Under Cabinet Tape LED Issues - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 1 Post By jw0445
  • 1 Post By singleshot
  • 1 Post By dronai
  • 2 Post By JoeSparky
Old Yesterday, 03:06 PM   #1
Default Under Cabinet Tape LED Issues
I have installed 24V tape LED lighting under my kitchen cabinets. I am using a 200W power supply because I am also installing magnet switch operated in cabinet lighting.
The issue is with the power supply plugged in, my Delta Touch2O faucet will not work when touched. I have tried relocating the power supple as far away from the faucet as possible (about 10 ft). The faucet works as designed with the power supply unplugged. The power supply for the faucet solenoid is 6 AA batteries. I have found that if I hold the plastic battery pack in my hand the faucet works. I have tried using tin foil as a Faraday cage around the battery pack, solenoid and the LED power supply, none of these helped. I have also wrapped the plastic battery pack with tin foil and then with none insulated wire and grounded. This seemed to work but not consistently.
Any ideas? I can't be the only one who has had this problem.
singleshot is offline   Reply With Quote
Old Yesterday, 03:19 PM   #2
dronai's Avatar
Rewards Points: 49
With the 200W led power supply on, the faucet solenoid stops working ?
dronai is online now   Reply With Quote
Old Yesterday, 06:00 PM   #3
Same question
Sent from my Pixel 2 XL using Tapatalk
cburke0000 is offline   Reply With Quote
Old Yesterday, 06:01 PM   #4
What if you unplug the 200 watt transformer?
Do you still have the same issue?
Old Yesterday, 06:38 PM   #5
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 268
Sounds like "dirty" power from the LED driver is causing issues. You may need a different driver or make the tape light battery powered.
Ibtl.
Does the faucet work properly when the driver is off or unplugged?
Old Yesterday, 08:09 PM   #6
jw0445's Avatar
Rewards Points: 1,818
Two hundred watts sounds way overkill to me. Sounds like a power quality issue. IBTL
jw0445 is online now   Reply With Quote
Old Yesterday, 08:18 PM   #7
Beam Me Up Scotty
Rewards Points: 268
I installed a 150 watt driver on 7' of tape light the other day... it's about 100 watts too many, but I just did what I was told...
Old Yesterday, 09:26 PM   #8
jw0445's Avatar
If you look on the superbright led website the range for watts per foot vary from 1.5 to around 5 depending on what you're buying. My typical kitchen is a 50 watt or if doing top and bottom a 100 .
dronai likes this.
Old Yesterday, 09:59 PM   #9
Beam Me Up Scotty
Rewards Points: 268
I was also given the tape light to install. All it said was 96 watts. It was 16.4 feet before being cut down. We honestly have no clue the footage per foot of this stuff. If I really cared I could measure the LED's to find out the power draw per then determine the total wattage. I dont particularly care to though lol.
This is good to know though.
Old Today, 01:37 PM   #10
The LEDs are 14.4W/m and I am installing about 13m of lights at 24 VDV.
The faucet works if the power supply is unplugged from the wall. It does not work the the lights are on or off. They are controlled by a motion sensor. I have moved the power supply to the top of the cabinets with a distance of about 4m+ from the faucet and it doesn't make a difference. Delta helpline is sending me an isolation bushing to isolate the faucet from the granite countertop. They think that might help because the mineral content of the granite can magnify any interference and if the faucet down pipe is touching the granite it can cause the solenoid not to operate..
I have also installed a voice activated unit that will turn the water on and off using Alexa. This works as advertised.
I have researched how the touch works and it is capacitive touch. When you touch the faucet it senses the increase in capacitance and the solenoid opens and when it is touched again the capacitance drops and the solenoid closes.
dronai likes this.
Old Today, 02:19 PM   #11
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 6,502
Alexa?
Sounds like Google is jealous.
IBTL
Old Today, 04:50 PM   #12
dronai's Avatar
Rewards Points: 49
Voice activated seems like a problem waiting to happen.
Kevin_Essiambre likes this.
Old Today, 05:07 PM   #13
Rewards Points: 1,917
Alexa, turn off the faucet.
I'm not sure I can help with that
Alexa, turn off the faucet!
I'm having problems completing your request
Alexa turn off the damn faucet!!
OK, sending your location to the NSA
dronai and Kevin_Essiambre like this.
Swampy the Alligator for Moderator
* Make Electriciantalk Great Again! *
Tags
led, led drivers and rfi
