Detached Garage - GROUNDING - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 1 Post By Dennis Alwon
  • 2 Post By HackWork
  • 2 Post By Bird dog
  • 1 Post By dogleg
  • 1 Post By tmessner
Old 05-14-2020, 11:37 AM   #1
SRG
Default Detached Garage - GROUNDING
Hey Guys,
Running a 100 AMP subpanel off meter box on the house.
I'm running 1/0 aluminum triplex.
Question: Do I need to run a ground with that or just pound ground rods at the garage? I'm not finding it in the code and I know it can be state specific. But can anybody help me out with NEC guidelines or an article to check out?
Thanks!
SRG is offline   Reply With Quote
Old 05-14-2020, 11:47 AM   #2
Bird dog's Avatar
Rewards Points: 2,058
Since you're an apprentice, ask your jman. Secondly, this is considered DIY, since, this is on your own house. The mods will sort this out.
btw when are you going to test for your card?
Old 05-14-2020, 12:03 PM   #3
Rewards Points: 2,204
You need a 4 wire cable and you need ground rods. Are you doing this for yourself or someone else?
250.32
tmessner likes this.
I can't help it if I'm lucky
Bird dog (05-14-2020)
Old 05-14-2020, 12:13 PM   #4
Rewards Points: 1,283
Yes, which is why you need to know the exact code in the state you are working before you do anything.
tmessner and Bird dog like this.
Old 05-14-2020, 03:57 PM   #5
Rewards Points: 2,895
This place really needs the 3 question quiz like @Majewski has over at C. B. E.
Kevin for Moderator
Swampy doesn't want the job
* Make Electriciantalk Great Again! *
Old 05-14-2020, 04:16 PM   #6
Bird dog's Avatar
Nah...a one time nuisance charge with a major credit card.
John Valdes and Easy like this.
Old 05-19-2020, 09:42 AM   #7
cool cat
Rewards Points: 335
If your coming off a meter base with add on lugs( before any mains) to a detached garage, isnt it ok to run a 3 wire and drive ground rods at the garage.
mbednarik likes this.
dogleg is offline   Reply With Quote
Old 05-19-2020, 10:28 AM   #8
In that case it would be compliant. I didn't realize that was what the op was asking. I assumed a meter main
Old 05-19-2020, 10:58 AM   #9
cool cat
Rewards Points: 335
yep I assumed it was just the meter base but it could be either.
Here in our part of the country fewer and fewer on the house and a meter/panel combo at pole.As long as no other breaker spaces except main 200 amp breaker we can run a 3 wire. Weve gone back and forth on this rule so the poco changed to just a meter and a main to avoid service inspections.
I have heard rumors that a main breaker will be required on the outside of the house for 2020 NEC.I wonder if this disconnect on the pole sometimes 200 feet away will satisfy this rule?
Old 05-19-2020, 02:23 PM   #10
Rewards Points: 908
Our code classes said that will qualify as the "emergency disconnect". Midwest Electrical Seminars
dogleg likes this.
Tags
detached garage, grounding
