Single-End Vs Dual-End Power Ballast Bypass LED Tbes - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 1 Post By Forge Boyz
  • 3 Post By rjniles
  • 1 Post By joe-nwt
Old 07-07-2019, 04:37 PM   #1
Swimmer
swimmer's Avatar
Rewards Points: 646
Default Single-End Vs Dual-End Power Ballast Bypass LED Tbes
For the LED ballast bypass tubes used as replacements for T8 and T12, which do you prefer, single-end power or dual-end power. I've used single-end power because that's what they had at Home Depot. Haven't had any call backs yet. T
Elvis is in the building
Old 07-07-2019, 04:48 PM   #2
Rewards Points: 1,409
Here's my take:
https://www.electriciantalk.com/f29/...2/#post5153580
There are 2 types of electrician... Those who knowingly break code, and those who lie about it.
swimmer (07-08-2019)
Old 07-07-2019, 05:24 PM   #3
Rewards Points: 46
Get the ones that can do either. It's one tube to stock for any application.
Sent from my XT1650 using Tapatalk
tmessner likes this.
The Following User Says Thank You to Forge Boyz For This Useful Post:
Old 07-08-2019, 07:02 AM   #4
With double ended tubes, you can use/reuse shunted or non shunted tombstones. With single ended they must be non shunted.
Sent from my RCT6213W22 using Tapatalk
John Valdes, HackWork and tmessner like this.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Old 07-08-2019, 07:15 AM   #5
Which ones are you talking about?
Old 07-08-2019, 08:06 AM   #6
Rewards Points: 46
Tubes that can be used for either single end feed or double end feed. They have some type of sensing circuit in them that tells them how to operate.
Old 07-08-2019, 08:11 AM   #7
I haven't seen those. I wonder if they are more expensive?
The way I see it, the doublesided tubes work in all situations. They will work with both shunted and non-shunted tombstones. If the light has shunted tombstones and is fed from a single side, you have to wire up the other side. But you are in there wiring around the ballast anyway, so moving that wire to the second tombstone really doesn't make a difference.
Old 07-08-2019, 08:22 AM   #8
Rewards Points: 46
For us they are the same price. We checked into double ended and that is how they came. We like them because we use them in 8' tandem strip lights and also wraparounds in new work as well and they come wired single ended.
Old 07-09-2019, 10:09 AM   #9
Rewards Points: 180
Been using the double-ended LED for about 4 years now. Sold/installed about 10,000 so far. I don't care what kind of tombstones I or my customers run into.
jw0445 likes this.
The Following User Says Thank You to joe-nwt For This Useful Post:
swimmer (07-09-2019)
Tags
ballast bypass t8 t12
