?
Old 08-13-2018, 11:17 PM   #3
Rewards Points: 42
Anything. He removed them, reattached them and then I came a few hours later and put them back in the proper strings. He works for the same company I do, and yes where I live he is qualified but he doesn't have much experience.
INB4: I work for a sketchy company, I live in a sketchy place, he should be fired. Just wondering if you know the likelihood of damage. If not thats okay.
Old 08-13-2018, 11:32 PM   #4
Rewards Points: 3,002
Nice and friendly company.
Probably no damaged. That's the fun with electronics you never really know until the magic smoke comes out.
If the guy didn't try to cover up what he did then its a ops. In-experienced people make op'es and experienced people normally take the time to show/teach the person so it doesn't happen again.
Old 08-13-2018, 11:43 PM   #5
Rewards Points: 6,421
It's unlikely you had the brightest design day going on at the time, so the string with the extra panel was probably no big deal. If the inverter(s) appeared to fire up normally, chances are you're just fine. I might be mildly concerned about potential crisping of the MC4 interlink, but there's plenty of people that pop them in and out hot with no particular issues.
Old 08-14-2018, 12:39 AM   #6
Most commercial PV systems are pretty stout. Check the fuses in the combiner box, but other than that, just check your outputs, and unless there's obvious damage (like chipped/cracked panels) you should be good to go.
Old 08-14-2018, 02:03 AM   #7
Rewards Points: 22,805
The biggest problem is you probably damaged the sun quite a bit. We are all bummed. I't a very delicate device. You should put dark tarps over panels prior to disconnecting them.
Start buying American
Old 08-24-2018, 03:58 AM   #8
Rewards Points: 1,564
Unlikely that you did any serious damage
panel numbers would not have done any damage
as the switch mode controller would have compensated
And interupting any dc circuit under load will draw an arc
but I think you will find this stuff is designed for it
rest easy !
Tags
array, renewables, reno, solar
Ground fault caused all 3 fuses to blow? JasonCo General Electrical Discussion 14 07-11-2018 09:02 PM
What caused this fuse melt down? Canaduh Residential Electrical Forum 9 01-16-2018 06:56 PM
Old Novaline panel with damaged cover screw holders? Islander General Electrical Discussion 10 03-02-2017 06:41 PM
Damaged wiring inside a water heater - questions Islander General Electrical Discussion 14 01-01-2017 04:37 AM
