Pico Wireless on fluorescent? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By 99cents
  • 1 Post By Dennis Alwon
  • 1 Post By 3DDesign
Old 04-11-2016, 09:14 PM   #1
Rewards Points: 2,941
Default Pico Wireless on fluorescent?
I want to add a wireless switch to about ten 4 lamp troffers. Possible?
Old 04-11-2016, 09:29 PM   #2
Rewards Points: 1,360
Absolutely, even if your wireless switch relay just switches a higher current relay or contactor.
Old 04-11-2016, 11:52 PM   #3
A Little Short's Avatar
Rewards Points: 1,186
Yep!
Lutron usually includes a minimum load capacitor for small loads. I've never had to use it though. The smallest load I've run was (2) 8' 2-lamp fluor.
You should be fine with your load.
Old 04-12-2016, 05:41 AM   #4
Southeast Power's Avatar
Rewards Points: 9,234
The thing to consider is that they don't just have an off/on. They ramp up. If the customer doesn't mind that, it should work.
Old 04-12-2016, 08:58 AM   #5
Thanks, guys. You're the best .
Majewski likes this.
Old 04-12-2016, 09:59 AM   #6
Rewards Points: 2,302
You're best bet is to call their tech support as they have a pretty good one and they will let you know if this may be an issue
shocksystems likes this.
Old 04-12-2016, 11:03 AM   #7
Actually, I did, Dennis. Lutron has a good technical service line. They actually pick up the phone and know what they're talking about.
I'm good to go. The Maestro is good up to 8 amps. Fluorescent isn't an issue. The only problem is delivery. My supplier doesn't carry ivory. I'm pulling wire tomorrow .
Old 04-13-2016, 07:33 AM   #8
wendon's Avatar
Rewards Points: 54
I've used the Lutron Caseta switches. Just make sure you order the switch and not the dimmer.
Old 12-29-2017, 11:20 PM   #9
Rewards Points: 58
Oh wow they make Caseta SWITCHES? Wish I knew that a few months ago. Crossed my fingers that the dimmer would work with a contactor, no dice. Going to dig out a model number and keep it handy.
Thanks for the tip.
mdimillo is offline   Reply With Quote
Old 12-30-2017, 07:17 AM   #10
Can't Remember
Rewards Points: 1,528
They also have the wireless relays that you can nipple mount to a box. These also come in a 0-10v dimming pack that you can run with a wireless pico dimmer.
Old 12-30-2017, 08:55 AM   #11
I bought an on/off and it ramped up and down just like a dimmer.
Old 12-30-2017, 08:57 AM   #12
Rewards Points: 3,078
THIS 73 PAGE DOCUMENT is the most comprehensive that I've found on Caseta Wireless.
Switched likes this.
Greg
Old 12-30-2017, 09:26 AM   #13
Old thread but Skylink works great for on/off.
Old 12-30-2017, 11:33 AM   #14
Finally got them all in.
How did I do?
Old 12-30-2017, 02:34 PM   #15
Rewards Points: 21,615
How did I do?
That looks like a Clown Shoes job..........
I stand with Tucker Carlson
Fluorescent Lights on GFCI Receptacle Temp power box TheLivingBubba General Electrical Discussion 13 03-22-2016 10:21 PM
Wireless 3way to code? Aegis Canadian Electrical Forum 13 03-03-2016 06:27 PM
fluorescent lights install AK_sparky General Electrical Discussion 32 02-09-2016 11:56 AM
Fluorescent Lighting electricguy Lighting Design 19 02-03-2016 06:45 PM
Retrofit 3-way with Wireless SSA General Electrical Discussion 5 01-30-2016 05:36 PM
