Lighting Layout in Garage - Electrician Talk - Professional Electrical Contractors Forum
Like Tree17Likes
  • 3 Post By HackWork
  • 2 Post By splatz
  • 2 Post By 99cents
  • 1 Post By A Little Short
  • 1 Post By frenchelectrican
  • 3 Post By NoBot
  • 1 Post By The_Modifier
  • 1 Post By 99cents
  • 1 Post By NoBot
  • 1 Post By CADPoint
  • 1 Post By Easy
Old 01-01-2020, 09:28 PM   #1
A Little Short's Avatar
Rewards Points: 1,196
Default Lighting Layout in Garage
I need to provide lights in a residential detached garage. It is 24' x 24' with 10-12' ceilings. No special work will be done, mainly tinkering and storage. They want 4' LED strip lights.
How many lights would you use in this layout, and how far apart?
I figured 9 lights in 3 rows of 3, spaced 6' on center apart.
Planned on 4' tubes 5k
Old 01-01-2020, 09:35 PM   #2
Rewards Points: 450
This garage is about 24 x 28‘. It’s being used as a workshop. I installed 8 4 foot LED lights. I hung them on chain at a height of about 7 foot, maybe slightly higher. The customer is very happy with the brightness.
Old 01-01-2020, 09:52 PM   #3
Attachment 139354
I wired one a while back and used 6. That's what I was going to use in this. But the owner wanted to be sure it was bright enough. So this layout might work.
Old 01-01-2020, 10:22 PM   #4
Rewards Points: 21,863
I have wired countless shaping rooms for surfboard shapers. They like strip lights mounted sideways along the walls at desk height.....
I stand with Tucker Carlson
dronai (01-01-2020)
Old 01-01-2020, 10:36 PM   #5
dronai's Avatar
Rewards Points: 439
I'm sure that will help him in his choices
Old 01-01-2020, 10:57 PM   #6
Rewards Points: 2,878
I ran the LBL4 LP840 through the Lithonia calculator and they come out nice and bright in a 3x3 spacing, nothing you're going to get a sunburn from but plenty of light for storage and tinkering.
Amazon has them for $80
https://www.amazon.com/Lithonia-Ligh.../dp/B06XJDRCZK
A Little Short and MHElectric like this.
Old 01-01-2020, 11:18 PM   #7
Rewards Points: 3,029
Lithonia, 4’ strip mounted at 12’.
Lighting Layout in Garage-d56e48e6-7f7c-4397-8fe8-b192c374368d.jpg   Lighting Layout in Garage-d3eb34e8-6e61-4e48-92dd-d31d97542e6c.jpg
Old 01-02-2020, 12:30 AM   #8
Those are exactly how I had it drew up with my 3 rows of 3 that I described in my OP.
Old 01-02-2020, 01:01 AM   #9
Modrateur
Rewards Points: 21,898
I would go in 3X3 pattern as well but be aware of garage door opener hardwares it may affect the location where you put the two luminaires that you may have to offset about 30 cm one way or other depending on how the trusses or rafter run.
useally LED wrap around useally do it pretty decent if you keep it up high.
Old 01-02-2020, 03:04 AM   #10
You would go 8’ apart with 4’ to the wall.
Old 01-02-2020, 07:44 AM   #11
Rewards Points: 324
Nine Lights.
Positioning depends on the size of the garage doors. These are 9ft wide x 8 ft tall.
Open the attached .PDF for the Layout Sheet
cburke0000, C10 and VELOCI3 like this.
NoBot is offline   Reply With Quote
The Following User Says Thank You to NoBot For This Useful Post:
C10 (05-11-2020)
Old 01-07-2020, 12:37 PM   #12
VELOCI3's Avatar
Rewards Points: 118
Not a fan of 5000k. 4000k looks pure white and renders colors better than 5000.
VELOCI3 is online now   Reply With Quote
Old 01-07-2020, 01:29 PM   #13
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 728
Originally Posted by NoBot View Post
Nine Lights.
What apps are you guys using for the design layouts?
Old 01-07-2020, 05:09 PM   #14
It’s just the layout software on the Lithonia site.
The_Modifier likes this.
The_Modifier (01-07-2020)
Old 01-07-2020, 05:31 PM   #15
VELOCI3's Avatar
Rewards Points: 118
Nine Lights.
This is the layout I would use because the garage doors won’t block the light
Old 01-07-2020, 05:55 PM   #16
Acuity Brands Visual Interiors, works very well as far as I can tell, I've used it a bunch this last few months and everyone's been happy with the layouts.
Old 01-07-2020, 08:25 PM   #17
Rewards Points: 324
Chief Architect Premier ver. X11
Old 04-12-2020, 05:54 PM   #18
Rewards Points: 8
Came across a general rule of thumb awhile back, not sure if it was on a lighting website or architectural website, but I try to base my lighting off it.
-A square foot of floor space needs 20 lumens.
-A Table or raised surface needs 30 lumens.
-A workspace needs 50 lumens.
r0yal is offline   Reply With Quote
Old 04-12-2020, 06:25 PM   #19
CADPoint's Avatar
Rewards Points: 1,852
http://www.visual-3d.com/tools/interior/
You can make your own layout using the web site above. You might need to get exact ceiling height, and assume some other aspects that you didn't state
in your OP.
You might ask client if there going to have work bench and position a light over their head (not work bench). ((You know Clients they never say what they really want IMO)) It's an up sale moment, light the bench.
The + is manufactures supplied spec'd lights that you'll need to choose something to get a light layout.
Easy likes this.
If you are even thirsty, you are two quarts low.
Old 04-24-2020, 01:11 PM   #20
Easy's Avatar
Rewards Points: 1,862
I'm in agreement with that. 4000k color temperature is great for seeing fine detail when working on things. At least for us old guys who have poor eye sight.
Kevin_Essiambre likes this.
Easy is online now   Reply With Quote
