Vapour boots for Lotus Lights? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 1 Post By PlugsAndLights
  • 1 Post By sandbox
  • 4 Post By 99cents
  • 1 Post By yoricky
Old 05-08-2016, 07:35 AM
Rewards Points: 11,027
Default Vapour boots for Lotus Lights?
How do you guys rough-in for Lotus Lights in insulated ceilings? It might be easiest to just throw in a blue boot. It gives you a big cavity for the driver and avoids damage to the vapour barrier when cutting the hole. It adds eight bucks per fixture, though. Suggestions?
99cents is online now
Old 05-10-2016, 09:44 PM
I use a vapor boot for a 4 gang box attached to a rough in plate.
magnation is offline
Old 06-06-2016, 05:37 AM
Rewards Points: 54
I had never used vapor boot before. I think it's great.
JoeAPinkley is offline
Old 06-06-2016, 08:16 AM
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
I haven't tried this yet, but here's what I'm thinking of doing.
-cut 2 pieces of 2x4 to go between the rafters/trusses
-cut a piece of vapour barrier about 3'x3'
-put one of the 2x4's between the trusses with one end of the
VB draped over it and screw it in place through the trusses
-put other 2x4 in place 1 to 2' away
-drill a hole through one of the 2x4's for the nmd to enter
-drill this hole from the "inside out" and stop before going through
the vapour barrier - just stab a hole through the VP so it'll fit
tight around the nmd
-bring the nmd in
-RI done
I figure it'll take 5 mins. Really cheap and possibly free as the 2x4
and VB are often on sight.
If you see a problem with this, let me know. Like I said, I haven't
done this yet.
P&L
Majewski likes this.
PlugsAndLights is offline
Old 06-14-2016, 07:15 AM
Use rough-in rings. They are cheap and you can just leave the wire in the ceiling knowing that you can reach it when the rings are trimmed out . You can wire up the drivers Before or after drywall with this method
sandbox is offline
Old 06-14-2016, 05:16 PM
Lotus pots are IC rated though. That little gasket is what seals your pot light with the drywall and vapor barrier. You don't need to add extra boots or anything.
billyhunter likes this.
sandbox is offline
Old 06-14-2016, 06:08 PM
Safety Pin Member
sanbox may be correct that a separate VB isn't necessary, I'm not sure.
Particularly wonder how effective that'd be on popcorn ceiling.
Either way, if anyone is going to do it the way sandbox described, I
think you'd better make sure you put your lights up before the attic is
filled with blown in insulation.
Just my thoughts,
P&L
Old 06-14-2016, 08:06 PM
Yea if you find a talented drywaller they will make the bit shallow when they cut the rough in ring and won't cut through the entire vapor barrier. That way it'll hold up most of the blown insulation while you work. it might involve the apprentice going in the attic and poking the wire down though.
sandbox is offline
Old 06-14-2016, 09:34 PM
A talented drywaller? It would be easier to find a Neanderthal with a Doctorate.
Old 06-19-2016, 03:17 PM
Rewards Points: 18
A Lotus with a built in Jbox.
yoricky is offline
Old 06-25-2016, 11:43 PM
billyhunter's Avatar
Rewards Points: 208
level 8 is right, Lotus pot light is already IC rated, you do not need make any drywall, for rough-in, you can use Lotus rough in plate which you can get it anywhere who sells Lotus LED pot light, they look like this
or
http://www.bulbspro.com/fixtures/cei...and_brand=1619
billyhunter is offline
Old 07-20-2016, 07:26 AM
or
My jurisdiction still requires a boot even with IC rated cans. I tend to agree. A good seal is difficult with a textured ceiling. I think I'll try 4 11/16" boots suspended by a 2 X 4.
Recessed LED lights Flicker wncgnet Residential Electrical Forum 9 05-16-2016 09:41 PM
Removing unwanted recessed lights. Woodman General Electrical Discussion 4 05-03-2016 03:56 PM
IC rated Vapour all in one Pot light Aegis General Electrical Discussion 2 04-11-2016 07:06 AM
Dimming LED Lights power General Electrical Discussion 8 04-01-2016 07:06 PM
Hanging heavy lights on a furred wall. Year_Zero General Electrical Discussion 16 02-25-2016 06:38 PM
