Distance Between Outlets on Different Phases - Electrician Talk - Professional Electrical Contractors Forum
Like Tree24Likes
Old 04-15-2019, 02:32 PM   #1
Rewards Points: 22
Default Distance Between Outlets on Different Phases
Are there rules or guidelines on residential outlets (120V) for keeping a single phase in a room or keeping outlets that are on opposite phases at a distance where an average person couldn't be exposed to the 240v across both phases within their reaching distance?
I tried searching but I'm sure I'm not using the professional terminology for what I'm trying to ask.
geobrick is offline   Reply With Quote
Old 04-15-2019, 02:52 PM   #2
Rewards Points: 10,179
240V is single phase. It is not plural.
John Valdes and cwsims84 like this.
Old 04-15-2019, 03:04 PM   #3
Considering a normal duplex receptacle can be split with an air gap of about 1/8” between “phases”, I say you’re good to go with an 1/8” between outlets. Is that enough?
Old 04-15-2019, 03:17 PM   #4
Rewards Points: 1,781
Electrical engineer everyone. You saw it here...
There are 2 types of electrician... Those who knowingly break code, and those who lie about it.
Old 04-15-2019, 03:22 PM   #5
Band Member
emtnut's Avatar
Rewards Points: 432
I hope you didn't measure that with a metal tape
When this thread gets closed, OP will be battin' a 1000
99cents likes this.
Old 04-15-2019, 03:23 PM   #6
Band Member
emtnut's Avatar
Rewards Points: 432
It's really what keeps bringing me back
HackWork and tjb like this.
Old 04-15-2019, 04:05 PM   #7
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 200
Wha da fuq? Article 210 of the NEC, go learn it, love it, live it. I understand you're an electrical engineer...so how do you call out the circuits for said room if you don't understand phasing and distance?
*Not trying to be an ass, seriously trying to help you out and inquiring.
99cents likes this.
When in doubt, run in circles, scream and shout.
TheLivingBubba is online now   Reply With Quote
Old 04-15-2019, 04:15 PM   #8
Rewards Points: 22
I suppose the 240v is a single phase but when measured to the center tap of the transformer, aren't the two 120v 'halves' 180 deg out of phase?
Old 04-15-2019, 04:21 PM   #9
No, it’s an Edison 3 wire.
Old 04-15-2019, 04:37 PM   #10
Rewards Points: 22
Thanks. I'll take a look at the Article.
I know I'm posting to a professional's forum so the jabs are expected. As far as "Not trying to be an ass" goes, you have to be pretty good at something to do it without trying.
readydave8 likes this.
Old 04-15-2019, 04:38 PM   #11
Rewards Points: 22
Got it. Thanks
Old 04-15-2019, 04:40 PM   #12
Bird dog's Avatar
Rewards Points: 844
OP is possibly an engineer trainee in which case he needs to ask his boss or hire an electrician depending on the situation.
Old 04-15-2019, 04:51 PM   #13
Rewards Points: 4,004
This is the same guy who groups homeruns (1,2,3) and (8,9,10...)
Old 04-15-2019, 04:54 PM   #14
Bird dog's Avatar
Rewards Points: 844
Trunkslammer EE
Old 04-15-2019, 05:23 PM   #15
Rewards Points: 22
I get what your point is but my question isn't whether the 220/240 can be within same outlet or junction box. My question is more about; Lets say someone has a metal toaster oven and a metal hotplate that are plugged into separate outlets on separate circuits (each using a different hot side of the 3 wire Edison configuration).
Now say the unlikely situation occurs where both appliances fail where the hot line is shorted to its metal case. This would create a dangerous situation that could be prevented if there were some restriction on where you can put outlets that are on a different legs of the 3 wire feed. I'm not saying I want there to be a restriction or that it's even warranted in this case. I just wanted to know if there were any restriction. Seems the answer is no. I'll look at article 210 to see what it says on this subject.
Old 04-15-2019, 05:27 PM   #16
Rewards Points: 22
Did my profile give it away or was it the words I used in my post? I'll either have to change my profile or hang out with more electricians.
Old 04-15-2019, 05:32 PM   #17
Rewards Points: 22
That one is over my head. My only reply is I wish I could group my homeruns but I've never hit one in my life (though I'm sure I've given up a few).
Old 04-15-2019, 06:30 PM   #18
tjb
Cool Kid
Rewards Points: 363
Curious why you appear to see 240V as dangerous to touch but 120V as fine. Am I reading you correctly?
tjb is offline   Reply With Quote
Old 04-15-2019, 07:06 PM   #19
Rewards Points: 22
You are reading me correctly but in the scenario I posted earlier, there would be 0v between the cases of the toaster oven and hotplate if they were on the same circuit. But if they were plugged in to outlets on separate sides of the 3 wire feed, there would be 240v between the cases. So in this case I've comparing 0v to 240v.
While I'm sure either can kill, my understanding is that in an apples to apples situation, 240v would be able to support a higher current through the 'load' but I really haven't researched that. Based on your question I assume you're saying I shouldn't assume 240v is more dangerous?
Old 04-15-2019, 08:16 PM   #20
Which is precisely why, before fixing a snack, I suit up with the proper PPE. The risk of an arc blast in the modern kitchen is just too great to take shortcuts.
2 30A outlets in parallel Civiccrown General Electrical Discussion 9 06-01-2018 02:59 PM
UPS 2 phases of a 3 phase subpanel vinister Alternative Energy Forum 4 07-12-2017 02:50 PM
Continuity Between 2 Phases of 240V Plug Azachi Canadian Electrical Forum 13 02-16-2017 09:00 AM
Multiple GFCI outlets on one branch NJMike Residential Electrical Forum 17 01-16-2017 12:09 PM
How to install a new outlets on prexisting wall VanillaSnake21 General Electrical Discussion 2 04-24-2016 07:24 AM
