Recessed cans - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
  • 6 Post By macmikeman
  • 2 Post By CoolWill
  • 2 Post By macmikeman
  • 1 Post By HackWork
  • 1 Post By sparkiez
  • 1 Post By telsa
Old 05-17-2019, 12:07 PM   #1
Rewards Points: 3,029
Default Recessed cans
Are recessed cans almost obsolete? I went to Bendover Electrical Suppy this week and bought some 5” cans. The dude told me nobody uses those anymore. I told him I do. For new construction, they’re better. The drywaller cuts the holes and installing trims are easy at finishing time.
I needed a couple of more 5” cans and the box stores barely carry inventory anymore. As far as I’m concerned, they still have their place. When a trim burns out, it’s easy to replace. When a Lotus style light burns out, there’s always the chance of ceiling damage when installing a new one.
Old 05-17-2019, 12:10 PM   #2
Rewards Points: 21,843
I found out about lotus lights from 99. Now he doesn't like them. Canadians
I stand with Tucker Carlson
Old 05-17-2019, 12:32 PM   #3
I know. When I first talked about Lotus Lights here, you guys thought I was the monster from outer space (no comment ).
I still like them for renos but I will throw in cans when possible. Part of the reason now is cost. A can and a 5/6” trim is the same price as a Cooper or Lithonia clamp light. If you add in the cost of the rough in ring for the clamp light, your cost goes up and you’re still dicking around at finishing time.
Old 05-17-2019, 12:38 PM   #4
Knotted Ropes Skeery
CoolWill's Avatar
Rewards Points: 2,082
I have almost stopped using cans due to wafer LEDs. Especially where placement is critical.
sparkiez and onthegravytrain like this.
Old 05-17-2019, 12:43 PM   #5
So far, the one GC guy who wants pretty much all the inside lighting to be wafer lights cuts all the ceiling holes before I return to the job after rough in. That color's my opinion of them. Right now I love the crap out of them. When I have to cut all the holes, I'm gonna change my opinion.
99cents and cburke0000 like this.
Old 05-17-2019, 01:07 PM   #6
Liberal Lesbian
Rewards Points: 374
When you first talked about pancake/wafer lights they were $60 each and we couldn't get them here.
Now that they are $25 on the high end and sometimes as low as $13 on Amazon shipped next day, they are great.
shocksystems likes this.
Old 05-17-2019, 01:09 PM   #7
Liberal Lesbian
Rewards Points: 374
On new work I agree that using conventional cans makes it easier because they cut the holes.
But for what it's worth, a grit holesaw, a dust bowl, and a 5 gallon bucket let you make the holes super quick and easy without much dust at all. If you are a man's height you don't even need a ladder for 8' ceilings.
Old 05-17-2019, 01:43 PM   #8
Old 07-11-2019, 09:33 PM   #9
Rewards Points: 20
I only like cans because the light source (bulb) is a couple inches above the ceiling and out of your eyesight. Also, you can select and change the light color and beam angle as desired.
Wiredindallas is offline   Reply With Quote
Old 07-26-2019, 12:19 AM   #10
Rewards Points: 256
OMG! is the name really bendover electric supply???? LOL Yea, I'm wondering the same thing about recessed fixtures. I'm a one man operation and I'm freakin old too, so I don't really know about new stuff and whats good and whats crap. Would actually like to put a cple dozen fixtures in my own house soon, but procrastinate because I don't know whats good anymore
joebeadg is offline   Reply With Quote
Old 07-26-2019, 07:02 AM   #11
Rewards Points: 3,078
I do a lot of new homes, I use cans. Every house I do is hard coat plaster. Cutting all those holes in hard coat would take forever and wear out a lot of blades/hole saws.
Greg
Old 07-26-2019, 08:28 AM   #12
Rewards Points: 938
We use lots and lots and lots of lights similar to these:
https://www.amazon.com/Dimmable-Equi...ateway&sr=8-18
We just set nail-on or bracket boxes. Don't take much time at all to install them, and you don't have to walk around with a box of can trims and lamps. I think I've only had one or two go bad out of close to 1000 last year.
There are other styles, but these go up the quickest and hold well.
99cents likes this.
Old 07-26-2019, 08:35 AM   #13
Rewards Points: 26,908
Go with tungsten carbide grit holesaws. You'll be amazed. Just capture the dust.
Think "Dust Bowl."
https://www.licensedelectrician.com/...s_DustBowl.htm
0day likes this.
cburke0000 (07-30-2019)
Old 07-26-2019, 09:00 AM   #14
For new construction in insulated ceilings, I put in the Eaton CLD’s now. They look fine, no customer complaints, and very little screwing around with the vapour barrier with an octagon box. If it’s an uninsulated ceiling, I lean toward cans.
GC’s love it when I throw in temporary lighting (some even demand it) and that’s tough with Lotus Lights.
Come finishing time, I want it done fast and clean. I already have 80% of my money. Hole saws and dust bowls don’t fit into the equation.
Old 07-26-2019, 10:06 PM   #15
Rewards Points: 938
There are a ton of different form factors for that type of luminary (we just call them "disc lights"). Does this one have a bracket-and-spring mounting system or do they go right into the screws on a 4" box?
Loud buzz from MLV recessed lights millsjef Residential Electrical Forum 7 07-04-2018 05:51 PM
RIP, recessed cans 99cents Lighting Design 26 02-09-2017 06:25 PM
How do you wire recessed cans in a drop ceiling? htroberts Residential Electrical Forum 14 04-24-2016 12:56 PM
Fire rated recessed cans ben franklin General Electrical Discussion 19 03-23-2016 10:40 PM
4" Non-IC cans in insulated ceilings Joefixit2 General Electrical Discussion 25 03-18-2016 11:42 PM
