Afci - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 1 Post By wildleg
  • 1 Post By HackWork
  • 2 Post By Going_Commando
  • 1 Post By Dennis Alwon
  • 1 Post By B-Nabs
  • 1 Post By MTW
  • 1 Post By Wiredindallas
Old 02-25-2019, 08:45 AM   #1
Peter Goldwing's Avatar
Rewards Points: 274
Default Afci
I just finished wiring my own house here in Fl.
The inspector brought to my attention that arch fault breakers are needed mostly every where inside the house. I checked the 2017 code and he's correct.
Circuits in the garage are exempt as are all the 240V circuits.
My laundry machines are located in the garage and there is not a formal "laundry room".
Is this branch circuit required to be arch fault protected ? Whats your opinion on this?
Peter Goldwing is offline   Reply With Quote
Old 02-25-2019, 08:54 AM   #2
Rewards Points: 1,755
I don't believe the code states laundry room, it says laundry area, which your space in the garage certainly is. Water supplies, drain standpipe, dryer vent duct, etc. That laundry area would require the dedicated 20A laundry circuit.
Old 02-25-2019, 09:15 AM   #3
Rewards Points: 274
On an arch fault! right?
Old 02-25-2019, 09:16 AM   #4
Rewards Points: 274
It is tough to determine where the garage stops and the laundry area begins
Old 02-25-2019, 09:18 AM   #5
I don't know, I don't pay attention to AFCI requirements.
I'm just saying that I believe the receptacle for this area would go by the requirements for the laundry area receptacle, even though it seems like it could be considered a normal garage receptacle.
Old 02-25-2019, 09:44 AM   #6
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
2017, eh ? did the inspector tell you that was the code cycle ?
MikeFL likes this.
Old 02-25-2019, 09:48 AM   #7
The one outlet you put closest to the laundry machines will be the laundry circuit and should follow the requirements for that. All the rest just do as you would for normal garage circuits.
The same as when the laundry is in the basement.
Peter Goldwing likes this.
Old 02-25-2019, 10:19 AM   #8
Rewards Points: 1,640
Imo, which really doesn't matter, if the laundry is in the garage then there is no reason to have afci on it. Btw, it is arc fault not arch fault.
I think this may be an inspectors call.
I can't help it if I'm lucky
Old 02-25-2019, 02:22 PM   #9
Going_Commando's Avatar
Rewards Points: 1,538
It's the "laundry area" regardless of whether its in a bathroom, basement, garage, or hall closet, thus it needs afci protection.
HackWork and lighterup like this.
Old 02-25-2019, 04:08 PM   #10
Rewards Points: 274
Well Im pleased that Im not the only one confused about the arcH fault. In my opinion assuming that we have a device arching, its still away in the garage therefore no need for AFCI. If Its wiring we are trying to prevent from arching (????) then any wires ran into the wall between the house and garage would have to be protected by AFCI.
This is what I got from a Google search:
"The effective date is December 31, 2017. The NEC is adopted in Florida with no state amendments"
Old 02-25-2019, 04:21 PM   #11
So if a washer is outdoors you think an afci is required? Yes I have seen them outdoors. I still say it is an authority having jurisdiction call but if you think about the areas that need afci then I would think the washer in the garage is not that area. It would be foolish, IMO, to require the washer to be afci in a garage and nothing else.
Old 02-25-2019, 04:23 PM   #12
There's a million foolish things in the code that you have always agreed needed to be followed just because the code says it. Why rationalize now?
MTW likes this.
Old 02-25-2019, 05:02 PM   #13
Watt Pusher
B-Nabs's Avatar
Rewards Points: 470
An arch is an architectural feature. An arc is an electrical phenomenon. Electrical devices don't "arch". And AFCIs don't mitigate "arch faults", which I assume would consist of a structural collapse of some kind.
DashDingo likes this.
Old 02-25-2019, 08:58 PM   #14
Rewards Points: 274
I've got the idea. That was a sarcastic answer to Dennis Thats why I wrote arcH with upper case H. So ArcH fault it is
Old 02-25-2019, 09:11 PM   #15
MTW
Rewards Points: 9,924
I never install arc fault breakers if the laundry area is in the basement.
Old 02-25-2019, 09:11 PM   #16
Rewards Points: 274
We had an electrical supplier in Monroe named Arch Electric. I dont exactly know why they named it such And they called it Arc not Arch as in cheese
Old 04-04-2019, 02:17 PM   #17
Rewards Points: 20
Any area where there is a washing machine and it's required plumbing becomes the laundry area. Also, GFCI protection is also required.
lighterup likes this.
Wiredindallas is offline   Reply With Quote
Old 04-04-2019, 02:54 PM   #18
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,198
I use a dual function because another code in the 17 cycle states all 120 volt outlet receptacles must be 20 amp & have gfci protection ( not just that sink rule anymore) and then the afci section sais that is needed in Laundry areas
as well.
I really hope I Offered something of value this time...errrrrr.
Old 04-10-2019, 03:56 PM   #19
Rewards Points: 193
It was the 2014 NEC that was adopted in FL on 12/31/17.
czars is offline   Reply With Quote
Old 04-10-2019, 05:35 PM   #20
sbrn33's Avatar
Rewards Points: 3,482
I have visited the arch in St Louis. Nebraska has an arch but not near as big.
Cabo has my favorite arch.
On the other side Noah built a really nice ark but it stank like crap.
Tripping AFCI fred122 Residential Electrical Forum 3 01-25-2019 10:10 PM
several questions about the new receptacles AFCI breaker rules mike883 Canadian Electrical Forum 7 09-04-2017 10:00 AM
2-005(a) is it safe to say that... NDC Canadian Electrical Forum 57 09-21-2016 08:03 PM
AFCI Omissions Wentez Canadian Electrical Forum 1 01-22-2016 01:03 PM
AFCI in 2017 manchestersparky NEC Code Forum 103 01-13-2016 07:47 PM
