Motor Ciruit Breaker Switch - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 1 Post By gpop
  • 2 Post By CoolWill
  • 1 Post By emtnut
  • 1 Post By emtnut
  • 1 Post By oliquir
  • 1 Post By Signal1
Old 06-11-2019, 09:06 PM   #1
Default Motor Ciruit Breaker Switch
Hello,
I have a connector with 480VAC and I need to connect 2 motors (one at a time with the selector switch) FLA 6.5 and 2.85. Obviously these require different circuit protection.
Is there a rule in the NFPA70 (replacement of the NEC), which says we cannot use a control relay to select the appropriate CB or the motor?
CB1, CB2 - circuit breakers
M1, M2 - motors
---||---CB1---(M1)--
---|\|---CB2---(M2)--
alexbeatle is offline   Reply With Quote
Old 06-11-2019, 10:35 PM   #2
Rewards Points: 21,898
Here the thing .,, are you legit electrician or maintenance personal ?
If you are electrician then please fill the profile fourm.
the reason why I asked to fill it out because the answer will varies a little depending on which side of national border line is. ( CEC or NEC )
Old 06-12-2019, 12:36 AM   #3
As per the original posting, the question is per NFPA70 -> NEC
Old 06-12-2019, 12:45 AM   #4
Cow
Rewards Points: 5,124
Why do both motors have to use the same "connector?"
Why not two "connectors" with a selector switch to energize one or the other?
Old 06-12-2019, 01:26 AM   #5
The motor connectors are identical and have to stay this way -> constraint. To save on components, I'm questioning whether its valid/legal to have one circuit with a switch for the CB's for different motors.
Old 06-12-2019, 06:17 AM   #6
CoolWill's Avatar
Rewards Points: 638
As long as the circuit is protected by an appropriate breaker or fuse, then it can feed other breakers downstream no problem.
Old 06-12-2019, 06:18 AM   #7
Rewards Points: 2,666
circuit breakers don't protect the motor they protect the wire and fault clearing.
The question makes no sense to me as its lacking details.
480 single phase?
internal thermal protection motors?
Old 06-12-2019, 10:09 AM   #8
480 single phase?
Circuit breakers protect device, that's why you choose them by the FLA.
Fuses protect the wires, that's why you choose them based on the wire size.
The topic is closed as I've gotten my answer elsewhere.
Thank you, all.
Old 06-12-2019, 10:15 AM   #9
CoolWill's Avatar
Rewards Points: 638
That's just silly.
Thank you, all.
I'll let you know when the topic is closed!
Flyingsod and Bird dog like this.
Old 06-12-2019, 10:20 AM   #10
Band Member
emtnut's Avatar
Rewards Points: 2,514
That is not correct
Thank you, all.
Makes me wonder what 'diyer' answered your question.
Anyways, thanks for stopping by, and filling out your profile like the Moderator asked
Flyingsod likes this.
Old 06-12-2019, 10:21 AM   #11
Band Member
emtnut's Avatar
Originally Posted by CoolWill View Post
That's just silly.
Hi Willy
CoolWill likes this.
Old 06-12-2019, 10:46 AM   #12
Rewards Points: 2,108
Thank you, all.
Greatest post ever
So all of my wires are not protected in my house since i have no fuses
Old 06-12-2019, 10:49 AM   #13
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,550
Wrong -NFPA70 is the NEC
Wrong again- Hire an electrician.
Old 06-12-2019, 01:06 PM   #14
Originally Posted by oliquir View Post
Greatest post ever
You're correct, I did not explain myself correctly.
Either fuse or CB can be used as a ground-fault or short circuit protective device.
When it comes to motor control circuit, you may put a Fuse\CB as per the device requirements and Fuse\CB as per the wire requirements.
Old 06-12-2019, 04:09 PM   #15
Wardenclyffe's Avatar
Rewards Points: 626
I'm still hung up on Connectors or Conductors,...
Wardenclyffe is online now   Reply With Quote
Old 06-13-2019, 08:53 AM   #16
Zog
Zog's Avatar
Rewards Points: 1,096
Ground fault protection fuses?
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
