Lighting Fixtures - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 1 Post By Forge Boyz
  • 2 Post By macmikeman
  • 1 Post By WronGun
Old 09-08-2019, 08:06 PM   #1
WronGun's Avatar
Rewards Points: 702
Default Lighting Fixtures
I’m having a hard time trying to update these fixtures. Currently a FL fixture with rough cut-out of 23x9.
Looked at some mainstream brands with no luck. I’ve seen the rectangular housings with 3 adjustable heads inside. I’m looking for something more low profile with led diodes and maybe a reflector for non-direct down lighting. This is a historical museum/visitor center I keep getting directed to cheaper imports on amazon.
Any suggestions?
WronGun is online now   Reply With Quote
Old 09-08-2019, 08:19 PM   #2
Switched's Avatar
Rewards Points: 10,332
Does it need to be directional or can it just light the space?
Old 09-08-2019, 08:59 PM   #3
WronGun's Avatar
Rewards Points: 702
Does not needs to be directional. Currently is a FT40 lamp tucked into the lower corner and a big reflector directing the light downward to the floor.
Old 09-08-2019, 09:24 PM   #4
Rewards Points: 58
What about an LED tube in the existing fixture?
Sent from my SM-G970U1 using Tapatalk
WronGun likes this.
Old 09-09-2019, 08:15 AM   #5
jw0445's Avatar
Rewards Points: 1,956
One with ballast bypass too! Getting them for less than 10 bucks a piece.
Old 09-09-2019, 08:56 AM   #6
Rewards Points: 1,965
Talk to a local lighting guy. Make those bastids work for a living.
Amazon is not the place for lighting advice.
Old 09-09-2019, 10:21 PM   #7
Rewards Points: 3,035
1+ on the LED retrofit tubes. If that is a no go, install a 1x4 edge lit LED fixture over the existing holes. If you mention @MTW by name, HD will sell them to you at the special Peter D discounted rate of $99.97 each
Take the old fixtures out and throw some lumber in between the existing frame in the ceiling to support the new lights. Leave the white trim/frame in the ceiling
Old 09-09-2019, 10:53 PM   #8
Rewards Points: 20,929
Another route is the cool replacement system with a driver that has magnets built into the case so installing it is as easy as placing it against the metal frame of the fixture , and it comes with output lines with snap together connectors for the wires going to some led lamp tubes they also produce, which also have rare earth magnets attached so they are placed super fast to the metal skin of the light. Then all you need to do is wirenut to supply power. I've changed out t-bar troffers with this system in 1 minute and just unwire the old ballast and lamps and leave em in place and stuck the other system in right around the old gear and slammed the cover shut . Looks exactly like 48" tubes are installed . They are mental they are so good.
WronGun and chongo like this.
Old 09-10-2019, 09:52 PM   #9
WronGun's Avatar
Rewards Points: 702
I’ve decided to go for the direct wire FT40 replacements. Easy peasy
jw0445 likes this.
