Thread Tools | Display Modes |
#1 |
Swimmer
Rewards Points: 654
I have 12" of unsupported EMT under the eave of a roof. The run along one side of the house was along the wall of the house. I then transitioned to the inside surface of the fascia board so there are 12" of unsupported conduit between the house wall and the fascia. I can't find anything in 300.18 or 358.30 that expressly prohibits this.
Elvis is in the building |
Join the #1 Electrician Forum Today - It's Totally Free! ElectricianTalk.com - Are you a Professional Electrical Contractor? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's the leading place for electricians to meet online. No homeowners asking DIY questions. Just fellow tradesmen who enjoy talking about their business, their trade, and anything else that comes up. No matter what your specialty is you'll find that ElectricianTalk.com is a great community to join. Best of all it's totally free! |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ElectricianTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Sponsored Links | |||
Advertisement |
#2 |
Mensa Player
Rewards Points: 383
Do you mean 12' (foot)?
If not, I can't figure out the question. EMT needs support every 10', so 12" is perfectly fine.
Perfection is the enemy of perfectly adequate. |
The Following User Says Thank You to HackWork For This Useful Post: | swimmer (06-20-2017) |
#3 |
Rewards Points: 7,349
Is it supported within 3' of the end? Is it supported at least once every 10'? Just support it right next to the unsupported part.
The Following User Says Thank You to joebanana For This Useful Post: | swimmer (06-20-2017) |
Advertisement |
#4 |
Gold Pliers Champion
Rewards Points: 2,270
There used to be 383.30(C) (I think) that allowed less than 36" to be unsupported. A nipple.
That was removed so technically you need some support, but if it's up and out of the way I wouldn't worry about it. |
The Following User Says Thank You to Signal1 For This Useful Post: | swimmer (06-20-2017) |
#5 |
Mensa Player
Rewards Points: 383
In what situation would that be used?
#6 |
I think in most cases a nipple between two panels or boxes.
Not really the OP situation here I guess. He said it was a short piece under a roof eave where it's not going to get kicked around or anything. Nothing to worry about I'd say. |
#7 |
Mensa Player
Rewards Points: 383
Gotcha, I see what you are saying.
I'm still confused about the OP.
#8 |
Watt Pusher
Rewards Points: 468
Wow you guys can go 10' between straps for EMT? Up here it's 1.5m/5' (1/2" & 3/4"), 2m/6' 6" (1" & 1 1/4") or 3m/10' (1 1/2" and up). Same for rigid.
Is that a real poncho or is that a Sears poncho? |
#9 |
Rewards Points: 316
If I get this it's strapped right to the boards except for where the jog in the pipe crosses the soffit.
@swimmer, are you just worried about the 12" where it crosses the soffit and isn't touching a board? That's no problem at all.
Everything Should Be Made as Simple as Possible, But Not Simpler |
#10 | |
Swimmer
Rewards Points: 654
![]() Quote:
@splatz Yes that's all I was worried about. Thanks
#11 |
Swimmer
Rewards Points: 654
I should have taken a picture. When I said "unsupported" I meant it isn't against any wood or stucco for those 12 inches. It just goes through the air. Anyway, I don't think I have to worry about it.
#12 |
Mensa Player
Rewards Points: 383
A very large percentage of pipe runs aren't against anything, such as all the pipe run overhead being supported every 8-10 by hangers or trapezes.
Tags |
emt support and securing ![]() |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Lining up your holes through the eave... | 99cents | General Electrical Discussion | 40 | 06-16-2016 09:40 PM |
