15kV switchgear cable pulling - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Trade Topics > Linework
Like Tree13Likes
  • 2 Post By frenchelectrican
  • 6 Post By Cow
  • 1 Post By Tonedeaf
  • 2 Post By kartracer087
  • 1 Post By kartracer087
  • 1 Post By wcord
Old 01-30-2019, 07:35 PM   #1
Rewards Points: 14
Default 15kV switchgear cable pulling
Hi,
I'm wondering if anyone has used pullers like the Greenlee Super Tugger for pulling medium voltage cable and if you have ever pulled the cable through the puller's sheaves at a 90 degree bend. Was wondering for a job set up where the cable leaves the switch from the top rear of a 15kv switch and needs to be pulled from the front of the gear since there is a wall behind the gear. Not an electrician myself (consulting engineer) but wanted to know how that typically gets done in the field.
Thanks.
kartracer087 is offline   Reply With Quote
Old 01-30-2019, 08:04 PM   #2
Rewards Points: 7,915
All the time. Try to avoid 90 degree pulls, but sometimes it can't be helped. There are many different types of rollers, shieves, pulley's, radius's, etc. to choose from. You can't pull some of those big cables by hand. But sometimes you can, with a big enough crew.
Old 01-30-2019, 08:12 PM   #3
Rewards Points: 21,898
Originally Posted by kartracer087 View Post
Hi,
Thanks.
First of all .,, welcome to electrician talk.,,
now you mention cable pullers yes it been done pretty often with med voltage cable but just be aware do not make sharp 90° bends and what size and type of cable is your crew will be pulling ? they will know the excat details to prepare it correct on cable pulling.
but if it was a very short run it can be done with hand pulling with extra personal on hand.
and yes the crew will using the wire pulling lube gel to make it easier to slide the cable.
sparkiez and kartracer087 like this.
Old 01-30-2019, 08:14 PM   #4
Cow
Rewards Points: 5,124
Just pay attention to your spec'd cables minimum bending radius.
We just pulled several hundred feet of 35kv CLX cable in. Our minimum bending radius was 28-29 inches, so we ended up using 36" radius rollers. It just passed a 55kv hipot, so I know we're good to go.
kartracer087 (01-30-2019)
Old 01-30-2019, 11:58 PM   #5
Rewards Points: 14
Thanks for the replies guys, yeah that was my concern as most of the puller boom arms have sheaves which are about 12" in diameter (6" radius) so if you pull the cable tight to the puller's sheave you will overbend the cable. So I think you would need to use a 24" roller sheave which gives you a full 24" radius which would cover 15kV cables up to 500kCMIL if you consider max bend radius is 12 times diameter of cable. Since the roller sheave would be placed in the gear I would think you could just build a simple steel frame and bolt it down as needed.
Old 01-31-2019, 06:57 AM   #6
I would use much larger pully wheel size if possible as Cow mention on his posting the larger it go the better it reduce the chance of damage the med/high voltage cable.
12 inch wheel is good for squat cuz it will kinda tick ya off on that..
If you have plenty room then try to find the larger wheel and get the biggest one if possible., I done 4 conductor 240mm˛ SWA cable (about the same as 500 KCM) that I have to use 30 inch wheel ( that was the smallest size the cable manufacter will allow for sharp bend ) I would use 48 inch or 1200 mm wheel if I have a room for it.
Old 01-31-2019, 08:47 AM   #7
Rewards Points: 1,116
we rarely use a puller........most runs are by hand with wheels/rollers/pulleys. You gota work angles. Straight in, Straight out.
I dont know what size and type you are pulling, but #2awg-1/0 XLPE cable pulls pretty easy.
kartracer087 likes this.
The Following User Says Thank You to Tonedeaf For This Useful Post:
kartracer087 (08-11-2019)
Old 01-31-2019, 06:13 PM   #8
Rewards Points: 14
Here is kind of what I'm thinking may be possible. Again, I'm not an electrician just mainly asking to understand the installation a bit better for planning. I'm probably one of the few engineers who tries to look at what the contractor actually has to do to get things set up and I try to design around that aspect. If it doesn't make sense to install I probably won't try and design it that way!
sparkiez and Paul SA like this.
Old 01-31-2019, 06:14 PM   #9
Rewards Points: 14
Old 01-31-2019, 06:23 PM   #10
Rewards Points: 14
So here is a link to what I was trying to post but I cannot because I have only made 4 posts total. Just remove the quotation marks. Sorry for the duplicate posts!
''https://ibb.co/vccFpDb''
Old 02-26-2019, 10:57 AM   #11
Rewards Points: 12
Request a power cable manual from Southwire or Okonite. It has good information on cable pulling and equations you can use to calculate pulling tension, sidewall pressure, etc.
chuckd83 is offline   Reply With Quote
Old 02-26-2019, 01:29 PM   #12
Rewards Points: 26,838
The industry has trick compound sheaves that provide a very relaxed radius for such cables.
Greenlee:
636 -- 16"
637 -- 24"
638 -- 36"
631 -- 48"
Also
Sherman+Reilly has a slew of sheaves.
Strangely, you can't come up with a problem that's never been faced before.
Old 08-11-2019, 06:51 PM   #13
Rewards Points: 14
Yes, the other thing I thought of which is helpful if you are pulling into gear that is tight or has restricted access is to do the pulling from another box location and do the feed in at the gear. This way you can have a couple guys feed the cable into the gear (with a little slack) as its being pulled rather than have to create more complicated rigging for rollers inside the gear. At the other end you can have a simple puller set up to pull it straight out through the box.
Paul SA likes this.
Old 08-11-2019, 08:09 PM   #14
Rewards Points: 20,929
You can also setup two sheaves set at 45 deg apart with distance between them so that any 90 deg turn is limited to actually being a 45 deg turn. I used to pull fiber optic cables and that was a trick I learned to stay within manufacturer spec.
Work out the triangle spreads from your 8th grade geometry book.
If the pull is inside an underground vault and you have to change direction 90 deg, pull the whole cable out thru the manhole , run a figure 8 with it and send it back down the other direction as a second pull.
Old 08-12-2019, 07:41 AM   #15
wcord's Avatar
Rewards Points: 2,068
one of the best electrical engineers I had the privilege (word I seldom use in conjunction with engineer) to work with, would come into the field and actually get his hands dirty working with the guys.
He also, wanted to understand how field conditions affect installations.
Paul SA likes this.
If you didn’t serve an apprenticeship, you're not a tradesman. You are labor.
Old 08-12-2019, 10:58 AM   #16
Paul SA's Avatar
Rewards Points: 148
Default best way
if i understand it correct and You just need to connect inside the specific panel, or need a short peace of cable on the other side.
this is the best practical way of doing it ( been doing it like that for the last 20 years) the slack (span) of 20-30 m is easy to handle (4-6 guy's)and i have done it up to 300mm x 3 core 11kv XLPE cable before
Paul SA is offline   Reply With Quote
gfci breaker b-cap General Electrical Discussion 20 06-15-2018 02:57 PM
Flexible Cable. Disconnected from reality Junky Cosmo Code Violation Discussion 3 01-11-2018 12:50 PM
Ground/Shield VFD cable termination Kris Wu General Electrical Discussion 8 07-07-2016 12:58 PM
