2020 GFCI Requirements - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree45Likes
Old 02-10-2019, 09:31 AM   #21
Can't Remember
Rewards Points: 796
Originally Posted by Signal1 View Post
Wasn't that the one where a guy jumped the neutral and ground in the receptacle?
Something about a finished basement if I recall?
I think there's a pic somewhere.
im gonna pay for this
I'll have to ask the inspector next time I see him so I get my story straight. It may have more to do with the range frame being lit up and the pipes being bonded. I forget that exact details. I've seen the range frame lit up before even though it was bonded.
Old 02-10-2019, 11:05 AM   #22
Rewards Points: 7,520
I remember at grandma’s house you had to be careful when using the kitchen sink. If you were touching the range and the sink at the same time you would get quite the lifter! Lol
Old 02-10-2019, 11:52 AM   #23
Rewards Points: 84
Anytime the neutral is connected to a dryer or range frame, and a person provides a path by touching the frame and another grounded object, a shock is likely. Hence the requirement for a 4 wire supply.
Mulder is offline   Reply With Quote
Old 02-10-2019, 12:06 PM   #24
CoolWill's Avatar
Rewards Points: 1,636
That's not true. It isn't likely. The copper neutral is so much of a better conductor than the human body that all but micro or nano amps would travel through a person. If the neutral becomes open though, that's another matter.
tmessner, splatz and positron like this.
Old 02-10-2019, 12:09 PM   #25
HertzHound's Avatar
Rewards Points: 430
Originally Posted by svh19044 View Post
I have been using the afci/gfci breakers for the past year on all new circuits so it's a non issue. The finished area was already required to be afci, and the afci/gfci breakers are the same price. No brainer, just throw in the dual protection.
As for the 240v gfci protection, it's adding on a (percentage wise) substantial cost to an already costly part of wiring where I don't believe it has ever been an issue. So what has happened to make them now become gfci protected?
If I put a 120V receptacle beside a sink in a restaurant it needs to be GFCI protected. If it’s 208V, it’s not required. Explain that.
I can’t explain it. This is the change that was added in our last code book.
(B)Other Than Dwelling Units.
All single-phase receptacles rated 150 volts to ground or less, 50 amperes or less and three-phase receptacles rated 150 volts to ground or less, 100 amperes or less installed in the following locations shall have ground-fault circuit-interrupter protection for personnel.
(1)Bathrooms
(2)Kitchens
(3)Rooftops
“Why say lot words when few words do trick”
Old 02-10-2019, 12:22 PM   #26
Rewards Points: 84
If the resistance of a body is 100,000 ohms the current through that body would be 1.2 milliamps if the voltage is 120 volts. Wet or cracked skin can significantly reduce the resistance. A person will feel 1.2 milliamps.
positron likes this.
Old 02-10-2019, 12:41 PM   #27
CoolWill's Avatar
But the voltage won't be 120 volts.
Old 02-10-2019, 01:05 PM   #28
Rewards Points: 84
The resistance is likely to be a lot lower than 100k ohms.
The International Electrotechnical Commission gives the following values for the total body impedance of a hand to hand circuit for dry skin, large contact areas, 50 Hz AC currents (the columns contain the distribution of the impedance in the population percentile; for example at 100 V 50% of the population had an impedance of 1875Ω or less):
Voltage 5% 50% 95%
25 V 1,750 Ω 3,250 Ω 6,100 Ω
100 V 1,200 Ω 1,875 Ω 3,200 Ω
220 V 1,000 Ω 1,350 Ω 2,125 Ω
1000 V 700 Ω 1,050 Ω 1,500 Ω
Old 02-10-2019, 01:18 PM   #29
CoolWill's Avatar
Voltage 5% 50% 95%
Ok, we're still talking about less than 1 volt. You can barely feel that on your tongue.
Old 02-10-2019, 01:46 PM   #30
At my grandma’s house, I think one of the hots was accidentally connected to the frame of the range and it was not grounded because when you touched the range frame and the sink at the same time it was a huge shock!
Old 02-10-2019, 02:16 PM   #31
Rewards Points: 15,351
Probably somebody either changed out the cord or the outlet and swapped the neutral and one hot wire on the terminals. I bet it took a long time when grandma was baking cookies and pies.
eddy current likes this.
Old 02-10-2019, 04:37 PM   #32
One thanksgiving my cousins were having a contest to see who could hold on to both the longest! I didn’t like that game
Old 02-10-2019, 05:07 PM   #33
Elderly Member
jelhill's Avatar
Rewards Points: 1,090
Originally Posted by manchestersparky View Post
I've been looking into the 2020 NEC ….
BIG changes are being proposed for the 2020 GFCI requirements in dwellings !!
GFCI requirement for unfinished AND FINSHED basements
240 volt receptacles in areas listed in 210.8 being proposed to be GFCI
Items like the Dryer Receptacle, any 240 volt receptacle in garages/shops, just to name a few.
Interesting things are coming _ Worth the time to review the 2020 on the NFPA website...
Based on another thread (That has nothing to do with you Manchester) I could say something about the dryer receptacle deal, but I have decided to treat everyone super nice on ET.
jelhill is offline   Reply With Quote
Old 02-10-2019, 05:11 PM   #34
Elderly Member
jelhill's Avatar
Are they requiring even more AFCI's?
Old 02-10-2019, 06:34 PM   #35
Rewards Points: 84
The voltage and current would be dependent on the resistances involved and Ohm's law.
Old 02-10-2019, 06:44 PM   #36
CoolWill's Avatar
The voltage is dependent on the potential on the frame of the dryer, which is the same as the voltage drop across the neutral, which is almost zero. Zero volts across any resistance is zero amps.
Old 02-10-2019, 07:16 PM   #37
Rewards Points: 10,943
They should just put GFCI protection in appliances. A soccer mom will spend $2000 on an appliance and then become a barracuda over the cost to wire it.
svh19044 and CoolWill like this.
Dan the electricman (02-10-2019)
Old 02-11-2019, 05:36 PM   #38
Professional Nit Picker
manchestersparky's Avatar
Rewards Points: 2,120
Not Here !
All single phase receptacles rated 150 volts to ground or less, 50 amperes or less and all 3 phase receptacles rated 150 volts to ground or less, 100 amperes or less require GFCI protection
99cents likes this.
Anything Worth Doing ....
Is Worth Doing Right
Old 02-11-2019, 07:46 PM   #39
MTW
MTW's Avatar
Rewards Points: 7,528
I'm so glad we have the NEC to protect us from the hazards of electricity by requiring more expensive products that make manufacturers lots of profit.
CoolWill likes this.
Old 02-11-2019, 08:45 PM   #40
Rewards Points: 1,079
As much as i agree with this, More expensive products make me more profit too. I get a percentage cut on everything I sell At least the GFCI is proven tech and not defective voodoo bull$hit like arc faults.
Delta wired gfci Mikelite General Electrical Discussion 69 01-07-2019 10:41 PM
Where is the GFCI protection sammedit Residential Electrical Forum 6 06-02-2018 10:48 AM
QO Single Pole GFCI Issue Takideezy Residential Electrical Forum 2 08-29-2017 08:28 PM
Can a pool pump burn out GFCI receptacles? HackWork General Electrical Discussion 116 06-06-2017 09:03 AM
Blank Face GFCI Question Ducatiguy Canadian Electrical Forum 5 01-11-2016 04:35 PM
