Tandem breaker question - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By HackWork
  • 1 Post By WPNortheast
Old 03-14-2019, 07:14 AM   #1
blueheels2's Avatar
Rewards Points: 332
Default Tandem breaker question
I have attached a picture of GE TM 3020 panel that a customer would like to add another circuit to. As you can see tandems have been installed already but I’m not sure that is correct. Normally I would check the label on the panel door and it would give me all of the relevant info however in this instance the label is ripped and torn off. The only info I can see is a stamp in the box that says it is a tm 3020. Pretty sure after researching this means 30 space 200 amp. Could be 30 circuit though meaning the panel is a violation at this point.
House was built in 79’ and it is the original panel.
Thanks
Tandem breaker question-0ad01ff1-f52c-4679-a49a-a42d2d778018_1552561953791.jpg
blueheels2 is offline   Reply With Quote
Old 03-14-2019, 07:30 AM   #2
Rewards Points: 1,605
I don't know much of anything about GE panels.
Those aren't actually tandems, they are skinny breakers. And it's my understanding that if they fit, they are ok to use in it (similar to normal tandems being locked out if they aren't supposed to be used). So you should be able to remove one of the full size breakers on the left bottom and replace it with 2 skinny's.
Old 03-14-2019, 07:38 AM   #3
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,688
Yeah, what Hack said, the fun part will be the neutral bar.
I hate to see her go, but I sure love watching her walk away.
Old 03-14-2019, 08:24 AM   #4
Yeah, even if there are enough circuits left in the panel, the neutral bar often gets filled up. I usually just take a bunch of grounds off and wirenut them together.
CTshockhazard likes this.
Old 03-14-2019, 10:32 AM   #5
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
Originally Posted by blueheels2 View Post
I have attached a picture of GE TM 3020 panel that a customer would like to add another circuit to. As you can see tandems have been installed already but Iím not sure that is correct. Normally I would check the label on the panel door and it would give me all of the relevant info however in this instance the label is ripped and torn off. The only info I can see is a stamp in the box that says it is a tm 3020. Pretty sure after researching this means 30 space 200 amp. Could be 30 circuit though meaning the panel is a violation at this point.
House was built in 79í and it is the original panel.
Thanks
That looks like a 3040 to me...especially if its a 200 amp main. I think you would be fine to use the thin style GE breakers on the left.
Old 03-14-2019, 09:31 PM   #6
WPNortheast's Avatar
Rewards Points: 184
Bottom 3 on left are all prime for turning into THQPs.. Neutral bar is open too.
lighterup likes this.
WPNortheast is offline   Reply With Quote
Old 03-14-2019, 10:03 PM   #7
ppsh's Avatar
Rewards Points: 166
If the breaker space accepts a THQP, it is legal to do so. The bus bar design is different where it accepts THQPs.
ppsh is online now   Reply With Quote
Old 03-16-2019, 01:26 AM   #8
blueheels2's Avatar
Rewards Points: 332
Thanks guys!
Old 04-04-2019, 01:02 PM   #9
Rewards Points: 20
GE thin breakers will only go where there is a T shaped bus slot as the thin breaker mount is completely different than the thick breaker space or any other brand. Looks like a mixture of breaker brands in there already. Not the best looking panel I have seen.
Wiredindallas is offline   Reply With Quote
Non-continuous breaker rating/ CSA pratice tool Mcarthur00 Canadian Electrical Forum 6 10-02-2017 01:28 PM
Non-continuous breaker rating/ CSA pratice tool Mcarthur00 New Member Introductions 2 10-01-2017 11:43 AM
Creating a "service call kit" for your second truck HackWork Business, Marketing, and Sales 41 04-07-2017 12:12 PM
AFC breaker Tripping? Darg87 Canadian Electrical Forum 10 05-29-2016 10:18 PM
what is the differences between inverse time circuit breaker and regular breaker? mike883 General Electrical Discussion 17 05-22-2016 03:47 PM
