2020 Residential Services-- Surge Protection - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree62Likes
Old 10-06-2019, 06:06 PM   #61
MikeFL's Avatar
Rewards Points: 3,002
Although lightning is a surge, not every surge is lightning.
A MOV that clamps an 800V surge is not going to have the same reaction as a MOV that attempts to clamp a nearby lightning hit.
drsparky and splatz like this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 10-06-2019, 08:32 PM   #62
Rewards Points: 198
Where would this 800V surge come from and what would terminate it (make it stop)?
I ask in terms of duration and what sort of protection scheme would coordinate with the surge supressor.
I am no expert on transmission and distribution but I don't see how poco equipment can supply much more than a few percent extra voltage.
Short of a catastrophic failure in which case things get real interesting, more like lightning.
Jerome208 is online now   Reply With Quote
Old 10-07-2019, 07:46 AM   #63
MikeFL's Avatar
wind
GPS Timers
(833) GPS-TIME
Old 10-07-2019, 08:03 AM   #64
Band Member
emtnut's Avatar
Rewards Points: 1,234
If you search you'll find zillions of pictures like this one:
There are similar pictures for surge strips. I found a surge strip that had cooked off pretty bad after a lightning storm, a bit scary. There are manufacturers selling surge strips with the MOVs in metal housings now. I am switching back to the old Tripp Lite Isobars, which are excellent and have a metal case.
Yep, sometimes they catch on fire. !
Scary huh
Old 10-08-2019, 09:33 AM   #65
Rewards Points: 16
I was standing next to a crappy 'surge protector' power strip that lit up like that once. Thing had a mini fridge plugged into it. One minute it was fine, the next there was a little camp fire next to me. In a fertilizer plant.... and no fire extinguisher in sight.
Sent from my SM-G960W using Tapatalk
Mobius87 is offline   Reply With Quote
Old 10-08-2019, 10:50 AM   #66
Rewards Points: 4,416
I struggle myself to visualize this because it's a lot harder to think about than current in wires in circuits.
In a lightning strike, there's a surge in ground potential at the point of the strike that's immense. It dissipates in a gradient around that point in the ground. Of course the ground itself has resistance, there is voltage drop across the resistance, the voltage at any point in the gradient is lower than the voltage at the strike point, the further you get, the lower the voltage.
A similar thing happens if a primary distribution line is lying on the ground say across the street from your house, this will raise the ground potential at the rod in your house, but not as much as it would if the primary line was bolted to your ground rod.
Old 10-08-2019, 11:11 AM   #67
Bird dog's Avatar
Rewards Points: 1,958
Maybe think about it as an electrical earthquake. The lightning strike point is the epicenter & gradients of damage. Or a dam breaking & the gradients of damage.
