Burning out of return side - Electrician Talk - Professional Electrical Contractors Forum
Like Tree17Likes
  • 3 Post By just the cowboy
  • 2 Post By MechanicalDVR
  • 1 Post By circuitman1
  • 1 Post By MechanicalDVR
  • 1 Post By MikeFL
  • 2 Post By David C
  • 1 Post By emtnut
  • 1 Post By telsa
  • 2 Post By HertzHound
  • 1 Post By VELOCI3
Unread 03-07-2019, 08:38 AM   #1
Default Burning out of return side
I’ve come across a few circuits in Berkeley that have been failing on the return side of 120 volt receptacles? Arcing enough to melt the face of device, in a recent kitchen remodel 2006? All inspected but failing where 1500 watt appliance have been used not old appliances? I believe all were 20amp leviton devices, all new Romex circuits? Possibly just poor workmanship? No loose connections that I’ve found?
tomjahnson is offline   Reply With Quote
Unread 03-07-2019, 09:09 AM   #2
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,548
Arcing, enough to melt the face of a device, is a connection issue.
Arcs happen between gaps in conductive surfaces that have current flowing across them.
Were you born retaŕded or did you pick that up on your own?
CTshockhazard is online now   Reply With Quote
The Following 2 Users Say Thank You to CTshockhazard For This Useful Post:
tomjahnson (03-07-2019), VELOCI3 (08-19-2019)
Unread 03-07-2019, 09:56 AM   #3
Thanks
Unread 03-07-2019, 12:19 PM   #4
just the cowboy's Avatar
Rewards Points: 72
Are they backstabbed? Quite common.
The Following User Says Thank You to just the cowboy For This Useful Post:
Unread 03-07-2019, 03:10 PM   #5
Rewards Points: 2,834
Curious, where are you from that you use the term "return side"?
circuitman1 and MikeFL like this.
Unread 03-07-2019, 03:47 PM   #6
Rewards Points: 660
you need to fill out your profile, or this thread will be locked!
John Valdes likes this.
circuitman1 is offline   Reply With Quote
Unread 03-07-2019, 04:27 PM   #7
MikeFL's Avatar
Rewards Points: 456
I think he's in Cali.
Berkley?
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Unread 03-07-2019, 06:33 PM   #8
Rewards Points: 21,856
To OP .,,
are you legit electrician or not ? because the key word is return line that is something we genrally dont say it.
I will give you 24 hours to come up with info otherwise this thread will be locked.
John Valdes (08-12-2019)
Unread 03-08-2019, 12:04 AM   #9
Berkley?
I've spoken to many Californians and never heard it phrased like that before.
You?
circuitman1 likes this.
Unread 03-08-2019, 12:37 AM   #10
MikeFL's Avatar
Rewards Points: 456
Never.
GPS Timers
(833) GPS-TIME
Unread 03-08-2019, 01:55 AM   #11
Rewards Points: 17,705
Wait a minute fella's ........... maybe a fault on a zig zag primary came up the GE and got into the neutral bus............. Nah..
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Unread 03-08-2019, 10:15 AM   #12
I haven't heard of a primary Zig Zag fault since high school!
Unread 03-10-2019, 09:50 PM   #13
Pull my wire
Rewards Points: 246
Must be french canadian, coz we say that all the time in french "sur le retour du circuit", aka on the return side. But no Berkeley around here and that does sound like a Cali city.
Sounds like bad connection from poor workmanship and using cheap appliances with tiny cords for a little bit too long.
MechanicalDVR and MikeFL like this.
David C is offline   Reply With Quote
Unread 08-12-2019, 04:27 PM   #14
Rewards Points: 42
fmwowol is offline   Reply With Quote
Unread 08-12-2019, 05:19 PM   #15
Band Member
emtnut's Avatar
Rewards Points: 1,848
telsa likes this.
Unread 08-12-2019, 05:23 PM   #16
Rewards Points: 26,360
Obviously, you can't say that enough.
Unread 08-12-2019, 06:16 PM   #17
HertzHound's Avatar
Rewards Points: 1,164
I wonder what his thoughts are on 14 gauge pigtails on 12 gauge wire.
“Why say lot words when few words do trick”
Unread 08-13-2019, 11:10 AM   #18
Rewards Points: 3,930
5 months for your fan @CTshockhazard.. lol..
@MechanicalDVR
Unread 08-19-2019, 07:39 PM   #19
Sounds like the system is out of balance by at least 20 wc
Nobbler is offline   Reply With Quote
Unread 08-19-2019, 10:28 PM   #20
VELOCI3's Avatar
Rewards Points: 100
We have a saying here in NY about Rube Goldberg type wiring. Well we either call it that or California wiring.
But seriously it sounds like you have a phantom phase on the downstream neutral.
Grounded-B likes this.
VELOCI3 is online now   Reply With Quote
How much do I charge? (side job) JasonCo General Electrical Discussion 96 07-04-2018 10:56 AM
Harmonics on load side of transformer Flex277 Commercial Electrical Forum 17 03-04-2018 10:31 PM
VFD-Line Side Readings AaronJ PLCs, VFDs, Motors and Controls 7 10-20-2017 03:32 PM
Line and Load side? JasonCo General Electrical Discussion 7 04-05-2017 01:09 AM
