Common panel/meter - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
Old 07-26-2020, 12:24 AM   #21
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 496
Originally Posted by MotoGP1199 View Post
This is very common in Southern California. Pretty much any neighborhood older than 1970 has something similar.
This is most definitely not common to see here. This is the first house in the city I've seen with a POA higher than the secondaries on a hydro pole.
I've seen a few in the country where its a long run of triplex so it's above the minimum height after sagging, but in the city it's just weird...
Vote Kevin for Moderator!
Old 07-26-2020, 12:32 AM   #22
MotoGP1199's Avatar
Rewards Points: 827
Most are definitely not higher than the secondaries but our POCO poles are a taller than the ones pictured. Depending on the building I do see some coming through the roof on 2 story buildings. On taller buildings they try to attach to the side if possible. The local POCO's pretty much demand on anything newer that is fed overhead that it must be at a location closest to the pole and does not go over the building. So they do sometimes have to go through the roof.
Kevin_Essiambre likes this.
"The laws of physics will be strictly enforced."
Kevin E. for MOD 2020
#HACKLIVESMATTER
MotoGP1199 is offline   Reply With Quote
Old 07-26-2020, 05:30 AM   #23
WronGun's Avatar
Rewards Points: 716
Default Common panel/meter
Originally Posted by kb1jb1 View Post
Wrongun, nevermind. We need to use ringless and lever bypass equipment. Much more expensive.
When I was an electrical inspector I had a inspection where the contractor installed a 9 gang system. I was a nice clean install but he bought his equipment from HD on line and it did not conform to local codes. Not ringless and no lever bypass.
This is $500
It is ringless style with horn bypass. I will check with utility if they want a lever.
Old 07-26-2020, 07:13 AM   #24
VELOCI3's Avatar
Rewards Points: 122
Originally Posted by Signal1 View Post
See NEC 210.25 (B)
The lighting you mention , any common are smoke alarms, outdoor lighting (if its a common yard etc.) would need to be separately metered.
Used to get away with "owner occupied" but not so much anymore.
Meter will need a bypass.
NEC 210.25(B)
This is dependent upon interpretation by the AHJ. This could mean separate meter or panel. It could also be waived.
VELOCI3 is online now   Reply With Quote
Old 07-26-2020, 12:02 PM   #25
Rewards Points: 1,042
Just a thought. Does 210.25 apply to a house that is divided into two or does it only apply to a legally defined two family dwelling? A house that is truly divided needs fire walls and all the other necessary separations otherwise it is just a single family house with two panels. The panels / service disconnects have to be grouped together and not one upstairs and one downstairs. Many people take a high ranch and divide it into illegal apartments. This is not a two family dwelling.
Old 07-27-2020, 09:16 AM   #26
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,736
Originally Posted by VELOCI3 View Post
NEC 210.25(B)
Nope
"Hanging ceiling fans for grandma"
M E T G A !
Old 07-27-2020, 07:33 PM   #27
WronGun's Avatar
Rewards Points: 716
I’m installing a common meter and panel on this job and rewiring all common circuits. It’s required if there are common areas.
The utility book is confusing as far as bypassing goes. It reads as if they only consider levers as bypasses.
It’s required in commercial and residential only if a common meter is present.
$1300 meter socket w/Lever
I’m still going to ask if Horn is acceptable.
Old 07-27-2020, 08:43 PM   #28
VELOCI3's Avatar
Rewards Points: 122
A lever bypass is for locking jaw pans. In order to bypass and remove the meter you must remove the cover. Then swing the bypass handle to release the meter.
There are two ways power passes through the meter socket.
-with the cover off and bypass handle in the up position
-meter installed with the handle down.
Handle down locks the meter in. The bypass also allows meter changes without service interruption.
Old 08-01-2020, 07:56 AM   #29
WronGun's Avatar
Rewards Points: 716
Because I really don’t want to touch the riser I went with the Siemens Power Mod Assemblies.
Lever bypass on the common.
